You Will Not Tunnel Through a Wall - Comments
- Context: Insights
- Thread starter ZapperZ
- Start date
- Tags
- Wall
63 replies · 7K views
Derek Potter
- 509
- 37
No, I wasn't saying it is rigorously zero. I first argued that the phase difference made it rigorously zero because whatever emerges the other side is definitely not HP (maybe HP Sauce?) but then I noticed the re-coherence loophole. That's two independent FAPP zeros so I won't be buying shares in the Tunneling Transporter just yet :)stevendaryl said:I was sort of joking, but I don't see how one can say that any transition that doesn't violate a conservation law has rigorously zero probability, which is what I think you are saying about Harry Potter tunneling. Or maybe it's just a matter of definition--because of the phase differences, the event where Harry Potter is on one side of the wall one moment and on the other side another moment (and the wall remains unbroken) would not be considered "Harry Potter tunneling through the wall".
jeffery_winkle
- 33
- 13
I attended the April 2000 APS Meeting at Long Beach, CA, and even though I already graduated, I went to a lunch for undergraduates. There was a girl undergraduate physics major there, and she was relating a conversation she had with her mother, where she was trying to convince her mother that you could walk right through a wall, without leaving a hole in the wall behind you, without being injured, without damaging the wall. Quoting herself, she was saying, "MOM! It's true!" After the girl told the story, all the physics undergraduates at this lunch all had a big laugh, basically laughing at this girl's mother.
Part of the problem is that in undergraduate classes, they frequently approximate macroscopic objects as point particles. For example, if they are calculating the Earth revolving around the Sun, they approximate the Earth as a point particle. Well, obviously, the Earth is not a point particle. If they are calculating the probability of something barrier tunneling, they also approximate it as a point particle, which might be sufficient for an electron but not for a person. There are more differences between a person and electron than simply the difference in mass.
Aside from the stupendously low probability for this happening, let's say all the subatomic particles in your body, successfully barrier tunnel through the barrier. There is no reason to assume that after that, they would all reform the exact same atomic and molecular bonds that they had before. Even if you do successfully tunnel through the barrier, in the process, you will be converted into a plasma of subatomic particles.
This is also relevant to the black hole information problem. Let's say you have a bound state of two fundamental particles, say a positronium, which is a bound state of an electron and positron. Let's say, it is passing through the event horizon of a black hole. Well, one particle has to pass through first. So, then you have an electron inside the event horizon, and a positron outside the event horizon. Obviously, they can no longer be bound together when they are on opposite sides of the event horizon. Then the positron passes through the event horizon. After that, there is no reason to assume they will reform the same bond they had before. And that's for the most simple example of a bound state of two particles. Now imagine, if a person, which contains complicated organic molecules such as DNA, were to pass through the event horizon of a black hole. They will be converted into a plasma of subatomic particles simply by passing through the event horizon of the black holes. Obviously, all of these subatomic particles are not going to spontaneously reassemble into DNA after they are on the other side of the event horizon. Simply by passing through the event horizon of a black hole, you will be converted into a plasma of subatomic particles.
This was implicit even in the earliest formulation of black holes going back to Schwarzschild, but nobody seemed to recognize it because they were so used to approximating things as point particles, especially in general relativity. However, recently, this idea was independently rediscovered as a solution to the black hole information problem, where it was called the "firewall". Even after the firewall solution to the black hole information problem was proposed, some critics complained that it contradicted the general relativity assumption that "nothing special happens at the event horizon".
jeffery_winkle said:Let's say you have a bound state of two fundamental particles, say a positronium, which is a bound state of an electron and positron. Let's say, it is passing through the event horizon of a black hole. Well, one particle has to pass through first. So, then you have an electron inside the event horizon, and a positron outside the event horizon. Obviously, they can no longer be bound together when they are on opposite sides of the event horizon...
The physics of black holes is certainly beyond my expertise, but I don't think that's quite right. You can set up an approximate local inertial coordinate system in the vicinity of the electron-positron pair, and to first approximation, the metric looks the same as the Minkowski metric, and so the usual two-particle bound state wave function should be approximately correct for this coordinate system. So to first approximation, falling through the event horizon shouldn't do anything to the positronium. (I'm sure there are higher-order effects that will take into account the possibility of the electron falling through while the positron escapes capture...)
maline
- 436
- 69
Drakkith said:I don't think the probability of electron + proton is necessarily less than either proton + proton or electron + electron. My guess is that it depends on the type of barrier.
Okay, we have a bona fide disagreement here! Can anyone settle this?ZapperZ said:Because they won't get through the barrier with equal probability! Your right hand might go through, but your left hand stayed behind!
