What is the force of kinetic friction acting on the skier in this scenario?
The discussion centers on calculating the kinetic frictional force acting on a 63-kg skier coasting up a 25° hill. The skier's initial speed is 6.6 m/s, and after traveling 1.9 m, the speed decreases to 4.4 m/s. The work done by kinetic friction was calculated as -267.146 J, leading to a frictional force of approximately 140.603 N when considering the correct angle for work calculation. The consensus is that the angle for the force should be 180° to accurately reflect the direction of friction against displacement.
  • Understanding of Newton's laws of motion
  • Familiarity with work-energy principles
  • Knowledge of vector resolution and dot products
  • Basic trigonometry, particularly in relation to angles and forces
  • Study the work-energy theorem in classical mechanics
  • Learn about vector resolution techniques in physics
  • Explore the concept of friction and its coefficients in different materials
  • Investigate the application of dot products in physics problems
This discussion is beneficial for physics students, educators, and anyone interested in understanding the dynamics of motion and forces, particularly in scenarios involving friction and inclined planes.
chmilne
I believe I have part A correct, but I have having some trouble with part B.
A 63-kg skier coasts up a snow-covered hill that makes an angle of 25° with the horizontal. The initial speed of the skier is 6.6 m/s. After coasting a distance of 1.9 m up the slope, the speed of the skier is 4.4 m/s. (a) Find the work done by the kinetic frictional force that acts on the skis. (b) What is the magnitude of the kinetic frictional force?
Part A
Part A
W_{nc}=(1/2mv_f^2)-(1/2mv_o^2) + (mgh_f) – (mgh_o)
W_{nc}= ((½ (63kg) (4.4m/s)^2) – (½ (63kg) (6.6 m/s)^2)) + ((63kg) (9.8m/s^2)(.802m) + (63kg)(9.8 m/s^2) (0))
W_{nc}= ((½ (63kg) (19.36 m^2/s^2)) – ((½ (63kg) (43.56m^2/s^2)) + (495.154 J) + 0
W_{nc}= 609.84J - 1372.14J + 495.154J
W_{nc}= -267.146J
Part B
Because the skier is going up hill, I would think that the angle for the formula W = (Fcos\theta)s is 155^o. So,
-267.146J = (Fcos(155))1.9m
-140.60316 = Fcos(155)
-140.60316 = -.9063078F
155.136N = F
This cannot be true because the professor has mentioned that, to 1 significant digit, the answer is 100N. I'm to find the anser to 2 SF, so, 155.136 would not be true.
Thanks,
Tony
The force of friction acts along the full displacemnt of 1.9 m, not a componant of this.
I get it. The angle should be 180, not 155 because the force run along the x-axis and using 155 would not be the entire x axis. This mean that the answer to part b is 140.603N. Correct?
I worked this problem and obtained 155N. So I assumed that the problem
means a 1.9m "vertical" rise and obtained the desired answer of 100N.
The problem states the skier is on a hill that is 25 degrees from the horizontal and that the displacement is 1.9m. So, the 1.9m could not be veritcle, it would also be 25 degrees from the horizontal. However, to answer part b, you need to calculate for 180 degrees, not 155 degrees.
Correct (but please, drop those insig digits! It's fingernails on the chalkboard to me!), I get 140 N .
Easier way to think of it; the force vector and the displacement vector are parallel , therefore no vector resolution is required.
A simple work and energy Q
I_i
I tried to draw the q but could not succed:))
Another way to think of it is to remember what a dot product is. chmilne, you start off with the formula W = F\cos{\theta}s, but a more general form is W = \vec{F}\cdot \Delta \vec{s}.
If you think of it in terms of dot products and vector resolution, then you can mentally and graphically verify that you're selecting the correct angle.
(An even more general form would be W = \int_{x_1}^{x_2} \vec{F} \,d\vec{x}, but that's hardly needed at elementary mechanics-level physics.)
