Young's Modulus for Two Materials connected
The discussion focuses on calculating the change in length of a composite rod made of Aluminum and Steel under tensile stress. Given that the Aluminum section is twice as long as the Steel section and the total change in length is 1mm, the user derives the equations based on Young's Modulus. The equations are manipulated to relate the forces and changes in length for both materials, leading to the conclusion that stress is uniform across the rod. The user confirms that setting the forces equal and canceling the area is a valid approach to solve the problem.
  • Understanding of Young's Modulus and its application in material science
  • Basic knowledge of tensile stress and strain calculations
  • Familiarity with algebraic manipulation of equations
  • Concept of composite materials and their mechanical properties
  • Research the derivation of Young's Modulus for different materials
  • Learn about stress-strain relationships in composite materials
  • Explore methods for calculating forces in multi-material systems
  • Study the effects of varying cross-sectional areas on tensile strength
Mechanical engineers, materials scientists, and students studying material mechanics who are interested in understanding the behavior of composite materials under stress.
thursdaytbs
If Aluminum and steel are connected as one rod, and are attached to the wall and is pulled upon. How would the change in length for each material of the rod be calculated? I'm given that the Aluminum section is twice as long as the steel section, and the total change in length of the whole rod is 1mm.
So far, I've said:
F = Y(delta-L / L-naught)A + Y(delta-L / L-naught)A
*Where, the first part is for Aluminum, and the Second part is for Steel.
Manipulating this equation I got:
(2Fx)/A = (6.9E10)(delta-Laluminum) + (4E11)(delta-Lsteel)
and, delta-Aluminum + delta-steel = 0.001m
*where x = the length of steel, therefore aluminum = 2x.
This is where I'm stuck. I dont' know the Force applied, or the Area of the rod. What can i do? Thanks in advance for any help.
OK another thing I've thought up is saying...
F = Y(delta-Laluminum / L-naught)A
and
F = Y(delta-Lsteel / L-naught)A
since force is equal throughout?
Then set the two equations equal to one another, where A cancels out?
Can anyone confirm this is a way of doing it?
Looks good to me. The stress (F/A) is the same throughout the rod. You'll also need to use the other facts given regarding total change in length and the ratio of the two original lengths.
awsome, thanks a lot.
  • · Replies 19 ·
