How Much Work Is Needed to Position a Charge in an Equilateral Triangle?
  • Thread starter Thread starter indie452
    Charge Work
The discussion focuses on calculating the work required to position a charge (+q) at one corner of an equilateral triangle, given two other charges (+q) at the remaining corners. The work is derived using the formula Work = q * ΣV, where V is the voltage at the point due to the other charges. The final expression for the work done is established as W = q² / (2 * π * ε * a), where ε is the permittivity of free space and a is the side length of the triangle. The importance of distinguishing between electric field (E) as a vector and voltage (V) as a scalar is also emphasized.
  • Understanding of electric potential and voltage (V = k*q/r)
  • Familiarity with electric field concepts (E = F/q)
  • Knowledge of integration in physics for work calculations
  • Basic principles of electrostatics and Coulomb's law
  • Study the derivation of electric potential from electric field concepts
  • Explore the implications of vector addition in electric fields
  • Learn about the concept of work done in electrostatics
  • Review the principles of superposition in electrostatic systems
Students in physics, particularly those studying electrostatics, as well as educators and anyone involved in solving problems related to electric fields and potentials in multi-charge systems.
indie452
situation:
there are two charges (+q) one at one corner of an equilateral triangle the other at another corner. the triangle has sides length a.
what is the work required to bring another charge (+q) in from infinity to the other corner on the equilateral triangle.
ok so i know dW = -dU = F.dl
i thought that maybe finding (F) at the corner that we are bringing the charge to may help...this is:
Fc [at corner] = q2 / 2*pi*epsilon*a2
then i could just integrate this over the distance i am moving it with respect to a...however i know that the one limit will be \infty however i don't know what the other will be
thanks for any help
Consider the Voltage at the point from each of the 2 other charges.
V = k*q / r
Since work = q*ΔV
and V = 0
Then
Work = q*ΣV
ok so
the E at the point is 2q / 4*pi*epsilon*a2
the V at the point is 2q / 4*pi*epsilon*a
so work to bring in point is = q(2q / 4*pi*epsilon*a) = q2 / 2*pi*epsilon*a
indie452 said:
ok so
Looks like it.
Though E is a vector, don't forget, and V is a scalar here. In your first equation then the E would need to be added as vectors. Whereas for V you are adding scalars.
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/mulpoi.html#c1
ok thanks...:biggrin:
10K
  • · Replies 17 ·
38K
