Understanding Work and Energy Transfer: The Relationship and Implications
  • Context: Undergrad
  • Thread starter Thread starter urtalkinstupid
    Work
The discussion revolves around the concepts of work and energy transfer, particularly in the context of physical systems and gravitational forces. Participants explore scenarios involving a man pushing objects and the forces acting on the moon in its orbit around the Earth, questioning the implications of work done and energy output in these contexts.
  • Some participants define work as the transfer of energy through the application of force over a distance, questioning whether energy output occurs when no movement is achieved.
  • One scenario describes a man applying force to move an object, concluding that work is done when movement occurs, but raises the question of energy output when no movement happens.
  • Another scenario discusses the gravitational force between the Earth and the moon, suggesting that while a force exists, it does not result in work being done, leading to confusion about energy sources.
  • Some participants argue that the analogy of a man pushing an object is flawed, emphasizing the distinction between energy input (calories burned) and work output (movement of the object).
  • Others assert that gravity does perform work on orbiting bodies, providing examples of energy changes in satellites during their orbits.
  • There are claims that the work equation may not adequately describe the energy dynamics in gravitational systems, with some participants expressing skepticism about the conservation of energy in these contexts.
  • Discussions also touch on the idea that forces arise from attraction without an initial energy input, raising questions about the nature of energy in gravitational interactions.
Participants express multiple competing views regarding the relationship between work, energy output, and gravitational forces. There is no consensus on whether the work equation accurately represents these dynamics, and the discussion remains unresolved.
Some participants highlight limitations in understanding the work equation and its application to gravitational forces, suggesting that assumptions about energy input and output may need further exploration.
  • #151
JoeWade said:
you can and will have such a force if there is no change in distance
Are you serious? I think that is known. I've already said that there is a force if distance isn't changing. There is a force; no work is done.
JoeWade said:
listen, if you have a better explanation for these forces, do tell
i suppose you're going to say that neutrinos are pushing the magnets together...
Actually, I'm trying to get you people to explain this stuff better to me.
You people previously told me there is no need for an energy source to apply a force to something, but through substitution of two Standard-Model equations, I and the equations say otherwise. So, in conclusion, in order for a force to be applied in a system or to an object, there must be an energy source for that force to take place.
  • #152
Let me put this as simply as I possibly can:
FORCE DOES NOT EQUAL ENERGY. Yes, I KNOW you know that, but you're obviusly confused over it.
Consider the magnet-on-fridge argument. What's keeping it there? The force of friction of course! This means that the magnet is transferring the force of gravity into the fridge, which is pushing on the ground. Since the fridge is pushing on the ground the ground is pushing back on the fridge. Next to no movement happens (I'm sure at the sub-atomic level the magnet is doing some kind of compeltely ignorable movement), energy is conserved, net force is 0, and everyone is happy.
But the point is: If net force is 0 in the magnet analogy, no energy will be produced. Since the force of friction is equal and opposite to the force of gravity, net force is 0. Thus energy change is 0.
Oh, by the way, if a magnet can't stay on a fridge without using energy, then all objects would need constant input of energy to stay together.
WAIT! I think I see where you're being confused. You think that energy can only be used once or twice! You're stuck on the idea of a car driving up a fridge, slowly losing gasoling, the fall is coming... But you need to realize that once taken, energy doesn't disappear, it continues to do it's "job" forever.
The reason a car loses gasoline is that it's CONVERTING energy. It's making movement out of atomic bonds.
  • #153
If you're not interested in science, why are you here?
urtalkinstupid said:
At least their babbling is interesting. Books and journals written by scientists are insipid. The same thing everytime you read them. First, they give you a jist of what they are explaining (abstract I guess). Then, they go into experimental evidence. Then, you have observations. Finally, you have a linking between observations and experiments. BORING!
urtalkinstupid, I've read many of your posts, both in this thread and others. I have slowly formed the opinion that you are posting to the wrong forum; it seems you have a great disdain for how science is done, and no real interest in either showing that it's an inappropriate approach to learning about the universe (in which case I expect that you'd be a frequent contributor to the Philosophy of Science and Mathematics section), or debating its weaknesses within the framework of science itself.
