Would the water remain in lquid form?
  • Thread starter Thread starter willstaruss22
    Form Water
In a scenario where Earth's atmospheric pressure is reduced to 0.10 bar, the boiling point of water would be 113 degrees Fahrenheit. Despite daytime temperatures potentially reaching 130 degrees Fahrenheit, the ocean would not boil due to the significant heat capacity of water and the limitations imposed by evaporation rates, which can only reach 1.6 mm/hour under optimal conditions. The temperature fluctuations over a 24-hour period would not be sufficient to raise the ocean's temperature to boiling, as the heat must first be absorbed by the water. Therefore, the ocean would remain in liquid form even with a thinner atmosphere.
  • Understanding of atmospheric pressure and its effects on boiling points
  • Knowledge of heat capacity and thermal dynamics of water
  • Familiarity with evaporation rates and energy requirements for phase changes
  • Basic principles of meteorology related to temperature fluctuations
  • Research the effects of atmospheric pressure on boiling points using thermodynamic principles
  • Explore the concept of heat capacity in relation to large bodies of water
  • Investigate evaporation rates and their impact on temperature regulation in oceans
  • Study the formation of clouds and fog in relation to temperature changes over water
Climate scientists, meteorologists, oceanographers, and anyone interested in the effects of atmospheric changes on water states and temperature dynamics.
willstaruss22
Lets say Earths atmospheric pressure was reduced to 0.10 bar which is 10% Earths atmospheric pressure. The boiling point at this pressure is 113 degrees F. Due to the atmosphere being thinner there is a greater temperature difference with higher highs and lower lows in a 24 hour period.
Lets say in a large area over the pacific ocean the air temperature in the day time reaches 130 degrees F and the temperature in the night time reaches 60 degrees F. This temperature difference is over a 24 hour period over a body of water. Would the oceans reach boiling point given the atmosphere is reaching above the boiling point for the given atmospheric pressure or will it remain a constant liquid because of the lower temperature?
You can't get such a large temperature difference above the ocean. At daytime the sun will shine into the water, and it will have to heat a layer some tens of meters thick. Evaporation will limit the temperature rise also. Even with the sun directly overhead and all energy going into evaporation., you can only evaporate 1.6 mm/hour. ( 1kw/m^2 sunshine and 2.26 MJ/kg to evaporate water)
rapid cooling at night over a warm ocean will surely produce clouds or fog.
Even with an atmosphere 10% as thick as Earths the temperature difference won't be as big? I always thought that there would be bigger highs and lows with a thinner atmosphere.
But to get the air above the ocean to heat up, you've got to heat up the ocean first, and the heat capacity of the ocean hasn't changed.
Would a change in atmospheric pressure change the latent heat of vaporization of the water?
So basically the ocean would remain liquid even with an atmosphere this thin? Interesting and i also forgot that there is a lot of water to heat up.
  • · Replies 0 ·
  • · Replies 0 ·
  • · Replies 21 ·
