Working out radius of sphere using Mass&Density
  • Thread starter Thread starter eggman100
    Radius Sphere
To calculate the radius of a sphere given its mass and density, the mass is divided by the density to find the volume. The density must be converted from g/cm³ to kg/m³ for accurate calculations. The volume of the sphere is then used in the formula V = (4/3)πr³ to solve for the radius. There are concerns about unit conversions, particularly when transitioning from cm³ to m³, which can lead to confusion in the final radius calculation. Ensuring correct unit conversions is crucial for obtaining an accurate result.
eggman100
Using mass = 2.473x10^23kg and Density = 7.481g/cm^3 work out the radius of said sphere,
D=M/V
4/3∏r^3
D=M/V
DV=M
V=M/D
Mass = 2.473x10^23kg
V=2.473x10^23kg / 7.481g/cm^3
V=2.473x10^23kg / 0.007481kg/cm^3
V= 3.31x10^24 cm
V= 3.31x10^22 km
Vol of sphere = 4/3∏r^3
3√(3.31x10^22/(4/3∏)) = 19918033Km
I assume I have a massive problem in my calculations (I think there's a problem where i changed the 7.481g/cm^3 into 0.007481kg/cm^3) but I'm still pretty unsure about that one, since my answer at the end is in kilograms and the units i used when changing the decimal is in cm^3, I think that's my problem but I'm not sure)
Thanks
Tried to change it into kg/km^3 and i got 2.473x10^23kg / 748.1
then cube-root((3.31x10^20)/(4/3Pi) to get 4291210 km, still unsure =/
Changed it :
(2.473x10^23kg) / (7.481g/cm^3) into
(2.473 x 10^23kg) / (0.007481kg/cm^3) noting that it is CM(i remembered at the end ;) )
3.666622109x10^25cm <--- 4/3PiR^3
divide
3.666622109x10^25cm by 4/3Pi then
cuberoot to get:
206091073.4 CM(!) / 100 to get meters (=)
2060910.734 M / 1000 to get KM (=)
2060.910734 KM -
rounded to 2061km (4.S.F)
I hope that's right, it seems reasonably accurate,
Check again on units. When you have units like cm^3, if you want to go to km^3, the conversion is not the same as going from cm to km (you can check this by typing "cm^3 to km^3" vs. "cm to km" in google).
but then on my calculator i get 2.060910734 x 10^-7 <--- I don't understand if I have a volume of 206091073.4cm^3, how that can turn into a small decimal number for the radius in kilometers, especially when the mass is 2.473x10^23, its nothing like a neutron star, just a regular planet, so i don't really agree =$
Google wanted to give me:
(2.47300 x ((10^23) kg)) / (7.48100 (g / (cm^3))) = 3.30570779 × 10^19 m^3
so it would be: cube-root( 3.30570779 × 10^19 m^3 / (4/3Pi) )
to get: 1990942.041meters /1000 =
1990.942041km, dividing by 1k because it isn't km^3 its km, like you said, radius isn't squared or cubed, just power1
to convert g/cm3 to kg/m3
(\frac{7.481g}{cm^3})(\frac{1Kg}{1000g})(\frac{100cm}{1m})(\frac{100cm}{1m})(\frac{100cm}{1m})
I'm sorry but that really doesn't help me solve my problem, I don't understand what you said, I mean all I wanted to do was convert the
M/D into Kg (top/bottom) and km^3 from cm^3 at the bottom,
and then just divide by 4/3∏ then 3√ to get my answer in Km's, but it just wasn't happening, any ideas?><
http://blip.tv/chemteam/converting-between-g-cm3-and-kg-m3-3101296 - but it isn't km^3 just m^3
I didn't really follow what you did because it's too much work. I was showing you how to convert your density into kg/m3 because it's always better to convert your units first. So just do that and it's a very simple problem.
It's the same as converting grams/cm to kg/m except since it's cm3 (because it's volume) I need to put the conversion factor (100cm=1m) 3 times so I end up with meters3.
http://youtu.be/XKCZn5MLKvk
Why do you want to convert it to km anyway?
