Why is this 0? Help Gauss's law
  • Thread starter Thread starter flyingpig
    Gauss's law Law
12 replies · 4K views
flyingpig
A long straight metal rod has a radius of 5.00cm and a charge per unit length of 30.0nC/m. Find the electric field
a) 3.00cm
It says a) = 0
I did some math and I got
[tex]2k\frac{\lambda}{r}[/tex]
The rod is solid, so should a E-field be radially outward from its symmetrical axis?
I am assuming that, what you wrote as, "the electric field a) 3.00cm" means "the electric field at 3.00cm from the center of the wire"
Answer to this question first: If you have a conducting sphere, carrying a charge say Q, than what is the electric field at a point inside it??
first check theory on electric field inside conductors.
[tex]k\frac{q}{a^3}r[/tex] for a < r
it is a metal rod. so all the charge would reside on the surface only, none can stay in the bulk.
so the field inside the rod is zero.
its for symmetrical charge distribution throughout volume. metals can't have that, all of their charge resides on surface! Can you tell why?
and i believe it must be "r<a"
So, but a metal sphere can too? Isn't that what my equation is?
Oh wait, I think I get it. The key here is that my equation is for an insulating sphere, not a conducting one. Hence.
Yes now you're right
If this was not a "metal" rod, or "insulating rod", then my numbers in the above would be right, right?
cupid.callin said:
i can't get you
If it is insulating, all the charges would be stuck and won't be all on the surface
If you are saying that this formula is for insulating sphere then you are right!
And also for the explanation, the charges will not move to the surface!
can you find the same for insulating cylinder?
flyingpig said:
[tex]k\frac{q}{a^3}r[/tex] for r<a
just draw a gaussian surface with r < radius of cylinder and coaxial with cylinder and use gauss theorem
