YOU: Fix the US Energy Crisis
  • Thread starter Thread starter russ_watters
    Energy
1,495 replies · 435K views
Redbelly98 said:
But surely you mean fission, whereas the previous post was referring to fusion.
Yes, I did. Totally missed the part about fusion.
Topher925 said:
Unless we want to live in the dark or destroy the planet, the majority of the supply of energy in the near future will almost undoubtedly come from nuclear energy.
"Salt water extraction"
http://www.new4stroke.com/pompa.pdf"
And sallt water Tank:
1 m^3 / sec if H = 100 m give ~~ 1 MW ( 1000 KW) electric energy
Detail about salt water generator:
http://www.new4stroke.com/salt%20water%20pumped%20storage.pdf"
Regards Andrew :-p
That refers to pump storage, i.e. an energy storage scheme, not a primary energy production technology like nuclear.
Disagree.
Energy is extracted from ocean waves and then stored for either immediate or future use.
It may not look like much, but getting away from "one trick pony" types of energy solutions is very important, IMHO.
OmCheeto said:
Disagree.
Yes I'm wrong, missed that part of it - the pump.
Very nifty. Gets around the entire baseload problem.
Looks good to me, one large pump would not react as well to the wave energy, but a multiple of smaller units might, a little like keys on a piano board.
I'm sure there would be many pumps involved in order to capture as much energy as practically possible.
I suggest FIRE the people we have in congress and start over. That would fix more than just the US Energy Crisis.
Nifty yes but an 'entire' problem solver might be stretching things a little. If pumped storage was tasked with backing an entire US theoretical electrical grid that ran only off an intermittent source like, say, solar power and existing hydro, then the US would need some 800 GW(e) of pumped salt water storage running at night worst case, and would require transmission to the middle US from the coasts. At the moment, the US has http://www.eia.doe.gov/oiaf/servicerpt/stimulus/excel/aeostimtab_9.xls" (2.6% ) of pumped storage, including the largest single facility in the world. Also, the existing pumped storage facilities are designed with a run capacity on the order of a dozen hours or so, not the couple, three days that might be required in the event of a major winter snow storm.
Yes, you right
One large wave...
Regars Andrew:wink:
Feliks said:
Yes, you right
One large wave...
Regars Andrew:wink:
I stand corrected, that would work one very large pump.:eek::biggrin:
An idea with no numbers attached to it has no identifiable feasibility. Here's the wiki on wave power: http://en.wikipedia.org/wiki/Wave_power
People have been trying to harness wave power for hundreds of years and as of yet have made little headway toward making it practical for large scale power generation. Here's a link to the website of the first project on the list on the wiki: http://www.oceanpowertechnologies.com/reedsport.htm
OPT is developing the first commercial wave park on the West Coast of the United States located 2.5 miles offshore near Reedsport, Oregon. The wave park will consist of ten (10) PB150 PowerBuoys, an undersea substation to collect the power, and a submarine cable to deliver the renewable power to the Pacific Northwest electric grid. Each PB150 PowerBuoy® has a maximum sustained generating capacity of 150 kiloWatts.
The estimated amount of electricity this project will deliver to the grid is approximately 4,140 MegaWatt-hours/year based on the wave resource at this location, or enough for up to 375 homes.
To put those numbers in perspective:
-Many buildings have generators bigger than the total capacity of that plant on their roofs.
-It takes about 20 of these buoys to match the [peak] capacity of one large wind turbine.
-With a load factor of 30%, it will actually generate an average of 470kW altogether.
-Power plant sizes vary, but a typical coal plant might be 500 MW and a typical nuclear plant 2,000 MW, both running at pretty high load factor. It would take 3,300 of these devices to match the [peak] power of a single typical coal plant and 13,000 to match a single nuclear plant. To match the consumption, multiply those by 3.
-The company claims it can match the max cost per kWh of wind, about $.15/kWh. That's more than double what is typical for nuclear and closer to triple what coal is. And that's an estimate by the company that is trying to sell them. No doubt, their pilot plant is much more expensive.
-The company's cost projection is based on being able to sell 400 of these buoys a year. If they meet their production goal, in 33 years, they will have installed enough capacity to match a single nuclear plant's kW capacity - and in 100 years, they'll be able to match a nuclear plant's kWh capacity.
Bottom line: people have been looking into wave power for centuries and even today they have not been proven to be viable, even as a high-priced niche product.
