Yet another Lagrangian problem. Motion in a cone
A particle slides inside a frictionless cone, and the discussion focuses on deriving the equations of motion using the Lagrangian approach. The participant struggles with formulating the correct Lagrangian, initially omitting key variables like the vertical position. After realizing the need to include the distance along the cone's surface, they update the Lagrangian to account for both radial and angular motion. The goal is to determine the frequency of circular motion and the frequency of oscillations when perturbed from this motion. The conversation highlights the importance of accurately representing all variables in the Lagrangian for proper analysis.
Xyius
Man I hate to make two post in one day but I am really stuck!
A particle slides on the inside surface if a frictionless cone. The cone is fixed with its tip on the ground and its axis vertical. The half angle of the tip is α. Let r be the distance from the particle to the axis, and let θ be the angle around the cone.
1. Find the equations of motion.
2. If the particle moves in a circle of radius r_0, what is the frequenct of this motion ω?
3. If the particle is perturbed slightly from the circular motion, what is the frequency of oscillations about the radius r_0?
Lagrangian and Lagranges Equations
If need be, I will draw a picture and upload it so the relations used are more obvious.
First thing is first, is my Lagrangian correct? (I made an image in MathType, its easier for me.)
[PLAIN]http://img197.imageshack.us/img197/9997/lag1.gif
I do not think this is correct because I am not getting oscillatory motion for theta when I solve!
EDIT: Oh! I forgot to mention! 'l' is the distance on the side of the cone from the point to where the particle is. I do not know how to include this in the lagrangian!
Okay so I realized I didn't include \dot{z}! After including that, I have...
L=\frac{1}{2}m \left( \frac{\dot{r}^2}{sin^2σ}+r^2 \dot{θ}^2 \right)-\frac{mgr}{tanα}
9K
