Work done by non-conservative force while particle moves in circle
  • Thread starter Ebby
    Force Work
25 replies · 4K views · last reply
Ebby
Show that the force is non-conservative
F = kx
x^2 + y^2 = R^2
Printed textbook problem 3: a particle moves on the circle x^2 + y^2 = R^2 in the x-y plane, acted on by force components Fx = -y and Fy = x, asking to show the force is not conservative.
I have to show that the force is non-conservative, i.e. that work done for the round trip ##\neq 0##.
Rearranging the circle equation, I can say that:$$x = \sqrt {R^2 - y^2}$$$$y = \sqrt {R^2 - x^2}$$
Then I have:$$F_x = -\sqrt {R^2 - x^2}$$$$F_y = \sqrt {R^2 - y^2}$$
Now, as I understand it, I must integrate these forces thus:
$$W_x = \int_a^b -\sqrt {R^2 - x^2} \, dx$$$$W_y = \int_a^b \sqrt {R^2 - y^2} \, dy$$
So now I'm not sure what my limits of integration ##a## and ##b## should be. Taking the expression for ##W_x##, for example, I imagine the ##x## coordinate starting at a value of ##R##, going to ##-R## and then back to ##R## again. But this will just mean ##W_x## is zero, which is not what I want.
Should I change the integration to be over an angle rather than over a displacement to reflect the fact that the path is circular, and use limits of ##0## and ##2\pi##?
I think I see. I need to take into account the sign ambiguity. So I can stay with using Cartesian coordinates:$$W_x = \int_R^{-R} -+ \sqrt {R^2 - x^2} \, dx + \int_{-R}^R -- \sqrt {R^2 - x^2} \, dx$$
$$= \int_R^{-R} - \sqrt {R^2 - x^2} \, dx + \int_R^{-R} - \sqrt {R^2 - x^2} \, dx$$
$$= -2 \int_R^{-R} \sqrt {R^2 - x^2} \, dx$$
$$W_y = \int_R^{-R} + \sqrt {R^2 - y^2} \, dy + \int_{-R}^R - \sqrt {R^2 - y^2} \, dy$$
$$= \int_R^{-R} + \sqrt {R^2 - y^2} \, dy + \int_R^{-R} + \sqrt {R^2 - y^2} \, dy$$
$$= 2 \int_R^{-R} \sqrt {R^2 - y^2} \, dy$$
$$W_{total} = W_x + W_y = -2 \int_R^{-R} \sqrt {R^2 - x^2} \, dx + 2 \int_R^{-R} \sqrt {R^2 - y^2} \, dy$$
$$\pi R^2 - \pi R^2 = 0$$
Oh dear.
OK, I shall try with polar coordinates, if I can work that out. But I did spot that I'm wrong about ##Wy##. I believe that the Cartesian method will yield ##Wy = 0##, and so ##W_{total} = \pi R^2## by this method.
What is the force vector in terms of unit vectors? What is unit vector in the direction of the tangent to the circular path?
Why do any integrations at all? You are not asked for a quantitative result. You are asked for a qualitative result. Use a little geometric intuition.
First, pick a direction for the path. Clockwise or counterclockwise.
Can you decide whether the ##x## component of the force does positive or negative work over the portion of the path in the first and second quadrants? Can you decide whether the ##x## component of the force does positive or negative work over the portion of the path in the third and fourth quadrants? Can you make the same decisions for the ##y## component in the second and third quadrants and then again in the fourth and first quadrants?
For information (since no one has yet mentioned it) the problem can be solved easily/quickly by showing that ##curl(\vec F) \ne 0##. A specific path is not need. But presumably you haven’t yet met ##curl##.
It won't!
If you follow @jbriggs444 44 suggestions and @Chestermiller ’s hint about the dire tion of the tangent vector, you can show that (going round clockwise) the direction of ##\vec F## is always the same as the direction of motion. That would be sufficient 'proof' IMO.
Also, that may help you resolve any sign-error(s) in your Post #4 working if you wanted.
I think I get it now:
$$F_r = \sqrt {{F_x}^2 + {F_y}^2} = \sqrt {{(-y)}^2 + x^2}$$where:$$x = R\cos(\theta),\, y = R\sin(\theta)$$
So we can form the integral:$$W_{total} = R^2 \int_0^{2 \pi} \sqrt {\sin^2(\theta) + \cos^2(\theta) \, d\theta}$$
$$= 2 \pi R^2$$And it was that simple? Is that right?
