Why we call 'Passive' sign convention?
The discussion centers on the terminology of the "passive sign convention" in electrical engineering, specifically why it is termed "passive." Participants clarify that passive components, such as resistors, follow this convention where current flows from the positive to the negative terminal. In contrast, active components, like batteries, utilize the active sign convention. The conversation highlights the importance of these conventions in circuit analysis and power calculations, emphasizing that the naming conventions are based on the nature of the components involved.
  • Understanding of electrical components: resistors, capacitors, inductors
  • Knowledge of current flow conventions: conventional current vs. electron flow
  • Familiarity with circuit analysis principles: Kirchhoff's laws
  • Basic grasp of power calculations in electrical circuits
  • Research "active sign convention" and its applications in circuit design
  • Study "Kirchhoff's Voltage Law" for deeper insights into circuit behavior
  • Explore "power calculations in electrical circuits" for practical applications
  • Investigate "electron flow vs. conventional current" to understand historical context
Electrical engineering students, circuit designers, and professionals involved in power systems who seek clarity on current conventions and their implications in circuit analysis.
coolpursuit
Hello, It's my first time login.
I'm not good at english.
Of course, I'm not native speaker.
I wonder why we call 'passve' sign convention.
have a good day. :)
I had never heard of passive and active sign convention before reading this. Now I've learned something new, thanks to you both!
I googled "passive sign convention" and got some good hits. This is the first hit on the list, and explains it pretty well.
Welcome to the PF, BTW.
http://en.wikiversity.org/wiki/Passive_sign_convention
ugh, i don't like that link at all. :rolleyes:
Example 1.2
Figure 1.6: Example 1.2
Figure 1.6 shows a simple resistor with the following parameters:
VR = − 6Volts , IR = 3A
Find PTotal and Determine if this resistor is supplying power or dissipating it.
Solution:
\begin{matrix}\ P_{Total}&=&V_R \times I_R \\ \ \\ \ &=& -6V \times 3A \\ \ \\ \ & = & -18Watts \end{matrix}.
Since power is negative this resistor is supplying power.
this is a recipe for failure.
Can we simply say:
With passive sign convention, a positive current flows from the + terminal to the - terminal inside the device (examples: resistors, capacitors, inductors)
and for active sign convention, it's the other way around (examples: battery cells and other power supplies)
Welcome to PF!
Yes, but nobody's answered the original question, which was, why passive? :cry:
coolpursuit said:
I wonder why we call 'passive' sign convention.
oh, and hello coolpursuit! :smile:
Welcome to PF!
Proton - one thing to note about Wikipedia - what one person views at 1000 may not be what you see at 2300. Wikipedia is not the most reliable source for a variety of reasons.
i'm not exactly sure i understand the question. passive components are passive no matter which current convention you choose, but...
i believe the important thing is that current into sinks (passives) is opposite the direction for current into a source. for example, you could choose to use electron current instead of conventional current and the current would change sign in both sinks and sources, but current would still be in the same direction as voltage for one, and opposing for the other.
much of this goes back to the physics of the problem. if you draw a simple circuit with one voltage source and one resistor, the first thing you may notice is that http://en.wikipedia.org/wiki/Kirchhoff's_circuit_laws#Kirchhoff.27s_Voltage_Law_.28KVL.29" will ensure that current is in phase with one voltage, and out of phase with the other.
and in a more general sense, you can extend this type of network theory to other systems. "[PLAIN]http://www.20sim.com/webhelp/modeling_tutorial/iconic_diagrams/acrossandthrough.htm" are not limited to electrical, you could apply the same principles to mechanical systems, and solve with the same mesh and nodal analysis. and this probably goes back to why conventional current is used instead of electron current. it keeps things like power calculations in generalized through and across variable network theory consistent.
Exactly!
I think what coolpursuit is asking (and I'd like to know, too :smile:) is why it's called a "passive" convention …
passive components are passive (!), but what does that have to do with the sign convention for current? :confused:
tiny-tim said:
Exactly!
i have no idea why it's called a passive convention. why not call it source sign convention? why not label electrons positive? that's why i say i don't understand the question. conventions are conventions, and are chosen at convenience. some choices really don't matter, as long as we all agree on the definitions.
Why not indeed! :biggrin:
But if it was called that, coolpursuit and I wouldn't be asking why … it would be obvious!
If we asked why negative rather than positive (for electrons, or for charge generally), the answer is that there are only two choices, and the choice was only arbitrary as between those two, in the sense that the word "positive" has no prior meaning … it was undefined. But "passive" does have a prior meaning … it describes a type of component, the opposite of "active" components.
So why is the convention associated by name with those components?
It just makes sense (to me anyway) that we would use passive sign convention for passive components (like resistors), and the opposite -- active sign convention -- for active components (like batteries).
Yes, but doesn't the passive sign convention apply to both?
Or am I missing the point of the convention? :confused:
(i'm not a very conventional goldfish :rolleyes:)
that's just the thing, tho. if we choose electron current (by convention), then the signs for current change in both active and passive components.
Hi Tim.
No, for batteries active sign convention (opposite to PSC) is used instead.
With passive sign convention, a resistor has positive current when the voltage is positive: current flows from + to - within the resistor.
With active sign convention, a battery has positive current and voltage when connected to a resistor. Current flows from - to + within the battery.
If you like, I could provide a couple of drawings showing this, but I hope you can understand it from my description so far.
p.s. I'm thinking that the whole issue of negative charge flow, and electron flow being opposite to conventional current flow, is not really relevant here.
I don't really like that wiki article either. Example 1.3 is just plain wrong. In this example the resistor is supplying power to the circuit and they state the opposite.
**Ok of course it can't actually be a "resistor" then but that's unimportant to me. Whatever it is it's clear that the device with voltages and currents as given is suppling power and not as they state absorbing it.
  • · Replies 20 ·
  • · Replies 51 ·
15K
