Can Fringes Exist with Sine Value Greater Than 1 in Young's Double Slit Formula?
In Young's double slit experiment, the relationship defined by the equation d sin θ = m λ indicates that if the slit separation (d) is less than the wavelength (λ), the sine value can exceed 1. This scenario leads to a situation where interference occurs, but total cancellation does not happen, resulting in a drop in amplitude rather than distinct fringes. The formula remains valid for d < λ, as it describes the positions of zeros, which do not exist for closely spaced slits. The discussion emphasizes the importance of understanding phase differences and the behavior of omnidirectional sources in this context.
  • Understanding of Young's double slit experiment
  • Familiarity with wave interference concepts
  • Knowledge of phase differences in wave mechanics
  • Basic principles of antenna theory
  • Study the implications of d < λ in wave interference patterns
  • Research the mathematical derivation of Young's double slit formula
  • Explore the concept of omnidirectional sources in antenna theory
  • Learn about the diffraction patterns produced by single and double slits
Students of physics, optical engineers, and anyone interested in wave mechanics and interference patterns in experimental setups.
terryds
In Young's double slit formula, the equation is
d sin \theta = m \lambda
Which means that
sin \theta = m \lambda / d
But, what if d < \lamda so the sine value becomes greater than 1?
Will there be any interference?
Science news on Phys.org
I'm finding problem understanding your question, what i know is that the path difference = d sinθ
and for constructive interference d sinθ =n λ
where n is an integer.
So, what happens if the distance between slits is much smaller than the wavelength?
Which means that
If d is small, there will be no total cancellation but interference will still cause a drop in the amplitude as the angle increases.
So, does the formula still valid for d < lambda?
Why will there be no total cancellation? I mean, you mean the cancellation caused by the difraction? Or, what? Please explain it.
Thanks
you won't see the fringes no more
It is valid because it only describes the positions of zeros and there is no zero for closely spaced slits.
The formula is based on a simplified situation with infinitely narrow slits (omnidirectional individual sources)-more like what you get with two co-phased radio frequency dipoles than two slits. If the sources are just greater than λ apart, there will only be a single zero, which will be at nearly 90° off beam. As the spacing gets narrower still, this zero will pass through the 90° direction and disappear. In any case, the beam (the diffraction you are referring to??) pattern of each 'real' single slit will have a zero at 90° or greater. Two dipoles will work fine, though, as a model because they are truly omnidirectional, individually.
If the slits are too close together, the phase difference between the waves from the two sources can't be as great as π and so you can't have complete cancellation at 90°. Nevertheless, if there is a reflex angle between the two E vectors, the resulting amplitude will be noticeably lower than where they add and you will get a minimum but the zero is, as you say, at an invalid angle for the formula. I tried a brief search for a suitable diagram of the patterns of two omnidirectional sources on Google but I could find nothing. It's the sort of picture you get in books on antenna theory.
I got to know this stuff from antenna theory, rather than optics and it's actually much more approachable (imo).
The formula is based on a simplified situation with infinitely narrow slits (omnidirectional individual sources)-more like what you get with two co-phased radio frequency dipoles than two slits. If the sources are just greater than λ apart, there will only be a single zero, which will be at nearly 90° off beam. As the spacing gets narrower still, this zero will pass through the 90° direction and disappear. In any case, the beam (the diffraction you are referring to??) pattern of each 'real' single slit will have a zero at 90° or greater. Two dipoles will work fine, though, as a model because they are truly omnidirectional, individually.If the slits are too close together, the phase difference between the waves from the two sources can't be as great as π and so you can't have complete cancellation at 90°. Nevertheless, if there is a reflex angle between the two E vectors, the resulting amplitude will be noticeably lower than where they add and you will get a minimum but the zero is, as you say, at an invalid angle for the formula. I tried a brief search for a suitable diagram of the patterns of two omnidirectional sources on Google but I could find nothing. It's the sort of picture you get in books on antenna theory.
Will there be any fringes then?
If there fringes then there would have to be zeros, wouldn't there? This is just one very broad maximum.
We're talking a slit separation of only 600nm or so.
  • · Replies 20 ·
9K
  • · Replies 0 ·
  • · Replies 36 ·