Derek Potter
- 509
- 37
No disagreement. If you don't mind going through the wall in little bits then combine the probabilities in the usual way. If you would prefer to get through in one piece, then the particles all need to tunnel together, which is a much lower probability. You may want them to retain their configuration too, making it even less likely, as even a small error here can have serious consequences.maline said:Okay, we have a bona fide disagreement here! Can anyone settle this?
https://paulfny.files.wordpress.com/2014/04/9d28b-insodeoutbaboon.jpg?w=400&h=217
Derek Potter
- 509
- 37
In this toy model, the tunneling events are independent. So you multiply the probabilities together.Drakkith said:What 'usual' way?
But you know this, so what are you getting at?
OCR
- 996
- 936
Derek Potter said:You may want them to retain their configuration too, making it even less likely, as even a small error here can have serious consequences.
Why yes, yes I can...maline said:Okay, we have a bona fide disagreement here! Can anyone settle this?
Does that make everything right ? ...Heisenberg compensators remove uncertainty from the subatomic measurements... further technology involved, includes computer pattern buffers to enable degrees of leeway in the processes.
DaveC426913
2025 Award
- 24,616
- 8,955
There is way too much fapping going on in this thread.
Derek Potter
- 509
- 37
No. You still have to get through the wall.OCR said:Why yes, yes I can... Heisenberg compensators remove uncertainty from the subatomic measurements... further technology involved, includes computer pattern buffers to enable degrees of leeway in the processes. Does that make everything right ? ......
OCR
- 996
- 936
Lol...Derek Potter said:![]()
- 32,819
- 4,724
Since I'm an experimentalist (and I was trained in tunneling spectroscopy measurement), I'll show you evidence on why single electron tunneling is much more prevalent (and thus, easier and significantly more probable) than a coherent 2-electron tunneling.
This manuscript (it was published in PRB) shows superconductor-insulator-normal metal (SIN) and superconductor-insulator-superconductor (SIS) tunneling spectroscopy. Pay attention to Fig 4 (near the end of the manuscript on Pg. 13).
http://arxiv.org/pdf/cond-mat/9807389.pdf
These are IV curves (current versus applied voltage across the tunnel junction) for SIS tunneling. The current that you see is dominated by single-electron tunneling. This is where the the Cooper pairs break apart, and single-electrons tunnel through the insulating layer, and then reforming Cooper pairs again on the other side. This is true EXCEPT for the zero-bias region. If you notice, there is a small signal in the current when there's no applied voltage, and no single-electron tunneling. This is the Josephson current, where it is a tunneling of the supercurrent consisting of the coherent Cooper pairs!
But look at the "constraints" here. The current is exceedingly small when compared to the single-electron tunnel current, and it is destroyed once one applies even a small bias to the junction. As someone who had measured and dealt with this current, it is EXTREMELY FINICKY, and can be destroyed very easily! In fact, if the tunnel barrier gets bigger, there is a point where I only observed single-electron tunneling, and not the Josephson current any longer. The Josephson current is extremely sensitive to "phase change", which is why it makes for a very sensitive detector in SQUIDs.
So in this set of measurements, there is a significant and distinct difference in the probability of single-electron tunneling versus 2-electron tunneling, over the same, indentical tunnel barrier! The single-electron tunneling is clearly more probable. In fact, as long as your barrier remains intact, you can crank up the bias potential as high as you want and get more and more tunnel current, while the 2-electron tunnel current is gone!
There are NUMEROUS complications and additional parameters when we deal with coherent tunneling of "composite" particles that are not described in the simple tunneling picture done in undergraduate QM classes. For example, we haven't even discussed the content of the tunneling matrix element which will be relevant as the complexity arises. I simply did not want this to go over the heads of people who haven't even done undergraduate QM classes, but I wanted to point out that many people who talk about macroscopic objects tunneling through a barrier are ignoring the FACT that composite particle/macroscopic object tunneling is extremely different and extremely complicated with compared to single-particle tunneling. The former has a lot more physics that must be considered, and it is not a simple one-to-one correspondence to the latter. The knowledge of single-particle tunneling does not translates as smoothly as one thinks when dealing with composite/macroscopic particles.
Zz.
Zz.
Derek Potter
- 509
- 37
@ZapperZ has just posted about the supreme importance of the coupling or entanglement of the particles, but initially we were using a toy model in which the tunneling events are independent. With fragile entanglements one might have to dig quite deep into the physics to discover whether a) we need to keep the coherence or b) whether in fact it doesn't matter as the experiment just turns the superposition into a mixture in the same way that the environment does all the time. That might be worth a separate discussion.maline said:I hope someone actually addresses the question before the thread gets closed!