Regarding cost and technical feasiblity, here's an article about the world's first true commercial wave power plant: http://www.cnn.com/2008/TECH/science/09/24/wave.pelamis/index.html
The first phase went online in 2008, generating 2.25 MW at a cost of about $11.2 million. If they last 20 years and require negligible maintenance while delivering a load factor of 30%, the power they deliver will end up costing about $.08 to produce.
However, the plant only operated for 4 months before bearings failed. They are currently planning on replacing the units with upgrades. http://en.wikipedia.org/wiki/Pelamis_Wave_Energy_Converter
More: http://www.ecogeek.org/tidal-and-wave-power/2635
A plant in Ecuador was intended to produce 750kW and never produced more than 200. It is now also ofline due to technical problems and the company (same company) appears to be in financial company. Keep in mind, this is probably the most successful wave power company ever and so far, they have little to show in the way of real commercial accomplishment.
Ding, ding, ding. That's got sig, or an engineering forum guideline addition written all over it.
I don't think anyone here ever stated that this was an amazing fix all solution. But it is an interesting idea based on already proven concepts. Just because an idea doesn't have all the numbers immediately attached to it doesn't mean you should just completely throw it out.
Also, Oceanlinx as far as I know has so far been successful. Although they are still very new and have only very recently connected one of their generators to the grid.
http://www.oceanlinx.com/
http://www.oceanlinx.com/images/FactSheets/oceanlinx_technical_facts_sheet_v3_eng.pdf
<shrug> I didn't suggest completely throwing it out.
That's how I see it.
Don't know why people don't like the idea.
Of course it'll take tweaking to get it right.
Who'd have thought, a hundred years ago, that if you collected a certain type of rock, threw them in a special box, you'd get free energy out of that box for decades.
ps. your keys on a piano board sounds like my wave powered rowboat.(a linear array of ratcheted arms with floats on the ends powering a single shaft) I don't think I'll ever build it of course, but the same idea can be used to pump water. A very handy device on a sandy beach when it's 100'F outside. Some of this stuff doesn't necessarily have to save the world. It just needs to make me more comfortable.
mheslep said:
Ding, ding, ding. That's got sig, or new engineering forum guideline addition written all over it.
Thanks, we can work out a licensing agreement offline :biggrin:
Well, the person who first brought it up made some pretty bold implicit claims. First, the post was in response to a statement you said about the "vast majority of the supply of energy", implying this could provide something substantial. Besides which, just by being brought up in this thread, it should be considered a technology with the potential to make a real impact.
Then, there's the addition of the comment about the pumped-storage, which is largely unrelated and includes a completely context-less capacity statement that has nothing whatsoever to do with the capacity of the pumping device.
That's an awful lot of nothing on which to base some lofty insinuations.
Interesting idea, yes, but the concepts are clearly not proven. As far as I can tell, none of these devices has yet been attached to the grid long enough to even test its actual capacity, much less make a real contribtution, much less prove technical viability, much less prove economic viability! It's basically still drawing-board level speculation based on failed prototypes.
No one has suggested that. But in a thread looking for real solutions, implying real potential exists in an invention that hasn't successfully left the drawing-board is wrong.
Define "successful". Because:
So they've "successfully" proven you can generate power from waves. That's old news and not really worth writing home about. Heck, *I* could do that in a month with a $10,000 budget! (But I'll take $5 million in venture capital funding, if you're offering). What they haven't done is demonstrate that you can run one of these for an extended period of time, generate a meaningful amount of power, or do it for a cost worth doing it for. These are the basic questions that separate a gee-that's-cool idea from a real commercial product and after decades of serious development, none of these generators has come anywhere close to moving from that stage to the "viable commercial product" stage. These are all just drawing board/developmental prototypes.
Also note that while the company's website says:
The Mk3PC was installed at Port Kembla on 26 February 2010, about 100 metres off the eastern breakwater of Port Kembla Harbour. It was connected to the grid and has been providing electricity since 19 March 2010 to customers of local retailer, Integral Energy.
...what they don't tell you is:
[May 17th]The landmark Oceanlinx wave energy system, the Mk3PC, sits underwater at the bottom of Port Kembla's eastern break wall after heavy seas ripped the unit from its moorings.
The 170-tonne structure, which was located 150m offshore, broke free of its pylons on Friday afternoon.
http://www.illawarramercury.com.au/...mbla-wave-generator-on-sea-floor/1831275.aspx
Oops. So it operated for less than 2 months before catastrophic failure. I'm really not that impressed by that. And this by a technology that is rated one of the top 10 renewable energy investments by the UN. That doesn't give much confidence for renewable energy!
