What if Planck Constant is Zero? Effects in Quantum Explored
If the Planck constant (h) is zero, the Heisenberg Uncertainty Principle ceases to exist, allowing both momentum and position of a particle to be known simultaneously. This scenario leads to a breakdown of quantum behavior, resulting in classical behavior where energy becomes continuous and momentum is precisely zero. The wave equation for any particle becomes trivial, yielding no meaningful solutions, as the de Broglie wavelength also approaches zero. The implications of h=0 fundamentally alter the nature of quantum mechanics, reducing it to classical mechanics.
  • Understanding of the Heisenberg Uncertainty Principle
  • Familiarity with quantum mechanics concepts
  • Knowledge of wave functions and the Schrödinger equation
  • Basic grasp of classical mechanics principles
  • Research the implications of the Heisenberg Uncertainty Principle in quantum mechanics
  • Study the Schrödinger equation and its solutions in quantum systems
  • Explore the transition from quantum to classical mechanics
  • Investigate the role of the Planck constant in quantum theory
Physicists, quantum mechanics students, and anyone interested in the foundational principles of quantum theory and its relationship to classical mechanics.
fricke
What is the effect in quantum if Planck constant is zero?
Here are some points that I could think of:
if Planck constant is zero, the Heisenberg Uncertainty Principles will become zero, therefore either momentum or position of a particle can be known exactly.
if Planck constant is zero, both momentum and position can be known simultaneously.
if Planck constant is zero, all quantum behavior will become classical behavior, where energy will become continuous, momentum will become zero (which means it is known exactly) and etc.
So, are my points correct? and please do tell if there are other points for "if Planck constant is zero".
Thank you.
Either momentum or position can be known exactly even if the Planck constant is not zero.
Those two statements are correct.
Hmm, so, if Planck constant is zero means that there is no uncertainty in both momentum and position, right? Does it mean if either one of momentum or position can be known exactly, therefore the other one is not known exactly?
Note the bolded "not" in my sentence that you quoted.
Yes, I noted that.
I was asking the understanding of if the Planck constant is zero. :)
If h=0, then both momentum and position can simultaneously be known exactly.
The idea of quantization of most physical quantities breaks down if ##h=0## ; the deBroglie wavelength associated with any particle becomes 0, the canonical commutation relation becomes ##[x,p] = 0## (the commutation of the position and momentum operators removes the "weird" effects in QM, and reduction to classical mechanics follows), and the wave equation of any particle takes the trivial and non-renormalizable solution of ##Ψ (r,t) =0 ## (there is no wave equation for any particle if h=0; this of course agrees with the fact that the deBroglie wavelength becomes 0). From this, you can also derive the fact that the Heisenberg 'uncertainty' vanishes.
PWiz said:
the wave equation of any particle takes the trivial and non-renormalizable solution of Ψ(r,t)=0
That is actually not quite true. If the limit h=0 is applied in the appropriate way, the complex Schrödinger equation reduces to two decoupled real classical equations. One of them is the classical Hamilton-Jacobi equation, which is a wave equation for a classical particle. The other is the continuity equation, which can be interpreted in terms of classical statistical mechanics.
I don't think the OP is talking about a limit. As I read it, the OP is asking what would happen if ##h## assumed the exact value of 0, not what would happen if it tended to 0. If ##h=0## , then the terms ##iħ \frac {∂Ψ}{∂t}## and ##\frac {-ħ^2}{2m} ∇^2## (in the Hamiltonian) will drop out, and in that case, Schrödinger's (time-dependent) wave equation would become ##V Ψ (r,t) = 0## , which can only be true for any potential function if ##Ψ (r,t) = 0 ## for all r and t.
  • · Replies 21 ·
  • · Replies 19 ·
  • · Replies 36 ·
  • · Replies 32 ·
