Writing a squared observable in Dirac notation
9 replies · 2K views
Zero1010
I need help writing in Dirac notation
##<A>=\int_{-\infty}^\infty \Psi^*(x) \hat A \Psi (x) dx ##
##<A> = <\Psi|\hat A|\Psi>##
##<A^2>=\int_{-\infty}^\infty |\Psi^*(x)|^2 \hat A^2 dx ##
Edited after post below:
Hi,
I need to show that the square of the expectation value of an observable takes a certain form in Dirac notation.
I know in wave notation that the expectation value is a sandwich integral which looks like this:
Which is written in Dirac notation as:
And the expectation value of a squared observable is written as:
##<A^2>=\int_{-\infty}^\infty \Psi^*(x) \hat A^2 \Psi(x) dx ##
But I am not sure how to write this in Dirac notation.
Thanks for any help and hopefully this makes sense.
This can't be right. You have a number on the LHS and an operator on the RHS. It should be:
##<A^2>=\int_{-\infty}^\infty \Psi^*(x) \hat A^2 \Psi (x) dx ##
Note also that this is the expectation value of the square of the observable/operator and not to be confused with ##\langle A \rangle^2##, which is the square of the expectation value.
Thanks for the heads up.
I was looking at the expectation value from my textbook (see image) which is obviously different. Thanks
If you have the position operator, or the position operator squared, then we have:
##\Psi^*(x) \hat x^2 \Psi(x) = \Psi^*(x) x^2 \Psi(x) = |\Psi(x)|^2x^2##
But, this does not hold for a general operator ##\hat A##. For example, if we have the differential operator:
##\Psi^*(x) \hat D \Psi(x) = \Psi^*(x) \frac{d\Psi}{dx}(x) \ne |\Psi(x)|^2 \frac{d}{dx}##
Ok that makes sense.
The operator I am dealing with is Hermitian which is important later in the question I'm working on.
So in Dirac notation is it just written as:
##<\Psi(x)|\hat A^2|\Psi(x)>##
Yes, that's the expectation value for the operator ##\hat A^2##. Look at it this way: you could write ##\hat B = \hat A^2##, then:
##\langle A^2 \rangle = \langle B \rangle = \langle \Psi | \hat B |\Psi \rangle = \langle \Psi | \hat A^2 |\Psi \rangle ##
Ok. Thanks for your help so far its been great.
One last thing, does this make sense (hopefully):
##<A^2>=<\psi|\hat A^2|\Psi>##
##<A^2>=<\psi|\hat A \hat A|\Psi>##
The operate on the right acts on Psi so:
##<A^2>=<\psi|\hat A|\hat A\Psi>##
Since ##\hat A## is Hermitian (therefore - ##<f|\hat A g> = <\hat A f| g>##):
##<A^2>=<\hat A \psi|\hat A\Psi>##
Yes. In general:
##\langle \Psi|\hat A \hat B|\Psi \rangle = \langle (\hat A^{\dagger} \Psi)|(\hat B\Psi) \rangle##
Cool.
Thanks again for your help.