Staying with the toy model, the composite probability is, practically by definition, the product of the individual probabilities. To define the probability properly we need to decide what time frame we allow ourselves. Presumably we don't want to experience too much of a lurch as we walk through the wall, so let us say t0 ~ 1 second. For simplicity I take this as the baseline probability P0 - the probability of all the particles tunneling within t0 seconds. But if you want all the particles to arrive "at the same time" so that you don't instantly dissipate, you are probably talking about times that are short on the scale of your own Plank period, leaving a time frame t1~ 10-40seconds. A little thought shows that the probability P1 is then (t1/t0)(N-1)P0 where N is the number of particles. This way P1/P0 just depends on how many particles there are, not on the number of types as they have already been accounted for in the calculation of P0.
Finally, a totally different calculation is needed if the experiment is left to run until you have completely tunneled. ZapparZ's scenarios of splinching his left hand assumes that he is through the wall. So in these cases, the probability is defined to be unity. However, the task of calculating the probability of arriving intact is rather different. I *think* one would have to use a different time slot for P0, not ~ one second, but the typical tunneling time for all the particles, say T3 seconds (so that T3.P0 = t0) Then the factor of t0/t1 ~ 1040 becomes t3/t1 and once again the probability does not depend on there being different types of particle.
However ZapperZ's argument seems very compelling at first sight - if, say, the neutrons tunnel much faster than the protons, then the chances of everything arriving at the same time are remote. I believe that the argument is actually incorrect: different particle types are taken care of in the calculation of P0 so what ZapperZ has illustrated is not that the probability of a successful tunnel is reduced by there being different types of particle but that most of the failures will show splinching because of the different types of particle.
- 2,136
jeffery_winkle said:Aside from the stupendously low probability for this happening, ...
“So you’re telling me there’s a chance!” — Lloyd (from "Dumb and Dumber", a documentary on trends in modern physics)
maline
- 436
- 69
My point exactly. Zapper, any comment on this point?Derek Potter said:ZapperZ's argument seems very compelling at first sight - if, say, the neutrons, tunnel much faster than the protons, then the chances of everything arriving at the same time are remote. I believe that the argument is actually incorrect different particle types are taken care of in the calculation of P0 so what ZapperZ has illustrated is not that the probability of a successful tunnel is reduced by there being different types of particle but that most of the failures will show splinching because of the different types of particle.
- 32,819
- 4,724
maline said:My point exactly. Zapper, any comment on this point?
No, because I have no idea what that meant.
Are you still questioning this even when I actually showed experimental evidence?
Zz.
Derek Potter
- 509
- 37
Lloyd was onto something. In MWI, it's not a stupendously low probability, it's a dead certainty. In some worlds.DrChinese said:So you’re telling me there’s a chance!” — Lloyd (from "Dumb and Dumber", a documentary on trends in modern physics)“jeffery_winkle said: ↑
DaveC426913
2025 Award
- 24,616
- 8,955
No, that simply moves the probability downstream in a ... philosophically whimsical way. It is simply a stupendously low probability for any of the Worlds that it happens in, to be the one you're in.Derek Potter said:Lloyd was onto something. In MWI, it's not a stupendously low probability, it's a dead certainty. In some worlds.
I put one thousand small boxes in front of you. In one of those boxes is $500. You have a 1:1000 chance of being $500 richer. Yay.
-or-
I put one thousand boxes in front of you. In one of the boxes I put a gold envelope. In the other 999, I put a white envelope.
Inside the gold envelope I put $500, while the white envelopes are empty. If you get the gold envelope, you are 100% guaranteed of getting $500.
Now what are your chances of being $500 richer?
Derek Potter
- 509
- 37
Dead certain in the world in which I pick gold.DaveC426913 said:Now what are your chances of being $500 richer?![]()
- 2,136
Just to be clear... my reference to Lloyd was not intended as a favorable one.
As ZapperZ says, the answer should be: it doesn't happen. He has shown why an H2 molecule will not ever tunnel through a wall in any universe. I think it is clear that anything larger won't either. Saying it is theoretically possible is meaningless in this context.
Derek Potter
- 509
- 37
I think everyone understood that.DrChinese said:Just to be clear... my reference to Lloyd was not intended as a favorable one.