1. Too materials intensive.
2. Too intriniscly expensive because of #1.
3. Very difficult to make robust enough to reliably withstand the forces of the ocean.
4. Power density far too low (related to #1).
My wife and I use as little energy as possible. Our small house is un-insulated with log walls, but it is really easy to heat with a small stove. We need a bit more refrigeration capacity for hot spells like this, but not a lot. Addressing broad energy needs needn't involve top-down regulations or enforced rationing. Education and cooperation can get us there.
And that's why my design was made out of empty 2 liter pop bottles, sticks, a long tube, discarded bicycle gear parts, and of course, duct tape.
I have to agree with you about pie in the sky ideas and the money that is being thrown at it.
I had an argument with someone at another forum. His idea was obviously perpetual motion, but I played along, feigning that I didn't understand his science. It was an oceanic device that worked off of differential pressure and different sized pipes. I told him that if it would work in the ocean, then it should work just as well in my 20 gallon fish tank. He said something to the effect that; it would only work if it were really big, and went really deep into the ocean. hmm.. and I bet he wanted investors too... unsubscribe...
But I wouldn't discount ocean wave energy based on a few failed attempts. We do after all, extract energy from other types of waves. We just need a simple method of harnessing this new one.
Uh, no.? I never said anything remotely about the "vast majority of the supply of energy". What basis do you have that this kind of technology can't make a significant impact? Thermodynamics says that it can.
I think its obvious that the quantity and capabilities of any pumping devices used is dependent upon the height and capacity of the reservoir and even more so location.
That's an awful lot of nothing on which to base some lofty insinuations. Interesting idea, yes, but the concepts are clearly not proven. As far as I can tell, none of these devices has yet been attached to the grid long enough to even test its actual capacity, much less make a real contribtution, much less prove technical viability, much less prove economic viability!
I disagree. Pumped-storage hydroelectric power plants are very common, reliable, and rather economical.
http://en.wikipedia.org/wiki/List_of_pumped-storage_hydroelectric_power_stations
The way I see it, only half of it. The water storage and power generation thing has been figured out. The only real issue I see is using waves to get the water into the reservoir. However, this isn't something that needs some major technological breakthrough, but rather just the right minded people to figure it out at a relatively low cost.
I don't think it is. If the world was full of successful solutions that made it well passed the drawing-board phase, then this thread wouldn't exist. Also, I never said this was something can and should be done, I just simply stated that it was "nifty".
So you're saying that we should just abandon the whole idea based on a few failures? Do you think we should have abandoned nuclear power after Chernobyl?
Also note that while the company's website says: ...what they don't tell you is: http://www.illawarramercury.com.au/...mbla-wave-generator-on-sea-floor/1831275.aspx
That is a little disheartening and I believe somewhat unethical on Oceanlinx part. However, I don't think you should can the idea just because someone couldn't properly design a foundation. I also think that generalizing your opinion of renewable energy based on the leadership of the UN is a bit haughty.
Reread post #572, where the originator of the concept quoted you in his introduction of the concept.
The fact that it hasn't yet proven to even work reliably after decades of serious attempts should be a clue, but read post #592 where I list four major obstacles to viability that are probably inherrent and likely unfixable. Consider this as an analogy: if the wind were only half as strong as it is, we'd have no wind power because it would be inherrently non-viable. Converseley, if the wind were twice as strong as it is, we wouldn't be having this conversation because wind would already be taking care of most of our energy needs. See, just saying there is enough overall energy in the wind doesn't tell you anything about how viable the recovery of that energy is. So no, the laws of thermodynamics say nothing whatsoever about the ability of this technology to have a "significant impact". You're confusing theoretical possibility with practical reality.
No, it isn't. One need not even be associated with the other, as now obviously we use pumped storage a lot, but not wave power. And wave power could be utilized without pumped storage. Until/unless wave power became a large producer of energy, there is no need to associate it with pumped storage: that's why none of the wave power projects yet mentioned have been associated with pumped storage.
Again, that has nothing whatsoever to do with wave power, as none of them are powered by waves. That was my objection. Bringing pumped storage into it was a red herring.
Again, two completely unrelated issues. It's like saying we're halfway to fusion powered cars because we have cars figured out. Just because it is half of the sentence, doesn't make it half of the problem.
