Zero crossing detector for Arduino using 4N35 optocoupler
The discussion revolves around designing a zero crossing detector for an Arduino using the 4N35 optocoupler. Participants explore various aspects of the design, including component selection, voltage considerations, and circuit configurations. The conversation includes technical details related to AC voltage handling and the implications of using different optocouplers.
  • One participant is designing a zero crossing detector using a 6-0-6 transformer and a 4N35 optocoupler, questioning whether to rectify the input.
  • Another participant suggests using a LED in reverse parallel with the optocoupler for protection and notes that the circuit will detect a time range around the peaks rather than the crossings.
  • Some participants discuss the implications of using a safety isolation transformer and the necessity of an optocoupler for fault protection.
  • Concerns are raised about the reverse voltage ratings of the optocouplers, with suggestions to use a 5V transformer instead of 6V.
  • Participants debate the effectiveness of using resistors for limiting voltage and discuss alternative methods such as anti-parallel diodes and bi-directional opto-couplers.
  • One participant provides a detailed analysis of the peak voltage from the transformer output and suggests using a bridge rectifier and a voltage divider to manage the voltage levels.
  • There is a disagreement regarding the interpretation of voltage specifications, with some asserting that RMS values are not applicable to diode specifications.
  • Participants consider switching to the H11AA1 optocoupler, discussing its operational characteristics compared to the 4N35.
Participants express multiple competing views regarding the design choices, voltage handling, and component selection. There is no consensus on the best approach to limit voltage or the necessity of certain components.
Participants mention various assumptions about voltage levels, the need for rectification, and the characteristics of different optocouplers. The discussion reflects a range of design considerations that may affect the final implementation.
This discussion may be useful for individuals interested in electronics design, particularly those working with Arduino projects involving AC signal processing and optocoupler applications.
Wrichik Basu
Insights Author
TL;DR
Can the 4N35 optocoupler handle 6 VAC in its input, or do I need to rectify it to DC?
I am designing a zero crossing detector for Arduino using the 4N35 optocoupler. This is just a small part of a large project. I haven't bought the components yet, so do not ask me for readings. Everything is in the planning phase now.
My input will be a 6-0-6 transformer (220V to 6V step down).
I was having a look at this website where they have controlled an AC fan using an Arduino and a TRIAC. They have fed the 9 VAC output from their transformer directly to their 4N25 optocoupler:
In https://forum.allaboutcircuits.com/threads/zero-crossing-with-4n25-issue.138690/, they have first rectified the AC to DC, and then fed it to the optocoupler (don't look at the input; I will be using 6 VAC):
The above circuits use 4N25, but I believe using a 4N35 won't create any problem. Do I need to rectify the input to the 4N35, or can I directly feed it 6 VAC?
Well, 4N24 and 4N35 both are with low reverse voltage for this, I think.
I would keep the transformer only, but put a LED in reverse, parallel with the opto.
Or a different opto, maybe with dual LEDs on the input side (something from here, for example).
I guess you are aware that it'll detect a time range around the peaks, not the crossings?
Yes, I am aware of that. I need the time range around the peaks because I will be using that information to switch on a TRIAC for a short period of time, thereby dimming the appliance connected to the TRIAC. Similar to what has been said in the first website linked in the OP.
It seems that if there is a safety isolation transformer, it may not be necessary to use an optocoupler, but certainly the optocoupler can serve as a secondary fault protection.
As mentioned in response 2, please make sure that the reverse input voltage does not exceed the rated value.
The rectified waveform is very different from the original sinusoidal wave waveform, so the two corresponding output waveforms are also very different. It depends on your design and the processing power of the Arduino hardware and software.
Yes, I will see to that. Maybe I will use a 5V transformer instead of 6V.
That's what I was thinking about, and the two designs are basically not interchangeable. Thanks for the clarification.
You have to work with the peak voltage instead of RMS
5V is still too much if you don't limit the voltage by some other means.
Fine. Resistors are always handy in such cases.
