Question: Calculating Work with a Line Integral
To calculate the work done by the force field F(x,y)=xy i + x^2j along the curve C: x=y^2 from (0,0) to (1,1), the correct parameterization should be y=t and x=t^2. The integral for work is set up as ∫F(r(t))·r'(t)dt, where r(t) is the parameterized curve. The initial attempt incorrectly used x=t and y=t^2, leading to an incorrect result of 3/4 instead of the correct answer, 3/5. The discussion emphasizes the importance of correctly identifying the parameterization of the curve to achieve the right solution. Accurate parameterization is crucial for solving line integrals in vector fields.
Breedlove
Find the work doneby the force field F on a particle that moves along the curve C.
F(x,y)=xy i + x^2j
\intF dot dr=\int^{b}_{a}F(r(t))dotr'(t)dt
Okay, so I parametrized x=t and y=t^2 (giving r(t)=ti+t^2j right?) and substituted those values in for x and y in F, dotted that with 1i+2tj because I think that it is the derivative of r, if the parametric equations for r are x=t and y=t^2. I then took the integral of the dot product i just took over the interval 0 to 1. I ended up with 3/4 but the correct answer is 3/5
No, the curve is x=y^2 not y=x^2 so your parametric form of y should be y=\sqrt{t}. Alternatively use: y=t and x=t^2.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
