Why isn’t there an equation to describe how energy is redistributed by destructive interference of an electromagnetic wave?
  • Context: Undergrad
  • Thread starter Thread starter Quarker
The discussion centers around the lack of a specific equation to describe how energy is redistributed by destructive interference of electromagnetic (EM) waves. Participants explore the implications of Poynting's Theorem, interference patterns, and the challenges in predicting energy distribution in various experimental setups, such as double-slit experiments and Airy discs.
  • Experimental/applied
  • Some participants assert that the energy of an EM wave is described by Poynting's Theorem and question the understanding of energy redistribution in interference patterns.
  • One participant suggests calculating the energy contributions from individual sources and comparing them to the combined effect to understand redistribution.
  • Another participant raises the issue that predicting energy pushed into areas of constructive interference is challenging, even under ideal conditions.
  • There is a discussion about the limitations of analytic solutions in physics, with some noting that numerical methods may be necessary when closed-form solutions are not available.
  • Concerns are expressed about verifying energy conservation in interference patterns, with suggestions for experimental approaches to measure total energy absorbed by a detector screen.
  • Some participants argue against the notion of energy being 'redistributed' in diffraction patterns, emphasizing the need for familiarity with diffraction theory.
  • One participant mentions the Optical Theorem of Lord Rayleigh as relevant to the discussion of energy conservation in diffraction patterns.
Participants express differing views on the predictability of energy distribution in interference patterns, with some asserting that energy conservation is upheld while others question the ability to verify this experimentally. The discussion remains unresolved regarding the specifics of energy redistribution and the applicability of existing theories.
Participants highlight the complexity of predicting energy distribution in interference patterns and the potential need for numerical methods in cases where analytic solutions are not feasible. There are also references to the limitations of existing theories and the assumptions underlying the discussion.
Quarker
The energy of an EM wave is described by a fairly simple equation. Why isn’t there an equation to describe how that energy is redistributed by destructive interference?
The energy of an electromagntic field is given by Poynting's Theorem. Destructive interference describes some points where the field is zero.
I suspect you have a misunderstanding about the electromagnetic field to ask this question.
Just take the "fairly simple equation" three times. One with the first source alone, one with the second source alone, and one with both sources together. Then subtract the two individual sources from both sources together. That will give the redistribution.
I’m thinking more of the interference pattern, not the entire EM field. In a double-slit experiment, or even a telescope’s Airy disc, there’s no way to predict how much energy will be pushed into the areas of constructive interference, even under ideal situations, as far as I know.
Do you mean cases where you end up with a solution that cannot be expressed in terms of elementary functions and requires numerical methods?
In physics generally, the neat analytic solutions that look so nice are very much the exception.
It sounds like there’s no way to verify that the energy going into an interference pattern equals the energy coming out, at least experimentally.
The total energy absorbed by a detector screen could be measured. You could calculate the energy with one slit open; then with the other open; and then both together. And, you could move the screen nearer or further from the slits and check the total energy remains the same for the different interference patterns.
In fact, I think there was a thread about this a while back.
Here are some relevant threads:
I can't find the thread about predicting the energy distribution in the double slit.
Thanks!
Would an artificial star and a sensor in a telescope serve the same purpose, or would the introduction of a lens in the light path create too many variables? It seems like it would be easier to measure the total energy of an Airy disc than a double-slit interference pattern.
I can't answer tat question. It seems somewhat random.
Perhaps.
Being fond of Airy discs, the OP may wish to investigate th Optical Theorem of Lord Rayleigh. This was a somewhat shocking result in its day and has been extended and rediscovered many times in EM and Quantum theory showing conservation of energy (or probability).
Please don't draw that conclusion from the comment you replied to. So-called closed form solutions (that give exact results) are indeed not the norm, even though those are what you tend to learn in school.
Approximate solutions are not what they may seem. In cases where closed form solutions are not possible (for example, a solution to the three-body problem) numerical methods can produce results to any desired amount of accuracy. Think about an infinite series that converges to a value. You can get an answer as close as you desire to that value by adding a sufficient number of terms in the series. The more terms you add the closer you get. There is no limit on how close you can get.
Those comments are actually not true. Energy is not 'redisributed' in a diffraction pattern because there's nowhere for it to be distributed from or to. There's no reason to suspect that the diffraction equations are not right. You need to get familiar with diffraction theory.
If you really wanted to verify, practically, that the total energy in the Airy Disc is (within certain limits, of course) defined by the area, all you need to do is to take two lenses of different radii. The two Airy Discs will have different apparent 'diameters' but an image of the Sun on a large thermal detector will produce the same heating effect when scaled according to lens areas. The diffraction patterns of each lens will have different disc and outer ring sizes. The nulls that you are so concerned about will be in different places but the total energy (limited by the same apertures of the lenses) will be 'conserved'.
Why would you have a problem with that? Not knowing the theory doesn't justify disagreeing with it.
  • · Replies 21 ·
  • · Replies 48 ·
  • · Replies 71 ·
11K
  • · Replies 17 ·
