Work done in Adiabatic, Quasistatic-compression
4 replies · 4K views · last reply
Trenthan
i have to find the W done in an Adiabatic, Quasistatic compression and I am not having much luck.
Ive calculated it using (delta)U = Q + W, since Q = 0, hence W = change in internal energy
However i want to calculate it using W = -(delta)P*V
My working is attached, my text just says to use W = delta(U), but i know there is a way to do it via pressure and volume, I am just not sure where to go from where I am at.
Attempt is attached
Has to be in terms of TA, n (moles) and R
Cheers Trent
I assume we are talking about perfect gases so that indeed [tex]p V^\gamma = const[/tex] for a quasistatic, adiabatic process :p
[tex] <br /> -\int_{V_C}^{V_A} p dV = <br /> <br /> \left\{ p V^\gamma = const \right\}= <br /> <br /> -\int_{V_C}^{V_A} const \cdot \frac{dV}{V^\gamma} <br /> [/tex]
Determine [tex]const[/tex] from the conditions at A.
I got it finally thanks heeps but i got it using conditions at "c" our starting point, (PCVCgamma = PVgamma, rearranged for P = and solved from ther) not "A", I am assuming u meant "c"?
Oopsie, yes I meant "C" , it's the point where you know P and V to start with. Sorry, I always think that A comes before C when I'm not thinking :P:P
Though now that you said, . . . it's also true that you know P and V of point A too, so you could use any:) of course, they've given you two points such that :
[tex] <br /> <br /> p V^\gamma = const1<br /> <br /> [/tex]
and
[tex] <br /> <br /> T V^{\gamma-1}= const2<br /> <br /> [/tex]
with
[tex] <br /> <br /> \gamma=5/2<br /> <br /> [/tex]
because if this was not so it wouldn't be a reversible, adiabatic process.
thanks and good point, just trierd it the other way and it works :)