If my observation is at least partly correct, why do you post to PF at all?
  • #154
Yes, you are right; I do know that force does not equal energy, but force is related to energy. In order for a force to be applied, there is a needed energy source.
Has my question been answered? No.
Since when did you refer to gravity making things push? I think it should be the ground is pulling the fridge, and the fridge is pulling the ground. Yea, doesn't make much sense putting it in the pull form. So, you are saying that magnets are conductors for gravitational fields? One problem I see in this. If gravity is lending this force, it's basically unlimited, because that magnet sits there until a force is pulling it away. This "unlimited" amount of force this gravity is providing in order ot keep the net force 0 requires an energy source of unlimited energy, seeing that force is related to energy. This energy seems as though it is created on the spot as a constant supply to the magnet.
Give me your argument on this so I can improvise mine. I'm not able to make a direct argument based on what you have wrote, yet. So, I'm waiting. I have to go somewhere right now, so if I don't reply, don't think it's because I don't have a plausible answer.
  • #155
Nereid, everyone is entitled to their own opinion. Whether it be right or wrong.
  • #156
You don't need a change in energy for a force, because two forces can cancel each other out (so no energy change). Perhaps an energy source, I don't really know, above my level.
Gravity is pulling the fridge into the ground, so the fridge is pushed/pulled against the ground, and the ground is pushing back. THEY'RE JUST WORDS.
AKA I can't come up with something to argue about.
  • #157
Yes, but there is no entitlement to waste bandwidth at this (privately owned) website. When I locked that other thread and advised you all that PF is not a chatroom for children, I was specifically thinking of both yourself and beatrix kiddo.
  • #158
This force needs a soucre. That source is energy
Let's do a thought experiment. Say you have two walls facing each other on opposite sides of your room. You put a hook on each wall. You then take a piece of rope and tie the two hooks together. You exert some energy making the rope as taut as you possibly can. You crank it down and tie a strong knot in it. The rope now has tension; it is pulling the two walls together. The walls are strong, however, and don't move. The tension in the rope will be the same tomorrow or in the year 3000 as it is today, as will the forces on the walls. It certainly took energy to tighten the rope in the first place, but it doesn't require any energy to keep it taut.
If you assert that the rope requires energy to stay taut, where does this energy come from? Why does the rope use energy when it's taut, but not when it's just laying on the floor?
If the rope uses an exhaustible source of energy to stay taut, what happens when that energy source runs out? Does the rope somehow untie itself and fall off the hooks? Does it stay the same length but magically just stop pulling on the walls? Does it turn into soup and drip onto the ground?
(according to the Standard-Model equations)... F=a\frac{E}{c^2}
This equation does not say what you think it says. You think it says that force requires a source of energy, presumably just because F appears on the left and E on the right. This is not sound reasoning. It's like saying that voltage requires a "source of current" because V = IR has voltage on the left and current on the right.
What you're doing is simply expressing a relationship between these quantities. Of course, E/c^2 is just the mass, so your equation is really just F=ma, or Newton's second law of motion. Forces and accelerations are related by mass. Mass and energy are related through c. Thus you can say that "force and energy are related through acceleration and c," but you're not saying anything new or novel. You're certainly not saying forces require sources of energy.
So, go out, pull something, and tell me if you get tired or not. You act the same way as gravity does.
No, you don't. We've already explained to you that the human body is a complex machine, with individual muscle fibers contracting and then relaxing. You already wowed us with your high-school biology curriculum. We've already been over this. If your muscle fibers could contract and then simply stay locked in that position, you'd never get tired. They don't do that, though.
In order for the Earth to keep the moon in orbit, there would have to be an unlimited amount of energy. Gravity is a force, where does the force of attraction get its energy from?
You can keep saying it, but it's still wrong.
- Warren
  • #159
And indeed they are (I don't think I said otherwise, did I?).
Since you did not answer my question, let me try to ask it in another way (perhaps you didn't understand my question):
PF is a forum for the discussion of physics, and other sciences. One of the cornerstones of science today is, in simple terms, the scientific method (please let me know if you are unfamiliar with what this is).
