scilover89
- 78
Why waves, such as light, will diffract when they pass through a small hole or slid?
scilover89 said:Why waves, such as light, will diffract when they pass through a small hole or slid?
jtbell said:It's because of interference between the light that goes through different parts of the slit or hole.
Remember two-slit interference? You add two waves (with different phases) together and they interfere. Now imagine dividing a single slit into lots of tiny "sub-slits," and add up the waves coming from each of those sub-slits. Each of those waves has a slightly different phase. Take the limit as the number of sub-slits becomes infinite, and the width of each slit becomes infinitesimally tiny. You end up with an integral that gives you the overall intensity.
Note that when we do two-slit interference, we usually start by assuming that the slits are very narrow so that their width doesn't matter, only the spacing between them. When we do take the slit width into account, we get a combination of the single-slit and double-slit interference patterns: the maxima in the double-slit pattern have different intensities, in a pattern that matches the single-slit pattern.
dextercioby said:Well Zz,how come the classical theory of LIGHT DIFFRACTION (you know,the one made by Fresnel,Fraunhofer,Kirchhoff and Sommerfeld) is both correct & elegant,while the one proposed by Feynman (with those photons taking a bunch of paths) is horrible and noninteligeable...?
I'll say diffraction is a wave-like phenomenon and applying to it the famous duality,though correct,would complicate things beyond one's power of comprehension.It would be interesting to view water waves' diffraction through the eyes of the HUP...
The diffraction is so nice with Fresnel integrals and Bessel functions,why bring in operators and propagators...?
Daniel.
ZapperZ said:Actually, this doesn't answer the question. If what you said is true, then how come you don't see such effects when the slit is WIDER? After all, why can't you still divide the slit into many, many more smaller slits?
Why would the diffraction effects go away?
jtbell said:You still can!
As the slit becomes wider and wider, the "diffraction effects" become smaller and smaller relative to the overall intensity at each point on the screen. But they're still there, in principle. Try putting a point source behind a large aperture, and a screen close to the aperture. Look closely and you'll see diffraction effects at the edge of the shadow of the aperture's edge. They still exist in the middle of the "beam", but they're imperceptibly tiny.
You have to be careful when doing the integral in such a situation, though. When we derive the standard single-slit diffraction formula, we use the Fraunhofer approximation, which assumes that the rays from various points in the slit to the image point on the screen are practically parallel, and that all points in the slit are equidistant from a point source. If the slit is wide enough, this approximation breaks down.
We can do better with the Fresnel approximation. Look in an optics book or on the Web, and you can probably find some nifty diffraction patterns generated that way. Try searching for "Cornu spiral", which is a graphical device to aid in generating such patterns. Once upon a time, I did some that recognizably approach the "no-diffaction" regime.
And finally for the ultimate accuracy and generality, do the integral numerically, customized for the specific source, slit and screen configuration.
ZapperZ said:We can't just leave the explanation as "many point sources in the slit".
jtbell said:At a fundamental level, at least in terms of the Huygens-Fresnel diffraction theory, that's really all it is. More precisely, if the slit is illuminated by a point source, the basic idea is "many paths from the source to the point P on the screen," each path connecting the source and one sub-slit with a straight line, and the sub-slit and point P with another straight line. Actually, we should use the term "sub-aperture" rather than sub-slit, because this formulation applies also to two-dimensional apertures.
For example, see Hecht's Optics, which starts its discussion of the rectangular aperture on p. 497 with the contribution to the field at P, from a single sub-aperture:
dE_P = \frac {K(\theta) E_0} {\rho r \lambda} \cos [k(\rho + r) - \omega t] dS
where E_0/\lambda is a constant related to the intensity of the source, \rho is the distance from the source to the sub-aperture, r is the distance from the sub-aperture to P, and K(\theta) is Kirchhoff's obliquity factor
K(\theta) = (1+\cos \theta) / 2
where \theta is the angle between the two lines described above, which prevents the aperture from producing a wave that goes backwards towards the source. The \rho and r in the denominator produce an inverse-square falloff of intensity with distance, going from the source to the sub-aperture, and from the sub-aperture to P, as we should expect.
This is equivalent to having the sub-apertures as our "original" sources, producing waves with different amplitudes and phases, from different locations within the aperture.
Starting from here, the only difference between different situations (single slit, double slit, circular aperture, rectangular aperture, whatever) is the geometry of integration and the approximations that one uses to make solving the integral less complicated.
At this level, the only 'ad-hoc' thing in the expression above is the obliquity factor. But it emerges naturally when you do a rigorous derivation starting from the differential wave equation.
dextercioby said:Yes,Halls,that picture of Huygens' principle is really nice.Though i'd still vote for Kirchhoff's integral...
Daniel.
T.Roc said:all
Why doesn't this happen with a laser (1 coherent freq.) through the slit?
TRoc
T.Roc said:dex, zz
I simply mean that I don't get the same results through the same slits when I use a laser, and when I use "white" light. What does this mean?
TRoc
T.Roc said:Zz,
Actually, I started with white light, and produced the pattern predicted by the text. It was months later that I got my hands on a laser.
Do not let this throw the question. Your last post is what I want to learn about. Namely, what are the expected differences in refraction through 2 closley space slits based on monochromatic, dichromatic, and polychromatic light waves?
TRoc
T.Roc said:since lasers were not around when this experiment was first done, how was their "monochromatic" light made?
TRoc
T.Roc said:"Lasers are monochromatic
This is incorrect, all lasers posess a finite linewidth, some lasers (supercontinuum lasers) have linewidths that can cover a large portion of the frequency spectrum."
so can you explain diffraction without saying you must start with monochromatic light?
