Why are narrow discharge tubes preferred for viewing spectra?
  • Thread starter Thread starter NitroNinja
    Discharge
Narrow discharge tubes are preferred for viewing spectra due to their ability to produce a thin emission of light, which enhances spectral clarity. The confinement of gas within these tubes allows for more precise control of light emission, resulting in sharper spectral lines. This design is also evident in commercial fluorescent lighting, which utilizes long, thin tubes to optimize light output while maintaining efficiency. The use of slits in conjunction with these tubes further refines the spectral viewing experience.
  • Understanding of spectroscopy and light emission principles
  • Familiarity with discharge tube construction and function
  • Knowledge of gas behavior in confined spaces
  • Basic concepts of light optics and spectral analysis
  • Research the principles of spectroscopy and how narrow tubes affect light emission
  • Explore the design and function of discharge tubes in various applications
  • Study the role of slits in enhancing spectral resolution
  • Investigate the physics behind gas confinement in narrow containers
Students studying physics, educators teaching optics and spectroscopy, and professionals involved in lighting design and spectral analysis will benefit from this discussion.
NitroNinja
This is a part of a homework question, and a concept that is expected to be understood. "Why do you think discharge tubes have a narrow waist?".
I was thinking about attempting the question like this:
Discharge tubes are mainly used to view spectra. And hence a thin tube, will allow a thin emission of light. But then, i couldn't think of an explanation.
I'd appreciate help!
You use a slit to get a thin line for spectra. This works for any shape "tube".
It's used on stars for instance.
You'll notice also that commercial florescent lighting usually comes in long thin tubes... sometimes bent into spirals for domestic light fittings. All they have to do is let you see stuff.
So what you need is some advantage to having the gas confined to narrow containers.
  • · Replies 0 ·
10K