Since PF is about science, I personally expect that everyone who posts to the science threads in PF - and that includes Theory Development - has at least the intention of respecting the scientific method.
If a person has issues with the scientific method, then PF has a section where folk may discuss and debate that very topic.
When I read your posts, you appear (to me) to disparage the scientific method, and to consider it unworthy of your time to learn about it (which may explain why you don't appear to be interested to discuss the nature of science, in the Philosophy of Science and Mathematics section for example). A good example of what I mean is your apparent unwillingness to accept or consider scientific method-based questions and critiques of your own ideas.
To ask again: why are you here?
  • #160
That's what I'm trying to say.
That equation relates energy and mass to force. There are two types of forces: those that arise from mass and those that arise from energy. Energy forces are the kinds that work at a distance. I.E. Earth-Moon system, because that is a lot of force (energy) to keep moon in orbit. The space in between them is said to be the force of attraction. This has to be energy, there is no mass to constitute the force in between them. Ok, so it does not require an energy source, but an energy source would better explain how the attraction works. New or novel, nice job on being redundant. It takes energy to push or pull for anything. This energy is directed through a force. Mass is just a compact form of energy; I'm sure you all know that.
Ok, new analogy.
You weigh a certain amount of Newtons. Gravity pulls on you that exact force, thus cancelling it, right? You go up to a box. The box weighs 20N and, you push with 20N. The forces cancel out, thus making you unable to push the box. Now, you pull on the box with 30N. Not only are you moving the box, but you are also doing work. You are the only thing that is losing energy, not the box. How can the box not lose energy? You go and wrestle with a friend. You both pull each other with 20N of force; you two don't move. One pulls the other with 30N while the other with 20. You both get tired in this situation. It requires an energy for BOTH sources to keep on doing it. Yes, the human body is copmlicated, but the overall outcome is that your body takes a mass and converts it to energy to be used as the force applier. Everything needs some type of source, whether it be mass or energy, to apply a continuous source. If they apply a continuous force forever, this requires an unlimited source.
chroot, AP is college-level classes. So, get it right. :devil:
  • #161
urtalkinstupid,
I asked you some specific questions. So did Nereid. Why are you not answering them?
And once again, this is nothing but abject speculation.
And thus falls this new theory of yours, just like the last one.
- Warren
  • #162
So far, so good.
Huh? The pull of gravity is your weight. Are you saying gravity cancels itself?
I assume you mean lift with 20N?
It would require a slight bit of extra force to accelerate the box from rest.
I assume you mean that you exert an upward force of 30N on the box. It will accelerate. And yes you are doing work on the box.
You are converting chemical energy into heat and mechanical energy, some of which you are transfering to the box.
Huh? The box gains energy.
I hope you realize that you always exert the same force on each other (assuming an ideal rope): that's Newton's 3rd law.
Whether you accelerate or not depends on the net force on you. The rope pulling on you is just one force. The ground also exerts a force on you.
LOL... can't happen.
The reason why it takes energy for you to exert a force is not because "forces require energy", but because exerting a force involves your muscles in continual movement, contracting and relaxing. You are a biological system, not an inanimate object.
Nonsense.
I trust you're not taking AP physics! :wink:
  • #163
Sorry, I didn't see your questions chroot.
