How can I design a reliable slewing bearing for a VAWT yaw control system?
The discussion focuses on designing a reliable slewing bearing for a vertical axis wind turbine (VAWT) yaw control system. Spherical bearings are identified as the appropriate choice for this application due to their ability to accommodate radial, axial, and tilting moments while compensating for misalignment. The selection of a specific bearing depends on the range of forces that need to be supported in each direction, making it crucial to assess the operational requirements of the yaw control system.
  • Understanding of slewing bearings and their applications
  • Knowledge of radial, axial, and tilting moments in mechanical systems
  • Familiarity with the design requirements of VAWT systems
  • Basic principles of bearing selection and force analysis
  • Research the specifications and applications of spherical bearings
  • Learn about force analysis in yaw control systems for VAWTs
  • Investigate design considerations for slewing bearings in wind turbine applications
  • Explore case studies on successful implementations of spherical bearings in similar systems
Mechanical engineers, wind turbine designers, and anyone involved in the development of control systems for renewable energy applications.
CloDawg
I'm building a yaw control system for one of the universitys VAWT turbines.
I need to design a slewing bearing which can reliably support radial, axial and tilting moments. I have absolutely no idea how to do this or even where to start.
Could you please give me some advice as to go about solving this problem
So-called 'spherical bearings' are used for this type of application. Finding a specific bearing to suit this really depends on the range of forces you need to support in each direction. Typically spherical bearings are used where some misalignment is unavoidable and needs to be compensated for / worked around, or where the geometry requires it, such as in the 'ball ends' of control rods, or the swash plates in helicopters.
  • · Replies 24 ·
  • · Replies 16 ·
  • · Replies 22 ·