Be careful, serial resistors are no good for limiting maximal reverse voltage load.
Then how do I limit the voltage? (I can't seem to find a 5V transformer, so I have to use a 6V transformer.)
The absolute maximum reverse voltage spec for the input LED is 6V. You can put in an anti-parallel diode to clamp this at about 0.7V. Read the data sheet for any IC you might use.
You might consider bi-directional opto-couplers like these too:
https://www.vishay.com/docs/83608/h11aa1.pdf
I think the whole HV side could be a resistor and a bidirectional coupler. If the pulse is too short you could insert back to back zeners in series with the resistor to increase the off time. Because there is always a current path, the only HV will be across the resistor.
You may find some with a darlington output which may allow you to have less power dissipation in the HV resistor. Like this: https://datasheet.octopart.com/IL755-1-Vishay-datasheet-10103.pdf
I am actually buying both types. I have to do some testing to see which one actually suits my case. My final aim is to use a triac as a dimmer — I will use a MOC3021 triac driver, and I need to detect the zero crossings because I will fire the triac driver accordingly for a dimming effect.
The two websites from where I buy things don't have an optocoupler with darlington output.
Not even 4N33 et. al.? I thought those were everywhere. You could use two in parallel for full wave.
4N35 is available, and it's already in my cart. H11AA1 is also available.
The following snippet is from a 4N35 Vishay Datasheet (https://www.vishay.com/docs/81181/4n35.pdf)
Note that 6Vac is an rms value. The peak voltage would be at 6√2 = 8.485 Vpk. Note that we are talking of ac voltage, and based on your schematic:
https://www.physicsforums.com/attachments/273618
you will be subjecting your 4N35 to 16.97Vpk-pk. I suggest you put a bridge rectifier circuit at transformer secondary to limit the voltage to 8.485Vpk, and further lower the secondary peak voltage to less than 5V by doing a resistive voltage divider. The good news is that even with these modifications, the integrity of your pulse output is not compromised. it will still fire at the zero crossing.
P.S. i implemented a similar circuit to this in my college days for a friend.
No! It is an instantaneous value. You won't see RMS voltage spec on a diode (maybe on a diode circuit, or application). RMS is only useful for AC signals and specifying an AC voltage limit on a diode is, at best, confusing. In any case the issue is damage to the PN junction which can happen very quickly.
I meant 6Vac as the output of the transformer in the OP's schematic.
though now that i read it more carefully, OP did say:
so it's basically a transformer with two secondary windings, only one of which would be connected to 4N35. So scrap what i said about 16.97V pk-pk. Though it still is 6Vac, and therefore 8.485V pk-pk.
Scrap the bridge rectifier, but the voltage divider is still necessary to bring that 8.485Vpk-pk down to 5Vpk-pk.
Yes, I see that now. Sorry, I misunderstood you! That was covered pretty thoroughly earlier in the thread.
I am actually thinking of switching to H11AA1 instead of 4N35. My circuit is not yet complete, but am I correct in saying that the H11AA1 will detect a time around the crossing rather than the peaks?
Either will work, it's just that the programming will be slightly different.
The 4N35 will be 'On' whenever the voltage is above about +1 Volt.
The H11AA1 will be 'On' when the voltage is above about 1 Volt of either polarity.
That's about 7 to 10 degrees from zero crossing.
For the 4N35 the coding would be:
Detect a change of input
If changed from 'Off' to 'On', a positive going Zero crossing just occurred
If changed from 'On' to 'Off', a negative going Zero crossing is about to occur
For the H11AA1:
If is 'OFF' you are within 10 degrees of a Zero crossing in either direction
Cheers,
Tom
Have you thought of using a MOC3041 zero crossing opto triac?
I'm not sure this would help much. IIRC, he wants to make a phase angle dimmer circuit and needs zero crossing information to know when to turn on a thyristor, which will then self commutate at the zero crossing.
Exactly, you are right. 👍
  • · Replies 63 ·
  • · Replies 38 ·
  • · Replies 17 ·
