What Is the Electric Force Between Two Charged Plates?
The discussion focuses on calculating the electric force between two charged plates and the electric field in a given potential region. The electric force on a positive charge of 3.2 x 10-19 C between two parallel plates 5.0 cm apart with a potential difference of 75 V is determined using the formula F = (V*q)/d, yielding a force of 9.6 x 10-16 N. The z-component of the electric field derived from the potential function V(x,y,z) = 10 (V/m)x + 20 (V/m)y + 30 (V/m)z is confirmed to be -30 V/m, indicating that the electric field is uniform. Additionally, the work done by the electric field when 5.0 C of charge moves through a potential difference of 12 V is calculated as 60 J, with the conclusion that external work must counteract the electric field to maintain constant speed.
  • Understanding of electric fields and forces
  • Familiarity with the relationship between electric potential and electric field
  • Knowledge of basic calculus for partial derivatives
  • Ability to apply the work-energy principle in electric contexts
  • Study the derivation of electric field equations from electric potential
  • Learn about the concept of electric field lines and their properties
  • Explore the implications of constant speed motion in electric fields
  • Investigate the relationship between electric potential energy and work done
Students studying electromagnetism, physics educators, and anyone preparing for exams involving electric forces and fields.
Soaring Crane
Two parallel metal plates 5.0 cm apart have a potential difference between them of 75 V. The electric force on a positive charge of 3.2*10^-19 C at a point midway between the plates is approximately
a. 1.6*10^-18 N
b. 2.4*10^-17 -
c. 4.8*10^-18
d. 4.8*10^-16
e. 9.6*10^-17
V = E*d = (F/q)*d
F = (V*q)/d = (75 V)*(3.2*10-19 C)/(0.025 m) = 9.6*10^-16 N?
But this does not match any of the choices . . .except for being close to E.
Is my arithmetic wrong or is the question in need of editing?
The electric potential in a region of space is given by V(x,y,z)=10 (V/m)x +20 V/m(y) + 30(V/m)z. The z-component of the electric field in this region is
a. (-30 V/m)*k vector
b. (-10 V/m)*i vector
c. (20 V/m)*j vector
d. (-20 V/m)*j vector
e. (30 V/m)*k vector
See below.
Is the answer e. (30 V/m)*k vector since V/m = N/C (both units for electric field)?
When 5.0 C of charge moves at constant speed along a path between two points differing in potential by 12 V, the amount of work done by the electric field is
a.2.4 J
b. 0.42 J
c. 5.0 J
d. 12 J
e. 60 J
U = q*V ?? (correct formula?)
U = 5.0 C*12V = 60 J?
Thanks.
For the first one, I got 4.8 * 10^-16...the electric field is constant so the force will be constant no matter what point you choose in the field...looks like you chose the midway point, well the potential is not constant throughout the field so if you choose the midway point, you have to divide the potential by half as well.
I don't know about 2 and 3...
Again, that cannot be electric potential because potential is not a vector.
Concerning the 1st question, E=V/d since electric field between parallel plates is uniform. Then, force =qE. Thus answer is d.
The third question however is trickier! (although your answer is correct)
You see if the field alone were acting on it then the motion would be accelerated. But since charge is moving at uniform velocity then we have to assume that work has to be done by an external agency to keep the charge in the same speed. Thus the work has to be negative. Atleast that is what I conclude!
So W= -60 J because external force is directed opposite to field.
So could you please chack again whether the constant speed part is there!
For the last one, the constant speed part is included.
For the second part, based on the partial derivative definition E = -dV/dx, the electric field of the z-component will be -30 V/m*vector k?
Does the x, y and z in the equation refer to the axes in free space?!
I don't understand?
Are x,y and z unit vectors or just scalars in the 3D equation?!
V is just a function of x, y, and z in the problem, I think.
E_z = -dV/dz?
Then the answer would be given by differentiating the equation with respect to z and put a negative sign, i.e: E = -dV/dz .
Thus, answer is -30 V/m
  • · Replies 16 ·
