How Does a High-Frequency, High-Power Electron Beam Affect a Vacuum?
  • Thread starter Thread starter Marianp
    Beam Vacuum
A vacuum pulsed electron beam with a frequency of 1 GHz and a power of 1 MeV per electron raises questions about its potential effects. The discussion highlights that energy is measured in electron volts (eV), not power, and clarifies the significance of synchrotron radiation at high energies. Historical examples from SLAC and CERN illustrate the challenges of accelerating electrons to high energies, particularly due to synchrotron radiation losses. These losses can lead to vacuum pressure fluctuations and beam scattering, complicating the use of superconducting RF cavities. Consequently, future electron-positron colliders, like the ILC, are being designed as linear colliders to mitigate these issues.
Marianp
What happens when we send in a vacuum pulsed electron beam with a frequency 1e9Hz and power 1e6MeV?
Thanks.
We get a pulsed electron beam with a frequency of 1GHz.
eV is a unit of energy, not of power. Do you mean 1TeV per electron?
Why do you expect something special to happen?
SLAC (Stanford) has accelerated electron beams to about 50 GeV in a straight beam tube using 2.4 GHz microwave power.
CERN (LEP) did accelerate electron beams to about 55 GeV using (I think) 240 (350?) MHz RF power in a 26 km circular accelerator.
The synchrotron radiation losses were extremely high. See http://hyperphysics.phy-astr.gsu.edu/hbase/particles/synchrotron.html
Because the synchrotron radiation power scales as beam energy E4, acceleration in a ring to a higher energy would be nearly impossible.
One consequence of synchrotron radiation is the desorption of trapped gasses, etc. from the beam tube walls, leading to vacuum pressure "bumps". which in turn cause beam scattering losses. Synchrotron radiation would be incompatible with superconducting RF cavities, due to the power load on the cryogenic system. Furthermore, at high energies (e.g., 1 TeV), the synchrotron radiation is very tightly focused into a pencil beam, and may melt any beam component it hits. (my guess anyway)..
LEP2 accelerated electrons up to ~105 GeV, and synchrotron radiation limited this energy.
Therefore, the next electron/positron collider (ILC) is planned as linear collider, with ~200-400 GeV per beam, depending on the LHC results.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
