Y=KX^n Graphing and Coefficient
  • Context: Undergrad
  • Thread starter Thread starter lunapt
    Coefficient Graphing
The discussion centers on the equation y=KX^N and its application to a dataset in chemistry exhibiting a curved negative slope. To transform this equation into a linear form, the value of N must be set to 1, making the equation y=kx a linear representation. The constant K can be any non-zero real number. The participants suggest using logarithmic transformations to analyze the data, indicating that plotting Log(y) against Log(x) yields a linear relationship, which is more suitable for fitting the data.
  • Understanding of exponential functions and their properties
  • Familiarity with logarithmic transformations in data analysis
  • Basic knowledge of graphing techniques, including Cartesian and semilog paper
  • Ability to interpret coefficients in linear equations
  • Learn about logarithmic transformations in data analysis
  • Explore methods for fitting exponential decay models to datasets
  • Investigate the use of linear regression techniques on transformed data
  • Study the properties of power functions and their graphical representations
Chemists, data analysts, and students studying mathematical modeling in scientific contexts will benefit from this discussion, particularly those interested in graphing and analyzing nonlinear relationships.
lunapt
So there's this graph in chemistry with a curved negative slope shape.
(x, y)
(0.16, 104.61)
(0.26, 39.62)
(0.35, 21.86)
(0.56, 8.54)
(0.70, 5.47)
(0.98, 2.79)
The equation is y=KX^N
1) What is the value of N for which the graph would be a straight line?
2) What is the value of K for which the graph would be a straight line?
No idea how to do this.
Mathematics news on Phys.org
(x, y)
(0.16, 104.61)
(0.26, 39.62)
(0.35, 21.86)
(0.56, 8.54)
(0.70, 5.47)
(0.98, 2.79)
Using purely qualitative understanding of functions, you would expect any equation of the form, y=kx where y is the dependent varialbe, x is the dependent variable, and k is any real nonzero number constant, the be an equation for a line. Knowing that, if you wished y=kx^n to be a line, then n=1, and again, k is any real constant not equal to zero.
Your (x, y) data show x going through one cycle of 10 and y going through about two cycles of 10. An exponential fit might be reasonable to try. You get a better idea if you plot the points on cartesian paper. Maybe semilog paper, too.
i tried exponentially, and if i put in logy and input y values, then its almost a straight line...
how do i find n?
Welcome to PF, lunapt!:
Consider that:
y=K X^N
\log y=\log(K X^N)
\log y=\log K + N \log X
The method would be to set up the regular equation for a line.
And then match the coefficients with log(K) and N.
However, it seems to me that your equation wouldn't fit (but I did not work it out).
It seems more likely that your relation is y=K N^X.
So:
\log y = \log(K N^X)
\log y = \log K + X \log N
lunapt,
Your points plotted on a cartesian system directly appear like exponential decay. Your points when treated as Log(y) versus Log(x) and then plotted seem to give a very clean, accurate, line.
  • · Replies 44 ·
46K
  • Poll Poll
  • Poll Poll
12K