Ok, so F=ma[/tex], and we all know mass is related to energy. Mass is a compact form of energy, thus giving energy the greater quantity. It takes an emmence amount of energy to compose mass, it takes much more energy to make a suitable force between two objects. (or in this case three). Take away gravity and frictional forces, what are you left with? A loosely fit rope between two walls. It is no longer taut. No longer is energy acting through force on the objects. This energy arises between the forces that are applied. It&#039;s source?...I don&#039;t know. It&#039;s not my case to state that. That&#039;s simply my question that I&#039;m asking you people. The rope uses energy when it is on the floor. It is held down by gravity, this is a force, and it is in the form of energy.<br /> <br /> <blockquote data-attributes="" data-quote="chroot" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> chroot said: </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> If the rope uses an exhaustible source of energy to stay taut, what happens when that energy source runs out? Does the rope somehow untie itself and fall off the hooks? Does it stay the same length but magically just stop pulling on the walls? Does it turn into soup and drip onto the ground? </div> </div> </blockquote><br /> I stated above, &quot;Take away gravity and frictional forces, what are you left with?&quot; You take away forces, and the energy that keeps the rope taut is gone. It doesn&#039;t untie itself, it simply gets loose, allowing the walls to move in or accelerate in one directionas a system of the two walls and rope. Wall and rope soup...Sounds like the soup of the day. <img src="https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f644.png" class="smilie smilie--emoji" loading="lazy" width="64" height="64" alt=":rolleyes:" title="Roll Eyes :rolleyes:" data-smilie="11"data-shortname=":rolleyes:" /> <br /> <br /> <blockquote data-attributes="" data-quote="Nereid" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> Nereid said: </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> And indeed they are (I don&#039;t think I said otherwise, did I?). </div> </div> </blockquote><br /> No, but I implied that you took it into assumption that your opinion was right. Otherwise you wouldn&#039;t question my presence on this forum.<br /> <br /> <blockquote data-attributes="" data-quote="Nereid" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> Nereid said: </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> To ask again: why are you here? </div> </div> </blockquote><br /> I&#039;m here for the heck of it. I like this site, though I&#039;m liked by very few...none. You people have actually inspired me to make a website based on the Standard odel. Isn&#039;t that exciting. A site made by me with no absurd theories! Perhaps, I will understand the Standard Model more?? Maybe, I&#039;m here to play as the devil&#039;s advocate. Just to spur up debates. Who knows?
  • #164
Sorry, poorly worded. What I meant was gravity is what holds you down to the Earth's surface. Not what I said. Told you guys I'm bad at wording, heh. :rolleyes:
No, I actually meant what I said, this time. Lift makes a better scenario though. Doc Al, you are cool unlike others. :smile:
I'm aware of that; I added that in there for clarity. As you noted in the progression of this scenario.
You said it yourself:
It can. If one is more powerful than the other, one pulls with more force. Just like lifting a box. If you lift with more force than the box has, you overcome its force.
Heh, I'm taking AP Physics B. :wink:
Doc Al, at least you aren't mean like the others.
  • #165
Then you're saying the rope uses energy in being acted upon gravitationally, and it also uses energy in being held taut. This means that the taut rope is actually using more energy than the rope on the ground, since the taut rope is having to expend energy both in having weight and in being taut. If the rope is using more energy, shouldn't it run out of that energy more quickly? If so, you have a clear experiment that can be done to test your theory.
It doesn't untie itself, it simply gets loose
The tension in the rope is maintained via intermolecular bonds. The atoms in the rope are bound together chemically. If this rope is to just suddenly run out of energy, give up and go limp, it must actually break chemical bonds to do so. This means that the rope, after giving up, will be fundamentally different from the original rope. Since it ran out of energy, you should now be able to do all sorts of paradoxical things with it. For example, tie that piece of rope between two tractors and have them pull against it. If the rope is no longer capable of supporting tension (it ran out of energy to do so) then it will simply stretch and stretch forever -- it can't exert any more forces, but it can't untie itself from the tractors either. It must just keep getting longer. This is the "rope soup" I was getting at.
Now, people have been using ropes and building materials for a very long time. The Earth itself has been around for almost 5 billion years, and its crust still seems to have the energy required to exert a force on me to keep me from falling through it. If this phenomenon (materials running out of energy to exert forces) really happens, why have we never seen it anywhere in the entire universe?
Maybe, I'm here to play as the devil's advocate. Just to spur up debates. Who knows?
We do not welcome such people here.
- Warren
  • #166
No, but I implied that you took it into assumption that your opinion was right. Otherwise you wouldn't question my presence on this forum.
There you go again, making unwarranted assumptions :mad:
I'm here for the heck of it. I like this site, though I'm liked by very few...none. You people have actually inspired me to make a website based on the Standard odel. Isn't that exciting. A site made by me with no absurd theories! Perhaps, I will understand the Standard Model more?? Maybe, I'm here to play as the devil's advocate. Just to spur up debates. Who knows?
