Wireless energy transmission via sound waves
The discussion explores the concept of using ultrasonic or infrasonic sound waves to vibrate a magnet, potentially generating electrical current. It highlights the principle of resonance, where one object vibrating at another's natural frequency can transfer energy. A participant points out that microphones operate on a similar principle but are known for their inefficiency. Another contributor references a vibration-powered generator linked to a furnace as an example of energy conversion. The conversation emphasizes the need for calculations to assess efficiency if the sound wave concept is viable.
Nickj800
Today in my high school physics class, we were shown that object 1 vibrating at object 2's natural frequency, can cause object 2 to vibrate. So since you are transferring energy, i was wondering if its possible to use ultrasonic or infrasonic sound waves to vibrate a magnet, causing a current to flow through a wire. Does anyone know if this has been done? Is there a way i can calculate how efficient it would be? Assuming the concept works.
p.s. The magnet idea is the first thing I thought of, but if you can think of any other ways to convert the energy into electrical energy, feel free to let me know :D.
Welcome to PF.
You are describing a microphone! They are extremely inefficient.
oh ok, never knew how a microphone worked.
thanks for the reply.
I am subscribed to a few magazines, but I saw something like this.
http://en.wikipedia.org/wiki/Vibration-powered_generator
I believe it was hooked up to a furnace as another way to get power from inconsistent flames but I don't remember all the details.
For simple comparison, I think the same thought process can be followed as a block slides down a hill, - for block down hill, simple starting PE of mgh to final max KE 0.5mv^2 - comparing PE1 to max KE2 would result in finding the work friction did through the process. efficiency is just 100*KE2/PE1. If a mousetrap car travels along a flat surface, a starting PE of 0.5 k th^2 can be measured and maximum velocity of the car can also be measured. If energy efficiency is defined by...
  • · Replies 31 ·
  • · Replies 49 ·
