Why Telcom Equipments are fed with -48V
  • Thread starter Thread starter Telco
Telecom equipment predominantly operates on -48V instead of +48V due to anti-corrosion properties. A positive voltage on metal wires promotes corrosion, while a negative voltage relative to earth mitigates it. This design choice ensures uniformity across equipment, eliminating the need for separate local and remote versions. Even rack-mounted telecom equipment adheres to this standard to maintain compatibility and reliability in various environments.
  • Understanding of DC voltage principles
  • Knowledge of corrosion effects on metal wiring
  • Familiarity with telecom equipment standards
  • Basic concepts of electrical engineering
  • Research the impact of voltage polarity on corrosion in electrical systems
  • Explore telecom equipment design standards and specifications
  • Learn about power distribution methods in remote telecom installations
  • Investigate the role of -48V in enhancing equipment longevity and reliability
Telecom engineers, electrical engineers, and professionals involved in the design and maintenance of telecom infrastructure will benefit from this discussion.
Telco
Almost all Telecom Equipments are fed with -48V why not +48V?
Anti-corrosion. Originally the DC power was fed down the telephone wires to power remote equipement a +ve voltage on a metal wire encourages corrosion a negative voltage (relative to earth) reduces it.
For equipment inside the electronics rack it doesn;t really matter.
Hi
But even Telecom equipments (Rack type) are working with -48V..
Is it the same reason or any other specific reason for that??
Telco said:
But even Telecom equipments (Rack type) are working with -48V.. Is it the same reason
Yes, you don't want to have to build a local and remote version of the same kit.
And even kit in a rack might be put out in a street corner box and fed from a central exchange.
  • · Replies 17 ·
25K
10K