Thank you for your answer.
Do you consider PF to be a site where physics (and other sciences) is discussed, as science?
Do you recognise that discussion of physics, as a science, should be conducted on its own terms? In case this isn't clear, let me give you an analogy: if we are having a discussion on apple pie in the context of cooking, recipes and so forth, I personally would not consider it appropriate to talk about sexual fantasies concerning apple pies in that discussion, or whether the Sun is powered by a giant apple pie.
urtalkinstudid, just so that you don't make any further unwarranted assumptions, let me be clear as to my intention: I think the evidence is overwhelming that you are a troll, and so feel that you should be immediately banned from PF. However, I first want to make sure that you really do understand what PF is and what it's trying to do.
(for the avoidance of doubt, I personally have no power to ban anyone)
  • #167
Two very different situations:
(1) Two guys yanking on a rope: the force they exert is always the same. Or: You and superman are arm-wrestling: I don't care how strong he is, whatever force he exerts on you will exactly equal the force that you exert on him. Note that these forces are on different objects, so they don't "cancel". This is Newton's 3rd law: learn it.
(2) Lifting a box. The acceleration of the box depends on the total force on the box. You lift with 30N, gravity pulls with 20N, so the box accelerates. This is Newton's 2nd law: learn it.
Then you'd better learn about Newton's laws before that class starts!
Give it time.
  • #168
Ok, so F=ma[/tex], and we all know mass is related to energy. Mass is a compact form of energy, thus giving energy the greater quantity. It takes an emmence amount of energy to compose mass, <b>it takes much more energy to make a suitable force between two objects. </b><br />
<br /> It doesn&#039;t take energy to make a force, we&#039;ve already told you this. A force isn&#039;t energy either, unless it&#039;s over a distance. It&#039;s like using a charge to make a distance, makes no sense.<br /> <br /> <blockquote data-attributes="" data-quote="urtalkinstupid" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> urtalkinstupid said: </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Take away gravity and frictional forces, what are you left with? A loosely fit rope between two walls. It is no longer taut. No longer is energy acting through force on the objects. This energy arises between the forces that are applied. It&#039;s source?...I don&#039;t know. It&#039;s not my case to state that. That&#039;s simply my question that I&#039;m asking you people. The rope uses energy when it is on the floor. It is held down by gravity, this is a force, and it is in the form of energy. </div> </div> </blockquote>Same argument as above. Your posts are so full of BS it&#039;s scary.<br /> <br /> <br /> <blockquote data-attributes="" data-quote="urtalkinstupid" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> urtalkinstupid said: </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> I stated above, &quot;Take away gravity and frictional forces, what are you left with?&quot; You take away forces, and the energy that keeps the rope taut is gone. It doesn&#039;t untie itself, it simply gets loose, allowing the walls to move in or accelerate in one directionas a system of the two walls and rope. Wall and rope soup...Sounds like the soup of the day. <img src="https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f644.png" class="smilie smilie--emoji" loading="lazy" width="64" height="64" alt=":rolleyes:" title="Roll Eyes :rolleyes:" data-smilie="11"data-shortname=":rolleyes:" /> </div> </div> </blockquote>Stop trying to argue by being clever (soup of the day), it won&#039;t work here and should only be done when you&#039;re actually making a valid point. I refer you to Chroot&#039;s post about the rope stretching forever.<br /> <br /> <blockquote data-attributes="" data-quote="urtalkinstupid" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> urtalkinstupid said: </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> No, but I implied that you took it into assumption that your opinion was right. Otherwise you wouldn&#039;t question my presence on this forum. </div> </div> </blockquote>If you have an opinion you MUST think it&#039;s right. That&#039;s what an opinion is.<br /> <br /> <br /> I&#039;m more for the ban every post.
  • #169
this is so ridiculous..
if anyone should be banned, its people who aren't questioning the current model. stupid is just pointing out what he thinks provides evidence for his case. just because u don't agree with it doesn't mean u have the right to ban him. this is TD and criticism is welcome, but to the point where someone gets banned, especially if they aren't saying anything vulgar, is crossing the line. are u afraid this is going to be another neutrino debate, soon? i was actually hoping for it, with the exclusion of another whack ultimatum...
