Yes, Determine Current From Watts
  • Context: High School
  • Thread starter Thread starter gkangelexa
    Current Watts
3 replies · 3K views
gkangelexa
Can you determine current given only the watts?
Ex) if you have a lightbulb with 120 Watts, can you determine the current (charge) that flows through it in a second, for example?
From the way the question is phrased, no was the correct answer.
You need any 2 (Voltage/Current/Resistance/Power) to determine an unknown in basic circuits.
However, if you MEANT (since you referenced a 120W light bulb) how much current will the bulb draw on a standard 120 VAC circuit, then that is simply P=V*I ---> I = P/V = 120W/120V = 1 Amp.
A 120 W rated bulb will not actually draw/dissipate 120 W of power unless it is powered by the expected voltage (ie a 12V battery will not push 10 amps through it).
In general no, you need also voltage:
Power = voltage times current.
In the lightbulb example you probably know the voltage implicitly i.e. it's a lightbulb used with 120V AC house lights. In that case you would solve to find the current is 1 amp (1 coulomb per second).
current = power / voltage
