Would the sky be red if the atmosphere was thicker?
  • Context: Undergrad
  • Thread starter Thread starter willstaruss22
    Atmosphere Sky
The discussion revolves around the hypothetical scenario of Earth's atmosphere being significantly thicker, specifically at 500 bar, and its effects on the color of the sky and the appearance of the Sun. Participants explore the implications of increased atmospheric density on light scattering and color perception, considering both theoretical and observational aspects.
  • Some participants propose that a thicker atmosphere would lead to a redder appearance of the Sun, especially at noon, while others argue that the sky might still appear blue due to scattering effects.
  • One participant suggests that with a thicker atmosphere, not only blue light would be scattered, but also green light, potentially resulting in a cyan tint to the sky.
  • Another viewpoint indicates that at very high pressures, blue light would be absorbed before reaching the surface, leading to a dim red glow instead of a distinct Sun.
  • A participant questions whether the entire sky would appear red or just a deeper blue if the atmospheric depth matched that at sunset.
  • There is a discussion about the visibility of clouds and whether their appearance at the horizon relates to the curvature of the Earth.
Participants express multiple competing views on how a thicker atmosphere would affect the color of the sky and the Sun, indicating that the discussion remains unresolved with no consensus reached.
Some claims depend on assumptions about light absorption and scattering in dense gases, and the discussion includes varying interpretations of atmospheric behavior under different conditions.
willstaruss22
Lets say Earths atmosphere with the same composition of gases was 500 bar. Would the sky be red instead of blue because light from the Sun would have to travel through more atmosphere?
Astronomy news on Phys.org
The sun itself would be very red. I dont't think the sky would have to be red, as the light that you see would still be the part of the sunlight that is scattered. At sunrise/sunset, the sunlight will take a much longer path through the atmosphere, and only the sun itself and the sky close to it is red.
If the atmosphere was thicker,wouldn't the sun look red even at noon?
Yes. What I meant was, that sunset/sunrise with a normal Earth atmosphere mimics the situation with a much thicker atmosphere.
So at noon the sky would essentially still be blue but the Sun would look red?
With a thicker atmosphere, not only blues would be scattered away from the direct path from the Sun. I imagine that you would also see green parts of the spectrum being scattered in the sky, away from the Sun. This could give a more Cyan tint to the sky. This is the sort of colour you can see in the western sky near sunset, where the atmospheric path is long and the normal blue of the sky becomes 'tainted' with a greenish hue and makes that very attractive, temporary greeny blue which we all recognise as a precursor to darkness.
With a really thick atmosphere (we have to mean 'dense' here, too) the outline of the Sun would also become blurred by scattering (as we get when viewing the Sun through thin cloud at sunset).
It seems to me that the sky would simply be a more intense and brighter blue, since even more blue light would be being scattered. Can someone tell me if this thought is incorrect? I would greatly appreciate it. Thanks.
500 bar? The blue parts would get absorbed long before they reach the surface, and I guess the red parts would get scattered so much you would not see the sun as a disk any more, just a general very dim red glow of the sky.
Note that nitrogen and oxygen are beyond their critical point then, that might change the absorption.
Maybe I should change the question a little - what if the normal depth of the atmosphere was the distance light travels through the atmosphere at sunset, when the sun is red? Would the whole sky be red, or just a deeper blue?
Also, another question: when you look out over a flat landscape on fairly clear day, and see a layer of clouds (discrete clouds) at maybe all the same height above the earth, stretching away in the distance and seemingly getting closer to the Earth as they near the horizon, are you, in a sense, seeing the curvature of the earth?
Of the order of ~200-300km at sea level pressure. You get a similar effect with less than 50 bar surface pressure and the sun directly above you - but then blue light gets a really hard time reaching the surface, so the rest of the sky will probably look dark red.
  • · Replies 29 ·
  • · Replies 34 ·
9K