I don't follow this. You need to look at the unit vectors in polar coordinates:
$$\hat r = (\cos \theta) \hat x + (\sin \theta) \hat y$$$$\hat \theta = (-\sin \theta) \hat x + (\cos \theta) \hat y$$And express ##\vec F## in terms of these unit vectors.
I made a sketch since I'm confused about the unit vectors. Where is ##\hat \theta##?
Handwritten sketch of a circle with x and y axes, a radius at angle theta, and a unit vector labeled theta-hat drawn tangent to the circle; equations read w = integral of F dot dr where dr = r dtheta-hat, and theta-hat = (-sin theta) x-hat + cos theta y-hat.
What you've drawn there is ##\hat \theta##. Not ##\hat r##, which is in the same direction as the radial position vector.
And there's no confusion here about ##\hat r## being the tangent unit vector (which is what I thought it was) and R the radius?
##\vec r## is the position vector, r is its magnitude and ##\hat r## is the radial unit vector. ##\vec r=r\hat r##.
OK, I'll think about that. I think I've gotten way confused here because I had something like the following sketch in mind (which is obviously wrong, but I include it merely to elucidate my state of confusion):
Handwritten sketch of a circle of radius R centred at the origin with x and y axes, showing an arc element dr = R dθ and a tangent unit vector F-hat = (-sin θ x-hat + cos θ y-hat), followed by the line integral of F dr over a full circle equalling 2πR².
To write ##\hat r=\hat r_x+\hat r_y##, those last two terms must mean "the x component of the unit vector ##\hat r##", etc. So that should turn into ##\cos(\theta)\hat x+\sin(\theta)\hat y##. What you have written would have magnitude r instead of magnitude 1 and is at a right angle to ##\vec r##.
I drew it out using @PeroK's nomenclature. I still have questions:
Handwritten diagram of a circle of radius R centred at the origin with x and y axes, a point on the circle at angle theta, and unit vectors r-hat and theta-hat, followed by vector expressions for F and the decomposition F = theta-hat + r-hat and the work integral W = closed integral F dot dR.
I previously read your ##F_x## etc. as ##\hat r_x##, etc. Please try to use LaTeX.
The second line is wrong. ##\hat r=\cos(\theta)\hat x+\sin(\theta)\hat y##; ##\vec r=r\hat r=r\cos(\theta)\hat x+r\sin(\theta)\hat y##.
##\hat\theta## is neither an angle nor a displacement. It is the unit vector in the anticlockwise tangential direction.
See post number #11 for the definition of the unit vectors.
Ah that was careless. I did not mean to write that.
Yes I understand the unit vectors now.
Decomposing, this means that ##\vec F = R \hat \theta + 0 \hat r##.
And now to form the work integral. I imagine it's the integral over ##d\theta## of ##\vec F## dotted with something? Perhaps it's:$$\int_0^{2\pi} \vec F \cdot R \hat \theta \, d \theta$$
I'd appreciate completing this!
EDIT:
Well, I'll carry on with it assuming:$$W = \int_0^{2\pi} \vec F \cdot R \hat \theta \, d \theta$$
$$= R^2 \int_0^{2\pi} \, d \theta$$
$$= 2 \pi R^2$$
Assume that the force is conservative. By definition this implies that there exists a function ##V=V(x,y)## such that
$$F_x=-\frac{\partial V}{\partial x},\quad F_y=-\frac{\partial V}{\partial y}.$$
From the identity
$$\frac{\partial^2 V}{\partial x\partial y}=\frac{\partial^2 V}{\partial y\partial x}$$
it follows that
$$\frac{\partial F_y}{\partial x}=\frac{\partial F_x}{\partial y}.$$ This is the only relation to check!
From the identity
it follows that
Is that sufficient in the case where the particle is constrained? If we had a non-conservative force that vanished on the given circle, say, then would that not be conservative on the restricted domain of the particle?
This is a good question. Surely not. And that is why I think that the statement of the problem is not good. Two interpretations are possible. The circle may be treated as a constraint, or it may be merely a curve that is suggested for checking that the work done is not zero. These are different statements.
My answer is for the second case. If the circle is a constraint, then one should calculate a generalized force ##Q=Q(\theta)##. This force is locally conservative, but globally not. The corresponding potential is a multivalued function on the circle.
In the general case, we have only a local result: if a differential form ##Q_idq^i## is closed, then it is locally exact.
UPD It is possible that the force in ##\mathbb{R}^2## is not conservative but the corresponding generalized force on the circle is conservative.
