Work Energy Method for Rotational Motion
6 replies · 3K views
freshbox
Reference to part C of the question, I would like to ask for work done U1to2, how come linear motion is not included? I thought both linear and rotational exist since the parcel "move downwards" (linear) and the wheel is rotating (rotational)
Thanks...
Part C asks for the work on the drum. Why worry about the falling mass? They want you to calculate the work directly.
Oh you you are right, sorry didn't read the question clearly :redface:
Just to confirm if they ask me to find the work of frictional force, Fr on the drum and falling mass between position 1 and 2 both linear and rotational will exist correct?
With regards to part c again, To find Torque τ, I know that τ=Tension X Radius so comparing diagram 1 (left) against diagram 2 (right) which i drew a red line to indicate Tension.
How come in the Work Done equation it uses the Frictional Force X Radius and not Tension X radius?Thanks...
If the mass falls and the drum rotates, sure there will be both linear and rotational motion and kinetic energy.
Realize that those diagrams refer to different problems.
Part c asks you for the work done by the frictional force, not the tension.
My lecturer told me that τ = tension X radius this concept on the chapter of Kinetics of rotational motion diagram 1 (left)
But he never mention this on the chapter of Work Energy method for rotational motion diagram 2 (right). However, I thought they have the same meaning since both are τ in both formula.
So are you trying to say U1-2=τ X δ
The τ in the equation is actually the frictional force?
And can I say that Torque in τ=Iα and U1-2=τ X δ are actually both different thing?
You can calculate the torque due to any force. If the force is tangential to the wheel, then τ = Force X radius. Depending upon the particular problem, that force can be a tension force or a friction force.
Right. The torque in that equation is due to the friction force. You are asked to find the work done by the friction force, so you'd use the torque created by that force to calculate the work.
Yes, those are different things. The first equation is just Newton's 2nd law as applied to rotation; the torque in that formula should really be the net torque: Ʃτ=Iα.
The second equation is an expression for the work done by some torque. In your problem, it's the work done by the frictional force, which is non-conservative work that will decrease the total mechanical energy of the system.
Thank you sir for the clarification.
