@256bits:
I had thought of the buoyancy effect too ...
Considering the different materials involved, I don't think the volume expansion was big enough but it's easy to check - simplifying the 1l of water is a cube 10cm on each side that weights 1kg. Water is nice like that. How much would the volume have to increase to cause a weight decrease of the order of 50mg? Ergo: how much do the sides increase? Would you notice?
The fact that there is no measureable difference in weight-loss for the other materials is problematic, but there is not a good enough control available to see if it is real. The trouble with home experiments is that you seldom get the kind of rigor needed to draw decent conclusions.
@Gh778:
As the bubbles rise, an equal volume of water must fall...
It's a bit like the sealed container of birds sitting on a sensitive electronic balance - and all the birds start flying around. What happens to the reading on the balance?
Another imagining: you sit in a sealed container with a cylinder of helium and a stack of balloons. You inflate the balloons and let them float up to hit the top of the container.
Note:
lime water (a saturated solution of calcium hydroxide) turns cloudy when carbon dioxide bubbles through it.
There's all sorts of problems concerning the quantities over the time involved.
You could do the experiment under water to see if bubbles form around the seals and over the surface of the container. Presence of bubbles confirms gas is escaping. Lack of bubbles is no information because the escaping gas is so small and slow that it could be dissolving into the water instead of forming bubbles. Similarly, doing the experiment under lime water - the concentration of CO2 may be too low for any clouding to be visible.
You could ramp up the experiment with an insane number of tablets so outgassing will be significant... but that does not confirm outgassing for the low-pressure case unless you are very careful.
There is probably something else I'm forgetting.
It's really not that difficult though:
Things that cause scales to read low are:
1. reducing the amount of matter present on the scales (outgassing suspected)
2. adding an extra gravity-opposing force from outside (buoyancy)
3. faulty scales - perhaps the scales lose 50-60mg over that time anyway?
4. acceleration of gravity changes