Which.Is.The.Entire.Problem!
Clearly the concept is simple, yes - but that doesn't mean it has a chance of ever being economically viable. Again, see those 4 objections in post #592 and recognize the density problem discussed above with the analogy to wind.
Ehh - wind power has left the drawing board stage and has potential to make a serious impact, yet this thread exists.
You're not the one who originated the idea in this thread, but now you're putting an awful lot of energy into defending it.
No, I'm saying until one shows some real results, I'm not interested. My goal in starting this thread was to discuss practical ideas that might have a real shot at making a difference. I included only one research component in my original plan: fusion. Everything else in my plan is doable now. I'm not suggesting anyone abandon anything, but a research project is not a solution.
Nuclear power was already plenty viable before Chernobyl.
Yes nifty, and that it "Gets around the entire baseload problem"
Map wave height: (display region , and period )
http://www.lajollasurf.org/gblpac.html"
Andrew:smile:
Another important reason why I dislike ideas like tidal power is they are a distraction from solutions that actually are viable. This very example was provided as a counter to the absolutely correct claim that nuclear power must make up the vast majority of the solution to fossil fuel power. Not only is just plain wrong to assert that tidal power could make a substantial impact (given what is currently known), it is a dangerous distraction in a time when we need to be focused. Most people consider the reduction or elimination of fossil fuels to be an issue of extreme importance. But if they see and believe that there is a possibility that something like wave power could have a big impact, it could distract them away from supporting nuclear power, delaying the real solution.
russ_watters said:
... Most people consider the reduction or elimination of fossil fuels to be an issue of extreme importance. But if they see and believe that there is a possibility that something like wave power could have a big impact, it could distract them away from supporting nuclear power, delaying the real solution.
Choosing energy solutions should not depend on faith, but from a very rational economic choices, and ensure safety.
Fortunately, people can still create new solutions that could be better than traditional solutions.
Here are some other new solutions are proposed:
Version at the deep end
Version of the shallow water (my propose half- rotate pump)
For achievement in such this collecting tube of flow 1 m3/sec and 10 bar , requirement 12 pump wanted for transport water on according to following specification 100 m height too reservoir.
Pump reconciles, for simplification about normal piston, should have 0,6 m diameter, and 3 m of height. During average jump of rippling 2 m, it will give during one cycle for composite tube 0,5 m3 water pushed (S= 28 dcm2 H= 20 dcm (2 meter) = 560 dcm3 (liter). For set up flow 1 m3, TWO such pumps should pump for collecting tube.
Taking into consideration that the peak of wave used to the work is coming every 6 seconds one should multiply the score through 6
For proper fabrication of pressure on exit of pump ( set up 10 bar ), wanted proper swimmer is.
There is simple account surface of piston of pump will together page (S) x 100 surface of swimmer.
In my example, surface of piston of pump it 28 dcm2, it signifies that swimmer)should have 2800 dcm2. In order to swimmer had such surfaces, it must have 20 m diameter, and definitely 1 m of height. It needs one kit about 12 pumps 12 swimmers 20 m each diameter, or about dimension one swimmer 12 x28 m2= 336 m2.
For behaviour some reasonable spans, it is possible to accept, that for such array for production capacity 1 m3/sec 10 bar, wanted near 700 m2 place rippling sea .
Need for continuous supplying tank for power station theoretically 700 m3/s (716 MW , 100 m height ) requirement 700 x 700m2 = 490000 m2 rippling sea . It is theoretically only 700 m x 700 m !, when 2 m average heights of waves.
Here, mathematical enumeration same only:
To 1m3/ sec
1 m^3/sec 10 bar(H=100m ), 600 mm diameter pipe and piston pump, S= 28 dcm2 Hwave= 20 dcm (2 meter) = 560 dcm3 (litre) for 1 m3 need 2 piece . but period are 6 sec , sum 6x 2 = 12 piece pump .
S pump= 28 dcm2 , 10 bar, F =28 T, Hfloat >1m, S float ~~=2800 dcm2 (28 m2) , D float =~~20m
12 piece x28m2 =336 m2 ~~ =100m x 7m using area =700 m2
700 MW (700 m3/sec), H=100m
700 m2 x 700 MW = 350000 m2 . ~~700m x 700m area of wave with float
Maybe today people are and what they consider the recording and reproducing sound, then the best solution is Edisons Phonograph.
Regards Andrew:smile:
