Comp Sci Optimizing Numpy Arrays for Efficient Data Manipulation
  • Thread starter Thread starter ver_mathstats
    Arrays Numpy
The discussion centers on optimizing the use of NumPy arrays for data manipulation, specifically addressing the need for a function to create a zero-filled array. The original code attempts to define a function, array_zero, but is deemed overly complicated and flawed. The simpler solution involves directly using np.zeros to create the array, which effectively meets the requirements without unnecessary complexity. It is noted that the dtype argument can be omitted since float is the default. Overall, the simpler approach is recommended for efficiency and clarity.
ver_mathstats
Assign to a variable a NumPy array that has shape (3, 4) and whose entries are all equal to 0.0 (so the values of a are of type float). So, if i= 0,1,2 and j=0,1,2,3 then a[i,j]=0.0.
python
I feel like I have over complicated this question but here is the code I wrote out for it, I wrote it as a function but when I printed my values I realized I did not need a function to do so. So would I just use my second code to answer the question.
Python:
import numpy as np
def array_zero(n):
    for i in range(n):
        for i in range(n):
            result=print(a1[i,j])
    return result
a1=np.zeros([3,4],dtype=float)
print(a1[0,0])
print(a1[2,3])
Or would the solution be as simple as:
Python:
import numpy as np
print(a1)
print()
print(a1[0,0])
Thanks.
The function array_zero has quite a few things wrong with it, but as you can see from printing the result, np.zeros([3, 4]) answers the question exactly (you can even omit the second argument as I have done because float is the default).
Likes ver_mathstats and jim mcnamara
Okay I understand, and thank you.
