Bob Eisenberg
- 4
- 0
Would magnetic charge be Lorentz invariant (the way electric charge is) if magnetic charge existed?
PeterDonis said:This question doesn't have a well-defined answer, because magnetic charge doesn't exist, so there's no way to do an experiment to test whether it's Lorentz invariant, and no way to know what theory we should use to compute the answer. There are certainly Lorentz invariant extensions of standard electromagnetism that include magnetic charges, which are Lorentz invariant in those theories; but there are also possible theories of magnetic charges in which they are not Lorentz invariant. Since magnetic charges don't actually exist, how are we supposed to tell which theory we should use to answer your question?
stevendaryl said:physicists have looked into the consequences of the existence of magnetic monopoles, and there are GUTs that predict their existence
Bob Eisenberg said:Mr. or Dr. or Prof. Donis, or Peter, if first names are OK
PeterDonis said:Yes, but all of these theories assume Lorentz invariance. So they don't, of themselves, address the question the OP was asking. The only way to decide that question would be if we actually discovered magnetic monopoles and could test whether their magnetic charge was Lorentz invariant.
samalkhaiat said:Do you need to discover the colour charges of QCD in order to see they are Lorentz scalars?
samalkhaiat said:Lorentz-invariance alone is not enough to prove the scalar nature of ##Q_{\alpha} (t)##.
samalkhaiat said:In formulating a theory, I don't care about what experiment may or may not say about the theory.
samalkhaiat said:are you certain that there exists no magnetic charges in this universe?
bcrowell said:magnetic charge should behave the same way as electric charge.
bcrowell said:if you have one electric charge ##e## and one magnetic monopole with magnetic charge ##g##, then the angular momentum of their fields is finite, proportional to the product ##eg##, and independent of the distance between them. Since both angular momentum and electric charge are quantized, it follows that magnetic charge, if it exists, must also be quantized. If it's quantized, then we can't have it changing when we do a Lorentz transformation.
First of all, in field theory with electric and magnetic charges, the numbers [itex](e , g)[/itex] are coupling strengths. They are not the Noether charges associated with the symmetry group [itex]U_{e}(1) \times U_{g}(1)[/itex]. If we put these couplings in the corresponding [itex]U(1)[/itex] transformation, they simply appear as coefficients in the corresponding charge [tex]Q_{\alpha} = q_{\alpha} \int d^3 x \ J^{0} (x) ,[/tex] where [itex]q_{1} = e, \ \ q_{2} = g[/itex]. If the OP was talking about (g), then I would not have bothered myself with his question.bcrowell said:Here is a further argument that I think is definitive. As pointed out by Dirac, if you have one electric charge ##e## and one magnetic monopole with magnetic charge ##g##, then the angular momentum of their fields is finite, proportional to the product ##eg##, and independent of the distance between them. Since both angular momentum and electric charge are quantized, it follows that magnetic charge, if it exists, must also be quantized. If it's quantized, then we can't have it changing when we do a Lorentz transformation.
It's probably also possible to make purely classical arguments. The original motivation for SR was to make Maxwell's equations Lorentz invariant. If charge wasn't invariant under a boost, that would break the Lorentz invariance of Maxwell's equations. I think the same would apply to magnetic charge.
PeterDonis said:My only question would be what assumptions are required to show that the angular momentum is proportional to ##eg##.
pervect said:By symmetry, I'd expect that magnetic charge density would be conserved, but would not be a Lorentz invariant scalar, which is how I interpreted the question, though I could be misunderstanding it.
