jmb
- 67
- 1
- TL;DR
- (Slightly philosophical). Conservation of energy would be satisfied by a totally stationary state, is there any principle, other than empiricism, that allows us to discard this solution?
I realize to many people this might seem a silly or at least pointlessly philosophical question, but I was wondering if there's a deeper answer I've missed...
After a lengthy break in physics I've been playing around with some classical mechanics to try and probe my understanding (and memory!). And I realized this...
Conservation of Energy is not violated if nothing moves: a ball hanging in mid-air is a perfectly valid solution if conservation of energy is the only constraint.
My first reaction was that: "No, conservation of energy doesn't require anything to move, but the Euler-Lagrange equations for a system do. (In fact you can derive conservation of energy as a first integral of the system specifically by multiplying both sides of the E-L equations by ##\dot{x}_i##, which actually introduces this motionless solution: because ##\dot{x}_i## could be zero)." But then I realized this isn't true...
To derive the Euler-Lagrange equations you search for a path of the system between two points ##x_i\left(t_0\right)## and ##x_i\left(t_1\right)## for which the integral over the path of some quantity ##L\left(x_i,\dot{x}_i\right)## (the Lagrangian) is stationary w.r.t. changes in the path. However, typically in this derivation we implicitly assume that ##x_i\left(t_0\right) \neq x_i\left(t_1\right)##. Clearly if ##x_i\left(t_0\right) = x_i\left(t_1\right)## then (at least for the subset of problems where the Lagrangian is strictly positive, such as movement in a gravitational potential well) a path that does not go anywhere does indeed represent a stationary value of this integral: as the integral will equate to zero.
Obviously, we don't live in a totally motionless universe (and one could also argue that such solutions are unstable to perturbation), so it is easy to discard this solution on empirical grounds, but I was wondering: is there any other principle of classical physics that requires us to throw out the the 'motionless solution'?
To put it another way:
Conservation of energy says we can exchange potential energy for kinetic energy, and the Euler-Lagrange equations tell us how we would do so, but is there any principle that says that if a system can exchange potential energy for kinetic energy then it will?
Appealing to Newton's Laws doesn't help, as you either have to consider them as empirical or as a consequence of the Euler-Lagrange equations.
