Zero Force from 3 charges placed at the vertices of a Triangle
43 replies · 5K views
Charles Link said:
The top part of 29 is good. I agree with 6.20. The other solutions are meaningless. To get the other point, it is going to be slightly below the base. You are going to need to write new expressions with the new scenario to find this other point.
Did you see the other solution when I switched the terms around in the denominator of the right hand side term in post #29? Does this make sense?
It could be a mathematical coincidence. The answer might agree with the right answer, but you need to work through the calculation to find the second point. You should be able to see qualitatively before you compute the exact location, why the second point is just slightly below the base.
Alright.
I'm not too sure what new expressions I should write, or how I should approach it. I thought that the expressions I created would give me the field for an arbitrary point in space.
Suggestion for you on this one (the second point) to make it easier: Call the distance below the base positive ## y ##. The distance from the negative charge is then ## y+\sqrt{3} ##. With the practice you had from the first part, it should be simple matter to write ## \frac{1}{(y+\sqrt{3})^2}=2\frac{y}{(...)^{3/2}} ##.
Charles Link said:
One thing that is confusing is where the origin is for the distance ## y ##. The OP might be using the base of the triangle=in my post 22, perhaps that is why my expressions are different.
Edit: In the latest post, I think the OP needs to be consistent with his triangle=if you use ## 1 ## for the distance of half the base, then the altitude is ## \sqrt{3} ##.
Well spotted. That error crept in going from post #16 to post #20.
cwill53 said:
I was using the base of the triangle as the origin.
In my original equations, I had got one of the points correct when I put it in Wolfram Alpha. I just don't see why I didn't get the other correct point.
That would be because you did not use the absolute value in the denominator.
In the original equation it was of the form ##(x^2)^{\frac 32}##, which is always positive. When you simplified it to ##x^3## it was wrong for negative x.
Correct me if I am wrong, but I think there is only one solution above the apex of the triangle. The other solution is just below the base. You need to rewrite the equations for this second point.
Waiting to hear from the OP to see if he gets the correct expression per post 34. The solution for ## y ##, and ## y ## is small, can be estimated by using ## \sqrt{3}+y \approx \sqrt{3} ##, and ##y^2+1 \approx 1 ##.(Note: This estimate is somewhat poor. I think the correct answer might be what the OP mentioned in post 29 at the bottom).
I tried making expressions, but when I put them in Wolfram I did not get what I should have gotten.
I treated the point below my axis P(0,y) as just a point with a positive valued y, as it really shouldn't matter as long as I keep the signs consistent with each other.
The simplifications made for the variables were:
##a_1=1m,q_1=q_2=1C,q_3=-1C##
So again,
$$\vec{E}(x,y)=\frac{1}{4\pi \varepsilon _0}\sum_{j=1}^{N}\frac{q_j\hat{r}_{oj}}{r^{2}_{oj}}=\frac{1}{4\pi \varepsilon _0}\sum_{j=1}^{N}\frac{q_j\vec{r}_{oj}}{r^{2}_{oj}}\frac{1}{\left \|\vec{r} \right \|}$$
$$\vec{E}_1(x,y)=\frac{1}{4\pi \varepsilon _0} \frac{q_1\left \langle a_1,y \right \rangle}{(\sqrt{(a_1)^2+(y)^2})^3}$$
$$\vec{E}_2(x,y)=\frac{1}{4\pi \varepsilon _0} \frac{q_1\left \langle -a_1,y \right \rangle}{(\sqrt{(a_1)^2+(y)^2})^3}$$
$$\vec{E}_3(x,y)=\frac{1}{4\pi \varepsilon _0} \frac{q_3\left \langle 0,\sqrt{3}+y \right \rangle}{(\sqrt{(\sqrt{3}+y )^2})^3}$$
$$\vec{E}(0,y)=k_{e}(\frac{2y}{(a_1^2+y^2)^{\frac{3}{2}}}+\frac{-\sqrt{3}-y}{\sqrt{(y+(\sqrt{3}))^2}^3})$$
I set this equal to 0 and solved for y but got the wrong answer.
There are a couple of things going on with these equations that are clumsy. One thing that is complicating things is that for the single charge, instead of using inverse square, you are complicating it with a linear term divided by a cube. For the first point, you can simply write: ## \frac{1}{(y-\sqrt{3})^2}=2 \frac{y}{(y^2+1 )^{3/2}} ##. If you then square everything in the algebra, you can get extraneous solutions. In addition, @haruspex pointed out why you were getting an incorrect expression when the ## x ## was negative. That's why it's really simpler to use a second expression to get the second point=there are otherwise too many minus signs floating around that should be with an absolute value sign.
Note: If you change the minus in the first denominator to a plus (and y going downward is positive), I think that gives you the expression for the second point. The solution really is kind of simple.
Actually, I take that back. I just forgot to put the y in 2y on Wolfram :smile:
I ended up getting BOTH -6.20448 and .14629 as solutions. It seems that if I used THIS approach initially I would've got BOTH answers.
How is that equation different?
See post 40. Ideally a single expression is all you need to get both solutions, but this one gets complicated by absolute value signs, etc. I think if you square both sides of the expression in post 40, you do get the second point ## y=-.146 ## as well.
Ok, we were saying the same thing in two different ways. Where I expressed it as the equation being wrong, you expressed it as needing two versions of the equation.
