Why is V_x of a projectile constant?
11 replies · 2K views
NooDota
Why is the horizontal velocity for a projectile constant?
I understand it physically, since the vertical and horizontal velocities aren't related and don't affect each other, g will only affect V_y and neglect V_x, so it's constant.
But maths-wise, isn't V_x = V*Cos(theta)? How can it be constant if the angle is changing?
V_x = V*Cos(theta)
V_x = V*Cos(theta)
V is also changing, such that Vcosθ is constant.
Good question!
I
Good question!
##\theta## refers to the initial angle at launch, not the changing angle at which the projectile moves thereafter.
But the law for the horizontal velocity is V_x = V*Cos(theta) where theta is the current angle the velocity vector makes with the x+ axis, right?
No, that's wrong. ##v## is the magnitude of the initial velocity and ##\theta## is the initial angle. That's why ##v_x## is constant.
PeroK said:
I
That's only true if θ is defined that way. Clearly OP considers θ to be changing along the trajectory.
In this case we would likely θ0 as the initial value of θ,
As usual, rude man has answered well. - - short and complete.
Thanks Sammy. Owe you one!
You are correct, and vcosθ is constant unless you try to include air friction. Which you don't want to do, trust me! :smile:
Okay, thanks.
Another question, it's not worth making a thread for.If the velocity of a projectile is given by V = 25i -4.9j (y is directed upwards), has the projectile reached its highest point yet? The book says yes.Since it's moving downwards, that means yes. But what if I initially threw it down, and it bounced back up higher than its starting point?
NooDota said:
Okay, thanks.
That's no longer simple projectile motion.
NooDota said:
Okay, thanks.
Then its V would no longer be i 25 - j 4.9.
