Write transfer function G(s) of circuit
2 replies · 7K views · last reply
Maurizio
The problem ask me to write the transfert function of a electrical circuit witch include an operational amplifier. I've follow some instruction bur I cannot figure out from this problem.
Could you suggest me somethings?
I'd like to calculate G(S) = U(s) / Y(s)
where U(s) is Lasplace transform of u(t) and Y(s) is Lasplace transform of y(t)
The circuit, and solution is in attached file tf.pdf.
I start cualculating the equivalent impedance Z2.
I get: R + 1/SC
How can I write equivalent impedance for Z1.
I'd like to apply the formula:
G(s) = U(s)/Y(s) = -Z2/Z1
Thank you very much!
Keeping in mind that the minus input of the opamp is a virtual ground, you should calculate how much current will flow to ground from the right end of the Z1 network if you apply 1 volt at the input node u. Then take the ratio of the applied voltage (1 volt) and the output current in the rightmost resistor R of the Z1 network, if the right end of that resistor is grounded.
That ratio will be the equivalent impedance of the Z1 network.
Thank you for your answer. I've found that it's possible to solve this kind of problem in simple way applying: Y-Δ transform
The link of a page on wikipedia is the following:
http://en.wikipedia.org/wiki/Y-Δ_transform
I hope that someone could find this post helpful.
Thank you
Bye
Maurizio
