Why Should We Care About Integrals?
  • Context: Undergrad
  • Thread starter Thread starter holezch
    Integral Motivation
9 replies · 3K views
holezch
Hi, this has been bugging me for a long time: I am lacking a philosophical concept or just a general motivation behind the concept of an integral. To me, "computing the area under a graph" seems too specialized to me, especially how our pictorial representation of a function could have been arbitrary. When I ask why I should care about the integral at all, I'm usually given answers like "to find the volume of a swimming pool.." , " to build MRI scans.." and I am unsatisfied with these answers. When I study algebra (vector spaces, rings ) it has a nice "beautiful picture" behind it.. I do not find this same intrinsic interest when I look at integration, can someone help motivate or enlighten me? thank you
Integration is, in essence, the inverse of differentiation. The Fundamental Theorem of Calculus says, in part,
[tex]f(x) = \frac{d}{dx}\int_a^x f(t)dt[/tex]
In one sense you are finding out different measures (length, area, volume etc) that have non-linear parts. It generalizes all the notions of measure to the point where you can calculate appropriate measures of any kind of non-linear line (ie a curve of some sort).
Add into the equation vector calculus and you can compute answers involving vector concepts such as the sum of "projections" of a vector field on to some plane. Again just like the above example with measures: we are generalizing to calculate examples that aren't simply linear (in vector calculus our "linear" object is a plane).
The other thing is that in mathematical modeling, we don't know the explicit solution to some system, but instead we know how it changes instantaneously. Calculus provides the method to go from our initial definition of "infinitesimal" change to either an explicit model of our system, or if the analytical solution is too complicated or can't be found, a numerical simulation is used to model the system as accurately as possible.
In high school we were mostly taught about different measures like length, area, volume and so on, but all of these measures involved straight lines (ie linearity). So generalizing this to non-linear situations means the invention of calculus.
mathman said:
Look up "integral applications" with Google or Bing or your favorite search engine. You will be overwhelmed with examples.
I don't want to see more "integral applications" , that is the reason why I made this thread
I was going with this for a while, but not all functions that are integrable have primitives, so I don't think this is general enough
Thank you, this kind of motivation is what I would like to hear.. I also realized that it's interesting intrinsically because it's just another function you can somewhat easily form out of old functions, and satisfies interesting properties such as it always being continuous.. et c
is integration a way to "measure" a set?thanks everyone
holezch said:
Thank you, this kind of motivation is what I would like to hear.. I also realized that it's interesting intrinsically because it's just another function you can somewhat easily form out of old functions, and satisfies interesting properties such as it always being continuous.. etc
thanks everyone
I haven't done a graduate course in analysis, but there are actually many different types of integrals.
The one people are taught early on in calculus classes is known as the Riemann integral. Its basically represented as a lot of rectangles that have a height of some function value, and basically the width of the boxes approaches zero without actually being zero (since 0 x a = 0 for any a).
The next version of integration is known as the Lebesgue integral. This involves more math including sets and measures.
In a way you're analogy of "measuring a set" can have some validity, but without being more specific I can't say whether the idea in your head is the same as the idea in mine.
Generally, speaking, things that in, nice, easy, constant situations, involve division, such as finding the slope of a line, the speed of an object, or the weight or mass density of something, become the derivative when things are not so nice.
Conversely, problems that involve multiplication, such as finding area or volume, finding distance moved given the speed, finding the weight given the density, become integral problems when we do not have constant height, speed, density, etc.
All integrable functions have entire families of primitives, namely if f(x) is integrable, then one primitive of f(x) is
[tex]F(x) = \int_k^x f(t) dt[/tex]
where k is an arbitrary constant. I believe you may be referring to the fact that most primitives cannot be written as finite combinations and compositions of the few elementary functions that we find useful in the most common idealistic situations, which should not be surprising, as the vector space of functions over R is infinite dimensional. The natural logarithm is defined as exactly this type of function, a special primitive of 1/x.
We find quite a few more functions useful in addition to the elementary functions, and many of them are defined using integrals. See Special functions. The only reason they are not taught at basic high school level is that they are only used in very specific circumstances or in advanced theory.
Yes. You should check out a basic text on measure theory; it is used as a basis for probability and statistics.
thank you, I have to go to work now but I will look into this
Not all integrable functions have primitives ( i.e. step functions, derivatives cannot have pointwise discontinuities ), a primitive is guaranteed if the function f is continuous
True, I was thinking of primitive as just a function that agreed with the definite integral, but I see that it needs to be differentiated back to the integrand.
