Is the Work Done by a Variable Force Non-Conservative?
The discussion revolves around calculating the work done by a variable force using the equations of motion defined in terms of parameters like time and angle. Participants clarify the expressions for the position vector and force, emphasizing the importance of using a dummy variable for integration. There is confusion regarding the correct parameterization of the equations, particularly the role of theta in relation to the path described by the ellipse. The conversation also touches on the necessity of correctly substituting variables and integrating over the appropriate limits. Ultimately, the participants aim to derive the work done by the force while ensuring the mathematical expressions are correctly formatted and interpreted.
  • #31
That's worrying. If you do try that be careful not to use θ for both purposes. Either take the polar coordinates to be (r,φ) or change the given parameter from θ to t, say. I say it is worrying because it makes me wonder whether your teacher has blundered.
MatinSAR said:
Thank you but what do you mean by this ?! I didn't understand.
This one should be Theta ...
No, neither of them matches the given theta. The one you circled would give ##x=r\cos(\theta), y=r\sin(\theta), y/x=\tan(\theta)##. But you are given ##y/x= \frac 12\cot(\theta)##.
If you draw a line from the origin to a point half way along the horizontal dashed blue line, the angle between that and the y-axis is the given theta.
  • #32
Chestermiller said:
If you are going from A to C, the limits of integration are from ##\theta=0## to ##\theta = \frac{\pi}{2}##. From the equations for F and dr that I gave in post #16, what is the equation for F dotted with dr?
Is it true ?!
kuruman said:
Forget ##\theta## as a variable. Try this. You have $$x=2a\sin\theta~;~~2y=2a\cos\theta.$$It follows that $$x^2+4y^2=4a^2 \implies xdx+4ydy=0 \implies dx=-\frac{4y}{x}dy$$ Now $$\mathbf{F}\cdot d\mathbf{r}=(x^2y~\mathbf{\hat x}+xy^2~\mathbf{\hat y})\cdot(dx~\mathbf{\hat x}+dy~\mathbf{\hat y})
=x^2ydx+xy^2dy.$$ Substitute the expression for ##dx## and integrate over ##y##.
Can I send a picture of my work ?! The final answer is unusual ...
  • #33
Thanks ...
Is it true ?!
  • #34
LaTeX is preferable, but if your work is too involved, you can post a picture as long as it is clearly legible and right side up. Use the "Attach files" link, lower left.
  • #35
MatinSAR said:
Is it true ?!
I don't get the factor as 6. Did you handle the signs correctly? The rest looks fine.
  • #36
Thank you ... I have done it with a math editor.
  • #37
What about Theta ?! Did I specify theta correctly?
I get the factor 6 again ! Let me send a picture ...
  • #38
  • #39
I'm getting what you are getting.
$$ \int 3 x y^2 dy = \int 3 \cdot y^2 \cdot 2 \sqrt{a^2 - y^2} dy $$
Let:
##\frac{y}{a} = \sin \beta##
## \frac{ \sqrt{a^2 - y^2} }{a} = \cos \beta##
It follows that
$$ y^2 = a^2 \sin^2 \beta$$
$$\sqrt{a^2 - y^2} = a \cos \beta$$
$$ dy = a \cos \beta d \beta$$
$$ \implies \int 3 x y^2 dy = 6 a^4 \int \sin^2 \beta \cos^2 \beta d \beta $$
  • #40
I also get a factor of 6, although I would never have done the math the way that he did it>
  • #41
Was it true ?!
What was wrong with the way I have done the math :rolleyes:
Can you please tell me what is your final answer ?!
  • #42
MatinSAR said:
Was it true ?!
I didn't do the integral!
  • #43
Post your work, it will get checked by someone...
  • #44
Yes, my mistake… I should have waited until I had the time to check properly.
  • #45
  • #46
MatinSAR said:
It is a line integral, not a double integral, so you must arrange that there is only one variable in the integrand. If you want to do it as an integral wrt y then you must first replace all the occurrences of x with what x is as a function of y.
But really, the parametric approach using theta is much easier.
Likes MatinSAR and erobz
  • #47
  • #48
So my answer is wrong , isn't it ?!
Thank you ... I will try to do it using parametric approach and I will send a picture of the work ...
erobz said:
Show the work. Explain how you get the last result?
Thank you ... I will try to do it using parametrich approach and I will send a picture of the work ...
  • #49
I'm confused. Isn’t that what you already did in post #32? Except that you did not perform the integral.
  • #50
The integration is very simple. It just involves the use of trigonometric identities.$$(\sin{\theta}\cos{\theta})^2=\frac{\sin^2{2\theta}}{4}=\frac{1-\cos{4\theta}}{8}$$
  • #51
MatinSAR said:
Hi @MatinSAR. Can I point out a fundamental mistake you are making? I don’t think anyone has mentioned it yet (apologies if they already have).
The final expression for W can not contain x or y (or θ). These are variables which change as you move along the path. They must disappear when the definite integral is evaluated.
You made the same mistake in your Post #1 solution, where your final expression for W contained x and y.
The expression for W can contains only given constants (here only the 'a') and pure numbers like 5, π and √2 (just picking random values as examples).
For example, if you determine the formula for the circumference of a circle, x²+y²=a², it wouldn’t make sense to have x and/or y in the final formula.
  • #52
Yes. It was unfinished.
Thank you.
Thank you ... I didn't know about this.
Likes Steve4Physics
  • #53
I hope it's finally true ...
The force is conserative so If I choose another path the final answer shouldn't change, Is it true ?!
  • #54
Is it? What do you get if you integrate from 0 to 2π?
I agree with your answer.
  • #55
haruspex said:
Is it?
It was mentioned in question.
Thank you.
  • #56
haruspex said:
Steve4Physics said:
Chestermiller said:
erobz said:
kuruman said:
Mister T said:
I hope I haven't forgotten anyone.
Thank you for your help and time.
  • #57
Try the path along the axes. Isn't F always zero there?
  • #58
No it's not.
  • #59
MatinSAR said:
No it's not.
Oh yes it is! (If you familiar with British pantomime.)
Can I expand on what @haruspex said in Post #57?
Referring to the Post #21 diagram, suppose you take the following route:
- from A(0,a), move along the y-axis to the origin (0,0);
- from the origin (0,0) move along the x-axis to C(2a,0).
##\vec F = x^2y~\hat i + xy^2 \hat~j##
While moving along the y-axis (x=0); both components of ##\vec F## are zero.
Similarly while moving along the x-axis.
The total work done along this path is therefore zero. This is different to your calculated value for the original route from A to C.
So you can see (without doing any maths) that the force is not conservative.
  • #60
Great !
So it's not conserative ...
Thank you.
  • · Replies 19 ·