Hmm. I can see where he says it is much more complicated, and fragile, and unlikely than a simplistic model would suggest but I can't see anywhere that he claims the probability is precisely zero.DrChinese said:As ZapperZ says, the answer should be: it doesn't happen. He has shown why an H2 molecule will not ever tunnel through a wall in any universe.
kmm
- 188
- 15
Thanks for posting this. Very clear explanation.ZapperZ said:Since I'm an experimentalist (and I was trained in tunneling spectroscopy measurement), I'll show you evidence on why single electron tunneling is much more prevalent (and thus, easier and significantly more probable) than a coherent 2-electron tunneling.
Zz.
Dr_Zinj
- 95
- 27
So.
Probability of a100 kg mass of liquid H2O (100 cm x 100 cm x 10 cm) at 4 deg C tunneling through a 10 cm barrier of an infinite size sheet of copper is greater than zero; but probably much less than 1/10^82. (10^82 is on of the approximations of the number of particles in the universe.) For comparison, your odds of winning the Powerball with anyone ticket are about 1/10^7.
Don't plan on having any "Harry Potter" or "Men Who Stare At Goats" moments during your lifetime.
DavidLloydJones
- 8
- 2
I.I. Rabi did a thesis in school on the proposition "How likely is it that a brick will spontaneously leap one foot into the air?" I think he did his undergrad at Buffalo, which would account for that archaic "one foot" thing.
I remember the answer as being "It'll happen about once in every 64 times the age of this universe." On the other hand my memory may be fooling me; it may have been once in every 10^64 times the age of the universe.
In speeches he also took to giving out the quantum likelihood of a Mack truck making it through a gap a foot too narrow. This is rather less likely than the jumping brick.
I think, however, there may be a solution for people who need a lot of bricks lifted or trucks driven into narrow places. An electric hoist works for bricks, and there are some surprisingly skilful drivers of Mack trucks -- though they do need spaces an inch or so wider than the truck.
Where hoists and skilled drivers are not available, or for spaces actually narrower than the truck, I would recommend that you get Deepak Chopra teamed up with Russell Targ, he of the Advanced Studies Institute at University of Texas, and very knowledgeable about quantum mind-bending of spoons.
They have access to more powerful quantum methodology than people like I.I. Rabi, a mere Nobel laureate, recognized in 1944 for his discovery of nuclear magnetic resonance. Bricks in seconds, trucks in inches: Ommmm.
-dlj.
-dlj.
Jeff Rosenbury
- 746
- 145
Does entanglement extend to tunneling?
My understanding of entanglement is that it causes some dependence (usual examples are full dependence) of one random variable with another.
So is it possible to entangle particles so if one tunnels, the other one must, or at least be more likely to tunnel?
Not that it really affects the answer. The difference between 1 in 10^82 and 1 in 10^164 may be huge numerically, but it seems of little practical significance.
Still, it's an interesting question about the nature of the universe.
- 32,819
- 4,724
Jeff Rosenbury said:Does entanglement extend to tunneling?
You are forgetting that in the SIS tunneling example that I had given, the electrons in the Cooper pair are entangled with each other. So they make up the Josephson current.
Zz.
DaveC426913
2025 Award
- 24,616
- 8,955
There is.DavidLloydJones said:I wish there were an edit function available
DavidLloydJones
- 8
- 2
Jeff Rosenbury said:The difference between 1 in 10^82 and 1 in 10^164 may be huge numerically, but it seems of little practical significance.
I think you're being a little cavalier about that factor of two in there.
Never forget the businessman who made his millions in Popsicles, or whatever it was: "I make them for a nickel and I sell them for a dime, and from that one percent difference I have become rich."
-dlj.
DavidLloydJones
- 8
- 2
Yup. Found it. But thanks, Dave.DaveC426913 said:There is.
- NTesla
- · Replies 7 ·
- Introductory Physics Homework Help
- Replies
- 7
- songoku
- · Replies 4 ·
- Quantum Physics
- Replies
- 4
- RUTA
- · Replies 395 ·
- Quantum Physics
- Replies
- 395
- Greg Bernhardt
- · Replies 132 ·
- Quantum Physics
- Replies
- 132
- A. Neumaier
- · Replies 38 ·
- Quantum Physics
- Replies
- 38
- A. Neumaier
- · Replies 2 ·
- Quantum Physics
- Replies
- 2
- Urs Schreiber
- · Replies 9 ·
- Quantum Physics
- Replies
- 9
- Urs Schreiber
- · Replies 15 ·
- Quantum Physics
- Replies
- 15
- Demystifier
- · Replies 118 ·
- Quantum Physics
- Replies
- 118
- Urs Schreiber
- · Replies 6 ·
- Quantum Physics
- Replies
- 6
