Zeroth Law of Thermodynamics
  • Thread starter Thread starter Kakashi
The discussion revolves around the Zeroth Law of Thermodynamics and its implications for defining temperature in relation to gas behavior, particularly through Boyle's Law. Participants explore the relationship between pressure, volume, and temperature, as well as the concept of thermal equilibrium in gas systems.
  • One participant questions the necessity of bringing systems A, B, and C into thermal contact to study the relationship between pressure and volume, suggesting that insulation could suffice for Boyle’s law experiments.
  • Another participant highlights that the relationship $$PV=Constant$$ is strictly valid only in the limit of zero pressure, prompting inquiries about the origin of this limit.
  • Concerns are raised about the appropriateness of taking the limit as pressure approaches zero, with one participant arguing that pressure has physical dimensions and should not be treated as a limit in that manner.
  • Some participants propose that the relationship holds precisely for ideal gases, where lower pressures make real gases behave more like ideal gases, and draw parallels to properties of liquid mixtures at infinite dilution.
  • There is discussion about whether the definition of temperature as $$T=\frac{\lim_{P \to 0} (P \bar{V})}{R}$$ implies that temperature cannot be measured for systems with finite volume.
  • One participant interprets the textbook definition, stating that as pressure decreases, the molar volume increases, and $$\frac{P\bar{V}}{R}$$ approaches temperature.
  • Another participant notes that while it is theoretically possible to define temperature based on Boyle's law, practical issues arise regarding accuracy and convenience in measurement.
Participants express differing views on the validity and implications of the limit of zero pressure, as well as the practicality of measuring temperature in finite volume systems. There is no consensus on the necessity of thermal contact for studying gas behavior or the interpretation of the limit in the context of real gases versus ideal gases.
Limitations in the discussion include the dependence on definitions of pressure and volume, the assumptions regarding ideal versus real gases, and the unresolved nature of how temperature can be accurately defined and measured in various conditions.
Kakashi
Consider three systems A,B,and C each containing a fixed amount of gas, whose equilibrium state is specified by two independent intensive variables. We have only a qualitative notion of temperature through our senses, and the zeroth law allows us to define temperature quantitatively.
Assume A,B, and C are each initially in equilibrium, so their intensive variables are uniform in space and constant in time. If we bring them into thermal contact, heat transfer will occur. Suppose this heat transfer takes place very slowly. During the process the systems may not be in equilibrium, but eventually A,B, and are in thermal equilibrium with one another. We associate some measurable property (such as color, electrical conductivity, or expansion) with temperature in order to signal when thermal equilibrium has been reached and whether temperature is changing or remaining constant.
Once thermal equilibrium is established, the systems are at the same temperature. If we now change the pressure of one system while maintaining thermal equilibrium, only one additional intensive variable is needed to specify the state. The curve of all pressure–volume pairs at fixed temperature is an isotherm.My confusion is the following: what is the purpose of bringing A,B, and C into thermal contact in the first place? Is it simply to fix the temperature so that the relationship between pressure and volume can be studied? Could we not instead insulate the system and directly carry out Boyle’s law experiments?
My textbook then relates this discussion to Boyle’s law. Historically, Boyle studied compressed air at (approximately) constant temperature using a mercury column in a U-tube. When Boyle plotted the reciprocal of the pressure versus the volume of trapped air, the data lay close to a straight line with an intercept near zero. However, the book states that the relation$$ PV=Constant $$ is only strictly valid in the limit of zero pressure.Where does this “limit of zero pressure” come from?
As I understand it, if the volume is increased slowly while maintaining thermal contact, the temperature remains constant and the pressure decreases. At sufficiently small pressures, the plot of volume versus 1/P approaches a straight line, and this behavior is independent of the gas used (for a fixed amount of gas). Hence the constant in Boyle’s law depends only on temperature.This motivates writing
$$ PV=f(T) $$ where f(T) is an unspecified function that depends on T.
Why is it then justified to choose this function to be linear and write$$ \frac{P_{1}V_{1}}{T_{1}}=\frac{P_{2}V_{2}}{T_{2}}=nR $$
Finally, the book defines temperature as $$ T=\frac{\lim_{P \to 0} (P \bar{V})}{R} $$
How should this definition be interpreted? Is temperature being treated as a function of both pressure and volume, or is one variable held fixed while the other varies? At finite pressure, T≠PV/R but does PV/R approach the temperature as the pressure is reduced toward zero?
Chemistry news on Phys.org
I just comment on limit $$P \rightarrow 0$$. As P has physical dimension it seems inappropriate to take its limit. It could be ##P##/ [constant which has physical dimension of pressure] << 1.
And
$$\frac{\lim_{P \to 0} (P \bar{V})}{R}=0$$
How does your textbook define taking the limit ?
What it tries to say is that the relationship holds precisely only for ideal gas (pointlike molecules with zero volume, no interactions other than elastic collisions), and that the lower the pressure, the closer the real gas is to the ideal gas.
This is quite common in the real systems, you will see the same approach in liquid mixtures/solutions - many of their properties depend on the concentration of the solute, but they are perfectly linear in concentration only for "infinitely diluted" solution.
And
How does your text define taking the limit ?
PV/R is not equal to 0 because the molar volume is not fixed. As the pressure decreases the molar volume increases and $$ \frac{P\bar{V}}{R} $$ approaches T.
So do we make this assumption because a gas approaching zero pressure corresponds to increasing the volume without bound, so that intermolecular interactions become negligible while the system remains in thermal equilibrium, and this allows temperature to be defined independently of the substance? Also, does this definition imply that temperature cannot be measured for systems with finite volume?
Kakashi said:
PV/R is not equal to 0 because the molar volume is not fixed. As the pressure decreases the molar volume increases and PV¯R approaches T.
I got ##\bar{V}## is molar volume. Thanks.
A gas with a known number of moles n is placed in a container whose volume can be varied and is brought into thermal equilibrium with a heat reservoir. In the limit where the volume is increased while maintaining equilibrium, the temperature of the heat reservoir can be determined from the equation
$$T=\frac{PV}{nR}$$
This is my interpretation of the textbook. Assuming that the gas pressure is initially in equilibrium with atmospheric pressure, if the air pressure in a closed laboratory is reduced and approaches a vacuum, this can be regarded as taking the limit in which the pressure is made smaller and smaller.
It is, in principle, possible to define temperature based on the Boyle–Charles law (Charles’s law); however, as a practical thermometer, this approach has problems in terms of accuracy and convenience and is therefore not suitable for practical use.
  • · Replies 0 ·
