Wiring three LEDs to light one at a time without a microcontroller
  • Thread starter Thread starter Hassan Raafat
    diodes led
18 replies · 3K views
Hassan Raafat
Is there is a way to connect three LEDs so that there are three cases where one LED only is working in every case of the three without using micro controller ?
What are the 3 cases?
Really I don't know what they are but I wonder it because there are two-color where are green is lighted in forward and red in reverse like that , so can I make the same for three LEDs ?
I'm still not sure exactly what you are trying to accomplish.
Do you want to have 3 multicoloured LED's each displaying a different colour??
Not exactly , I want to have three LEDs in one circuit so each time I have a specific condition , there is only one LED working
What are the conditions then? Hard to tell you what you need to do if we don't know exactly what it is you are trying to accomplish :)
Not for confusing you that is an idea not a real question in the picture up I have one LED working in the forward and the other is working in reverse bias where the first became off , now the question is Can I make a circuit which have three LEDs where there is one LED working in every case , But also I can't tell you the condition because I really don't know it .
Tri-color LEDs usually have 4 leads. One common (cathode), and 3 separate anode pins:
http://gcdn.indiabizclub.com/uploads05/30/H/5mm-Tri-color104258895.jpg
Please can you tell me how that works ?
Your circuit showing two LEDs is incomplete. Something has to make the +V node to go both +ve and -ve with respect to the Earth node. That implies +ve and -ve supply voltages and a switch of some sort.
It's very easy to do what you want if you don't have any constraints. My house has at least 20 light bulbs and I can turn one (any one) on at a time without a microprocessor...but that's because I have 20 light switches.
We can't really answer your question without knowing the constraints. Can you use three switches? One multi position rotary switch?
Thanks very much CWatters , So what you said I Can control these switches and control when to turn of the leds on , right :)
CWatters said:
Is three LEDs enough?...
Here is a chip that can be configured to turn on 1 of 10 LEDs depending on the voltage on a single input.
http://www.ti.com/lit/ds/symlink/lm3914.pdf
Can be used in "dot" or "bar graph" modes.
Thanks a lot CWatters , I'll read it , you helped me a lot , Thanks again :)
If you were to power this two-in-one with AC you could have both LEDs glowing 'simultaneously' to give (I'm guessing) a third color: violet.
EDIT: oops, seems that the third color for a R-G led could be yellowish orange, click on customer comments in this link: http://www.allelectronics.com/make-a-store/item/led-6/bi-color-led-2-legs/1.html
That's great :) , big thanks NascentOxygen :smile:
Great Video , CWatters , Really thnak you for your effort :smile:
