Why was ∠ BAC = θ given in this problem?
  • Thread starter Thread starter Jbreezy
    Vectors
57 replies · 7K views
Jbreezy
The points A,B,C, D with position vectors a,b,c,d are coplanar. Given : ∠ BAC = θ
(a) Find an expression for a unit normal of this plane.
(b) Find an expression for the distance of this plane from the origin
(c) Prove that
[abd] + [bac] + [cdb] + [dca] = 0
So, I did part a and b but I'm just having a doubt. I'm wondering why I was given ∠ BAC = θ I didn't do part c yet so maybe it comes in there.
First I found two vectors on the plane then I crossed them. I chose to use a,b,c.
So I did
(b-a) = u = (<ux, uy,uz>
(c-a) = v = (<vx, vy,vz>
I did u cross v =
< (uyvz-vyuz)-(uxvz- vxuz) + (uxvy-vxuy) >
Lastly I just took u cross v and divided it by its own norm.
< (uyvz-vyuz)-(uxvz- vxuz) + (uxvy-vxuy) > / √(< (uyvz-vyuz)2-(uxvz- vxuz)2 + (uxvy-vxuy)2 >
Call the unit vector that I just got r(hat) then for part b all I did was to do r(hat) dot a
I could of chosen any of the other position vectors to dot with because the question says that they all lie in the same plane and all I need is a vector in that plane right? So once again why
∠ BAC = θ
Thanks
Would ∠ BAC = θ be given because if it wasn't I may do a cross product and the angles between might be 0 or 180 resulting in the 0 vector? So this just guarantees I won't get a 0 vector?
Indeed, you are given the condition so that you know vectors a,b,c are not collinear.
(c) Prove that
What does the notation [abd] mean? You need to tell us so we don't have to guess.
Apparently that angle is being named ##\theta##. It doesn't tell you anything about the angle.
So I did
I did u cross v =
The cross product is a vector. You just have a single scalar inside the brackets. You need to separate the components of the vector with commas.
So once again why
∠ BAC = θ
Thanks
Unless there is something you haven't told us, that is just the name of that angle.
OK, does the other part look correct? Please and Thanks.
< (uyvz-vyuz)i-(uxvz- vxuz)j + (uxvy-vxuy)k >
This work too no?
And [abd] is just triple scalar product.
Don't worry about that because I have to still do that part. I just want to know if my other parts are correct ...please and thanks
This work too no?
No. Either use the bracket notation or the ijk notation, but don't mix them. Also, as others have suggested, when you mean subscripts make them look like subscripts.
It was supposed to be subscript like above but it doesn't just copy and paste apparently.
< (uyvz-vyuz),-(uxvz- vxuz), (uxvy-vxuy) >
There we go.
The other part is correct no? a and b?
The length of a vector is just a number. What are the < and > brackets in there for?
There we go.
Yes except for notation. See above.
Also, I would suggest you start using LaTeX. Subscripts are much easier. For example your uyvz-vyuz expression could be typed like this:
##u_yv_z-v_yu_z##. Press the Quote button to see how to do that.
uyvz−vyuz. Press the Quote button to see how to do that
OK, I will fix the notation. Also LaTex is quite annoying for me. The other day I tried it and I felt like it took me way to long to write something out and it wasn't even correct I had all sorts of issues. I feel like its more trouble to me.
I have a proof but it is ratty but it is right.
(c) Prove that
So if you rearrange it you can see it a little better.
[abd] + [cdb] + [bac] + [dca] = 0
Notice that b cross d = -(d cross b)
So if you are do b cross d + d cross b you get 0
But this is kind of informal. I'm trying to think of a better way to show it.
What you should NOT do is annoy the people whom you want to help you! If you cannot use TeX because it is too much trouble for you, and you cannot use the X2 or X2 buttons because they are too much trouble for you, at least you should use proper ASCII, like this: u_x, etc.
What are you even talking about? I copied and pasted something from above that wasn't transferred in the paste so that is what LCKurtz was telling me to use subscripts for. It was an accident all my others have subscripts. Relax dude.
The reason the subscripts don't come through is that you are using copy/paste in the first place. You should always use the Quote button instead of copy/pasting. Start your response with the quote button in the post to which you are replying. You can always delete stuff you don't want in the quote.
Did you try pushing the Quote button in my post #8 like I asked you to do? If you haven't yet, do it now. There is no way subscripts and superscripts aren't easier with Latex.
(c) Prove that
It's also wrong. What you have is [abd]-[cbd] for those two terms. They aren't the same so why should you get 0?
No No. I have you get the 0 vector. I have [abd] + [cdb] not [abd]-[cbd].
I say you get the 0 vector because [b cross d= -(d cross b)
what [abd] means is ( a dot ( b cross d) It is why I said it was a ratty proof I think it is right though. But I need to think of a better way to show it.
Read my post again. The - sign is from switching the b and d.
No I didn't abandoned this thread. I'm thinking. How can triple scalar products be equal to the 0 vector if by definition the operation produces a scalar?
I mean the left side is a bold 0 so doesn't that mean the zero vector not just 0?
Thats how the question was given to me! lol.
I didn't just bold it for no reason. How can you say that both sides are scalars then? I agree but why was it given in bold?
$$\begin{bmatrix} ax & ay & az \\ bx & by & bz\\ dx & dy & dz\end{bmatrix} \
+ \begin{bmatrix} cx & cy & cz \\ dx & dy & dz\\ bx & by & bz\end{bmatrix}= $$\begin{bmatrix} ax + cx & ay + cy & az + cz \\ bx + dx & by + dy & bz + dz\\ dx + bx & dy + by& dz + bz\end {bmatrix}ignore this! sorry
+ \begin{bmatrix} cx & cy & cz \\ dx & dy & dz\\ bx & by & bz\end{bmatrix}= $$\begin{bmatrix} ax + cx & ay + cy & az + cz \\ bx + dx & by + dy & bz + dz\\ dx + bx & dy + by& dz + bz \end{bmatrix} = 0 because two rows are the same
What about this dude?
Are those matrices or determinants? I'm guessing determinants since you claim the result is 0. But you have added them like they are matrices. Altogether it is just nonsense. The determinant of a sum of two matrices is not the sum of the determinants of them.
Instead of trying to defend your incorrect argument you might be better off trying to understand why it is wrong.
I have to leave now. Think about that while I am gone.
I didn't know there was a difference. Oh well.
If you do not know what matrices and determinants are, then it is not a good idea to try to use them!
__________________
"Euclid alone has looked on beauty bare"
Edna St. Vincent Millay
Steller advice amigo.
Y 09:39 PM
Well the problem is the dot product with different vectors.[abd]-[cbd]
I wish a = c then I would be good. But it doesn't.
Yes, that's why your argument doesn't work. You could have guessed you didn't have a solution to the original problem because you never used the fact that the four points are given to be coplanar. Before you will be able to actually solve the original problem, you have to know some things about the triple scalar product [abc] (sometimes called the box product) of three vectors in general. So here are some preliminary questions about that:
1. Does [abc] mean ##a\cdot (b \times c)## or ##(a\times b) \cdot c##, or does it matter?
2. What happens to the value of [abc] if you swap two of the vectors?
3. What happens to the value of [abc] it two of the vectors are the same?
4. What happens if you have a constant k times one of the vectors: [(ka)bc]?
5. What happens to its value if one of the vectors is a sum: [(a+d)bc]?
6. What does it mean geometrically about the vectors if [abc]=0?
Start by answering those questions. You need to know them to work out the hint I will give you next.
