Charles123
- 131
Why Single-wire Earth return systems are only used in rural areas? Why not also in urban areas where there is only demand for single phase power?
Single-wire Earth return (SWER) systems are primarily utilized in rural areas due to cost efficiency, allowing for a single copper conductor instead of two. In these systems, a pole-mounted transformer provides both active and neutral wires to isolated farms, with the Earth serving as the return path. Urban areas, however, require balanced three-phase loads and multiple customers per transformer, necessitating the use of neutral wires and making SWER impractical. The voltage drop across the Earth return in urban settings would be significant due to higher current demands, necessitating automatic voltage regulation to maintain service quality.
PREREQUISITESElectrical engineers, utility planners, and professionals involved in rural electrification or electrical distribution system design will benefit from this discussion.
