Create a Wireless AV Switch for Simple RCA Audio Input Toggling
The discussion focuses on creating a wireless audio switch for toggling between two RCA audio inputs using the CD4066 analog switch. The user seeks a remote solution, preferring control via a smartphone app, which necessitates programming skills. The CD4066 provides four analog switches that operate based on a digital control signal, allowing for low-resistance paths for audio signals. This setup is aimed at being cost-effective while enabling remote audio input selection.
  • Understanding of analog switches, specifically the CD4066 model.
  • Basic knowledge of digital control signals and their application in analog circuits.
  • Familiarity with mobile app development for remote control functionality.
  • Knowledge of wireless communication protocols such as Bluetooth or WiFi.
  • Research the CD4066 analog switch specifications and applications.
  • Learn about mobile app development frameworks suitable for remote control, such as React Native or Flutter.
  • Explore Bluetooth and WiFi communication protocols for audio applications.
  • Investigate circuit design for integrating the CD4066 with a microcontroller for remote operation.
Electronics hobbyists, audio engineers, and developers interested in creating remote-controlled audio switching solutions.
Chunkysalsa
I'm trying to figure out the easiest way to make a simple switch that toggles between two different RCA audio inputs.
I can do it easily with a physical switch but how can I do it remotely. Either from a remote or from my cell phone (so either IR, Bluetooth, or WiFi). I'd prefer using my phone but I guess that would force me to write a simple little personal app. A good programming exercise I suppose.
I'm trying to keep things as cheap as possible. Thank you
One way is to use an analog switch.
The CD4066 is one of these. It contains 4 switches.
Each one provides a low resistance path between two pins, depending on whether a third pin has 5 volts or zero volts on it.
So, the control is digital, but the switch allows analog signals, like music, to pass.
  • · Replies 17 ·
  • · Replies 35 ·
