Discover the Solution to the World's Hardest Easy Problem on Thinkzone.wlonk.com
  • Thread starter Thread starter namanjain
The discussion revolves around solving a diophantine equation related to angles in a triangle, specifically x + y = 130, where x and y are positive integers with y > x and y > 90 degrees. Participants suggest possible angle pairs, such as (20°, 110°) and (30°, 100°), but express frustration over not being able to find a solution. There is a focus on using geometric strategies, including drawing triangles to scale and considering parallel lines, to approach the problem. Some participants emphasize the importance of demonstrating effort before seeking help, while others share their experiences and challenges in understanding the geometry involved. Overall, the thread highlights the collaborative effort to tackle a complex mathematical problem.
namanjain
Mathematics news on Phys.org
I haven't the solution, I get the equation x + y = 130, where x and y are angles. If x, y \in Z^+
This is a diophantine equation. We know: x, y > 0. y > x. And y is greater than 90 degrees.
the most probable angles:
x=20^o\,\, ,y=110^o
or
x=30^o\,\, ,y=100^o
I tried a couple of things but didn't solve it yet , but there's probably a way to build your way up to the x angle using the tricks in my sketch (just don't have the patience to construct the triangles properly and doing it now):
Simple geometry is all that is required.
Why can't you do this for yourself? Don't give up so easy.
wazz it,
i tried it hard that's why asking askin solution,
well i need an approach
i asked it to one of my faculty at coaching and he straightaway said it's wrong so i needed to check
x=20^o\,\, ,y=110^o
or
x=30^o\,\, ,y=100^o
whatss y in equation
x+y= 130
reenmachine i agree myself i even not have patience and doing it (doing angle sum property question) , thanks for tip of parallel lines but what benefit it does
I don't know since I didn't solve it.It was just a suggestion of strategy to attack the problem , maybe it's a dead end , but the parallel lines will at least allow you to chase more angles , whether or not they end up being useful to find angle x.
If you don't have the patience to try it , I suggest you do not ask others to do it for you as it's not recommended on the forum to ask for answers without showing that you tried hard before hand.I'm not a moderator , just friendly advice.Also , saying that you tried hard is not showing that you tried hard.
till here i ve done (in attchment)
one of image is inverted
so i did the mirror image from webcam toy
You should draw the triangles/angles to scale if you want to try that strategy.
It should look like the picture below
kingo1979 said:
from the original figure below, y seems equal angle bde
http://thinkzone.wlonk.com/mathfun/triangle.htm
where x + y + 50 = 180
however i got that but i also meant that diophtine (whatever is name) equation
well where is it taught
reenmachine said:
you should draw the triangles/angles to scale if you want to try that strategy.
does that help, because doing any of olympiads we were never told to draw to scale and i was always of kind to do geometry of this kind mentally so it's quite difficult for me
though i think i'll print that page
Uff! After long work with a correct precise figure i bored and saw solution on one of other web pages
is it bad of me not getting it (i'm 15 yrs and preparing rmo and iit)
I don't know , you should listen to your teachers before you listen to me that's for sure :-p
You should also listen to mentors here as they are qualified to help you.
Likes 1 person
Might try to prove both of these triangles (or another pair of triangles) are similar to prove x = 20 :
