Will nuking jupiter start a helium/hydrogen fusion reaction?
The discussion centers on the hypothetical scenario of detonating a nuclear weapon on Jupiter to initiate a helium/hydrogen fusion reaction, exploring the conditions necessary for fusion and the implications of such an event. Participants examine the physical properties of Jupiter, the mechanics of nuclear fusion, and the potential outcomes of such an explosion.
  • Some participants assert that Jupiter lacks the mass required to sustain nuclear fusion, suggesting that if it could, it would already be classified as a star.
  • Others propose that even if fusion were initiated, it would not result in an explosion but rather a stable equilibrium state of fusion at a constant rate.
  • A participant questions the energy dynamics of a fusion bomb and whether it could raise the temperature and density of Jupiter's atmosphere sufficiently to ignite fusion.
  • There is a discussion about the necessary conditions for fusion, including gravitational pressure and the role of mass in sustaining a reaction, with some arguing that a cold dense star of hydrogen would not remain stable without igniting on its own.
  • Concerns are raised about the activation energy barrier for fusion and whether external conditions could allow for a sustained reaction after an initial impetus.
  • Some participants note that while sustained fusion may not occur, there could be some fusion of hydrogen as a result of the explosion.
  • One participant mentions that the heat from a comet impact on Jupiter was significantly greater than any nuclear bomb and discusses the challenges of increasing density without poisoning the fusion reaction.
The discussion features multiple competing views regarding the feasibility of initiating fusion on Jupiter through a nuclear explosion, with no consensus reached on the potential outcomes or the underlying physics involved.
Participants express uncertainty about the energy requirements and conditions necessary for fusion, as well as the implications of gravitational pressure versus thermal motion in sustaining fusion reactions.
dazzlepecs
ala the sun?
Jupiter's upper atmosphere is composed of about 88–92% hydrogen and 8–12% helium
http://en.wikipedia.org/wiki/Jupiter
considering many nuclear weapons have a fusion stage
would the explosion propagate?
what would rain on my parade?
No. Jupiter doesn't have the mass to sustain nuclear fusion. If it did, it would already be a star.
...and even then, it wouldn't explode, it would just be in an equilbrium state, fusing at a certain, relatively constant rate.
dazzlepecs said:
ala the sun?
I would first want to know how the energy of a fusion bomb varied with the volume and how much energy we could pack in some small volume? Say all the energy of the bomb is absorbed by some shell of Jupiter's atmosphere surrounding the bomb. This energy will raise the temperature and density of this small shell of gas. If the energy released by the bomb is large enough the gas will be hot enough and dense enough to ignite? I don't know if you can simply argue that no additional energy is produced, seems there would at least be a little extra from unlikely events? Or is it that you just can't pack enough explosive energy a small enough space for the case of Jupiter?
But what if we had a cold dense star of hydrogen, no thermal motion. Not so dense as to form a neutron star. Now let's set off a fusion bomb, are conditions now different?
Thanks for any help!
The reason stars are able to form stable fusion reactions is because their enormous gravity is great enough to balance the enormous outward pressure produced by the reaction, and that their high gravity creates the initial pressure needed to ignite the reaction in the first place. You can't just have a "cold dense star" made of hydrogen - if it's so dense to sustain fusion, it will inevitably ignite on it's own. If it's not dense enough, any fusion pressure would cause the star to swell, and then you'd lose the pressure needed to sustain the reaction...
How do you know that? Surely there's a high activation energy barrier to ignition, and after ignition there's far more energy available to sustain the reaction. (There's plenty of examples in nature, of stable things that just need some external impetus after which they can sustain a very different state.) I don't know whether or not your claim has any truth to it, but don't you need the support of some kind of modeling to be able to be convinced of your statement? (Are you actually trying to argue that the heat of Jupiter's coalescence was enough to ignite any potential fusion processes, and that it has since petered down?)
It really doesn't have to do with heat in the way a chemical reaction does... what matters is gravitational pressure.
The outward pressure of a nuclear reaction is enormousness... think of the energy released by a nuclear bomb, except millions of times larger and occurring every single second for millions or billions of years on end. If the star doesn't have sufficient mass, this pressure will simply blow the star apart, and the reaction will halt. You need a large enough mass to continue to squeeze the core of the star to at least the critical pressure after you've already fought off the pressure the fusion is generating.
The "activation energy" comes from the gravitation it's self, and should actually be less than the energy needed to sustain the reaction. Therefore, it is impossible for a star to have the mass necessary to sustain the reaction without actually igniting.
thanks for clarification!
Although a sustained reaction could not occur, some hydrogen would fuse, would it not? Other than the hydrofen inside the bomb, I mean.
The heat of the comet hitting Jupiter was easily much more than any bomb we have made or would expect to make.
Jupiter's existing very slow rate of fusion could only be increased by making it more dense in a way that does not poison the fusion chain reaction. Since almost any dense material would poison a chain reaction, I'd say its almost impossible. A possibility might be to get a couple teratonnes of fissionable isotopes in there, so that the core was raised in temperature from what would essentially be an unmoderated gas-core fission reaction.
Wizwom did you know the last post in this thread before you was almost 2 years ago? :-p
... and, besides, I don't think PF should condone the unprovoked bombing of an alien planet! :-p
  • · Replies 19 ·
  • · Replies 23 ·
11K
  • · Replies 21 ·
  • · Replies 16 ·