  • #170
It doesn't take energy to make a force
but mass is energy and it takes mass to make force...
Your posts are so full of BS it's scary.
well help to eliminate the bull-**** and answer the question...
If you have an opinion you MUST think it's right.
duh.. but doesn't mean it is right...
  • #171
beatrix,
The general consensus is that both you and urtalkinstupid are trolls. This means we don't feel that you guys actually believe the things you say. It also means that you're not here to learn (and you're obviously not capable of teaching anyone). We feel that you're just here to provoke people. We feel that you guys go home after school and laugh at all the crap you stir up here by making up and posting some garbage physics that you know is garbage. You would be thrown out of a classroom for doing such things, because you'd be wasting everyone's time. The good people of this forum are generally here because they like to learn, like to teach, or both. This forum does not intend to support trolls.
- Warren
  • #172
lord of the rings?
i never laugh at this crap.. I'm really being serious! why would we do that? it's certainly NOT to make fun of anyone... and i have only been thrown out of a classroom twice or 5 times.. last year.. :wink: so i think it's safe to say that i am not trying to waste anyone's precious time.
  • #173
Your actions speak louder than your words, beatrix.
- Warren
  • #174
i was being sarcastic warren.. maybe i shouldn't because i guess it's not just stupid on the verge of being banned...
  • #175
Here is a good example of how a force doesn't require energy: electron orbits a nucleus.
Didn't beatrix say that your physics teacher illegally spanks you? I question how good the teacher really is.
Nobody like that on these forums. We question the standard model all the time. Except we actually provide logical and informed reasons for doing so.
He has the right to ban whoever he wants for whatever he wants. These are private forums!
Excuse me? Not only do you have a very disrespectful tone but you also have said many vulgar, off-topic and ignorant comments in some of your posts. I can go and find lots of examples if you don't believe me. The fact alone that you are calling the admins considerations and the way inwhich they run the forum "ridiculous" is disrespectful and unwise. Commenting/suggesting on how the forum should be run isn't wrong, but blantly insulting the way the admins are doing their job is.
Just look at stupid's name "urtalkingstupid". Its obvious he made it that way to piss people off. Its like you want everyone to know that "if you disagree with me you're stupid!" without you even reading the details of their argument.
Debate? Felt more like an endless circle of us giving you facts and you responding with verbal attacks and lame puns followed with misinformed garbage.
  • #176
i meant generally!
everyone here hates me.. why don't u give us some of ur "logical" questions about the current model, so i know what to do...
hahaha.. it's just a name...
i may comment sometimes on the admins.. but i can find places where they personally attack me.. i can also go back and look where U have personally attacked me..
nah... it was a debate..
  • #177
I don't hate you or stupid.
I question if the universe is expanding as fast or if it is at all expanding. I think that the apparent red-shift that other galaxies show may not be from doppler-shifts at all, but possibly the result of gravitational red-shift caused by a galaxies mass. I posted a topic on this in the astronomy Forum: https://www.physicsforums.com/showthread.php?t=32590
Go and find those comments and let's see what you think attacks are. I'm sure if we did say anything "smart" or disrespectful it was a responce to you attacking us.
  • #178
u just really despise us... :wink:
good! now, go a step further and question the really big stuff like gravity...
i will.. later.. right now I'm too lazy.
sometimes yes and sometimes no.
  • #179
I would if I had a logical reason to do so, until then I assume the current model to be true.
  • #180
your energy equation derivative : F=ma~~~m=\frac{F}{a}~~~E=mc^2~~~E=\frac{F}{a}c^2~~ ~F=a\frac{E}{c^2}~~~W=a\frac{E}{c^2}dcos\theta is a direct proportion to motion at the speed of light.
so once again, no distance is being covered in relation of the two objects exerting the force, so there's no SPEED factor.
what percentage of the speed of light is Zero Speed? Nothing. hence. no energy.
this has gone as far as it's going to go, Lock it down. thanks, to all the participants.
  • · Replies 16 ·
  • · Replies 24 ·
  • · Replies 54 ·
