Work question without distance, work and velocity
  • Thread starter Thread starter MsHomework
    Velocity Work
37 replies · 16K views
MsHomework
How much work is done on an 8.0kg wagon rolling along a flat sidewalk, if applied force of 60N opposite to its direction of motion brings it to a rest in 2.0s?
W = F · d
I don't know how to start!
Force is the rate of change of momentum... F = (mv-mu)/t
The mass is constant, and the wagon comes to rest.
This should allow you to find the initial velocity of the wagon.
From there either use an equation of motion to find how far it goes, then apply W = f.d, or calculate the kinetic energy of the wagon at its initial velocity - the work done to bring it to rest is equal to that initial KE.
What does F= (mv-mu)/t stand for? Also the equation for motions would be the five main equations, right?
F=(mv-mu)/t is a form of Newtons second law. m for mass, t for time, F for force, v for final velocity, u for initial velocity. Your F here is a force opposing motion so can be used in this formula as -60 N.
Five main equations? I teach them as the 4 SUVAT equations, if that rings a bell...
F = force
m = mass
v = initial velocity
u = final velocity
t = time
It's just the change in momentum caused by stopping the cart.
I'm not sure what you mean by "five main equations", but an equation of motion is simply an equation that relates velocity and/or position and/or acceleration and time. Say, s = ut + 1/2 at^2
EDIT - Snap! Sorry.
d=(u+v/2)t
u=v+at
d= vt+1/2at^2
u^2=v^2+2ad
d=ut-1/2at^2
If you make a list of your given variables it makes it a lot easier to see which equation is the simplest to use.
You have force, mass, initial velocity and time. You can go with change in kinetic energy equations or find your distance and use your work equation. Several ways to work it.
I get a negative intial velocity, is that normal?
Like I did F= (mv-mu)/t and my initial velocity was -15 m/s
If you drew your force and velocity vectors what do you notice about their directions? Whether your initial velocity is negative depends totally on which direction you chose as positive, You could be correct or incorrect.
so the intial velocity is in the opposite direction it is heading?
Can someone just show me this step by step...because I am lost! This way I could try a similar question to practice this method!
I like Serena said:
Hi MsHomework! :smile:
Let's take a new approach from scratch.
Suppose the wagon was initially at rest and is accelerated by a force of 60 N for 2 seconds.
First question: what would the acceleration be?
But isn' the velocity final at rest since it comes to a rest...?
MsHomework said:
a= -7.5 m/s^2
Yes.
I assume you used the formula F=ma to find this?
However, since I was talking about accelerating from rest, let's take the acceleration to be positive shall we?
Next question: what would the speed be after 2 seconds?
Well, I've changed the setting of the problem.
In your problem statement, the wagon is moving along at an unknown speed and is decelerated to a halt.
But, if you'll bear with me, I first want to do a simpler problem, which is the reverse.
That is, we start from rest and then accelerate to the unknown speed.
I don't have distance!
alright I will follow your way...so What do i do for distance?
v= a/t... I don't think there is a formula like that...but that is what I used... so ya
I just divided the acceleration by time to get the speed since the real speed equation requires me to have distance!
Actually you used: u=v+at
But your formulas are a bit confusing I'm afraid, since the symbols u and v are used inconsistently in your 5 formulas.
Let's hang on to v=at.
Note that there is no division, but multiplication.
So for distance?
v= d/t is the real speed equation .
Not quite, I'm afraid.
This equation is only true if the speed is constant.
In your problem the speed is not constant, so you can't use this equation.Do you have another formula relating distance to acceleration and time?
velocity final^2= velocity initial^2 + 2(acceleration)(distance)
