Work done by man pushing a crate up a ramp, includin done on
The discussion focuses on calculating the work done by an 85 kg man pushing a crate 4.00 m up a ramp inclined at 20 degrees. The man exerts a force of 500 N parallel to the ramp while moving at a constant speed. The work done on the crate is calculated using the equation W = F d cos(θ), resulting in 2000 J when θ is set to 0 degrees, as the force is applied in the same direction as the motion. The conversation also addresses the need to consider the forces acting on the man to determine the work done on his body.
  • Understanding of Newton's laws of motion
  • Familiarity with the work-energy theorem
  • Knowledge of vector components in physics
  • Proficiency in using trigonometric functions in calculations
  • Study the work-energy theorem in detail
  • Learn how to resolve forces into x and y components
  • Explore the implications of constant speed on force calculations
  • Investigate the effects of different angles of incline on work done
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of work calculations involving inclined planes.
SDTK
Calculate work done by an 85 kg man who pushes a crate 4.00 m up a ramp at an angle 20 degrees to horizontal.
He exerts a force of 500N on the crate parallel to the ramp, and moves at constant speed.
Include the work that he does on the crate and on his body to get up the ramp.
I need to find the Force with which he moves himself up the ramp in other to determine the work he does on his body.
I set up x and y components of the forces acting on the man to find the Force, and have come up with a negative magnitude.
--Is setting the x and y components for the forces acting on the man the appropriate strategy?
-- do I include the force of the crate on the man?
file attached
Suppose for a moment that it was only the man on the ramp (no crate). What work is required to move him 4 meters up the ramp? What force is he working against? Hint: work-energy theorem.
thank you
In your attached work you had this portion:
In the indicated equation what does the angle θ represent? Why did you set θ = 20° in the next line?
Should angle θ be "0"
because the force applied is parallel to the angle of the ramp?
W =F d cos(θ) = 500 kg 4 m cos(0) = 2000 J , work done on crate
Yes. The force is applied in the same direction as the motion.
  • · Replies 56 ·
  • · Replies 23 ·
9K
