What is the concentration of the HCl solution?
  • Thread starter Thread starter Jaramide
    Chemistry
To determine the concentration of hydrochloric acid (HCl) in a beaker, 10 mL of HCl is neutralized by 10.5 mL of sodium hydroxide (NaOH) with a concentration of 0.1 mol/dm³. The calculation begins by converting the volume of NaOH used into liters, resulting in 0.0105 L. The moles of NaOH are calculated as 0.0105 L multiplied by 0.1 mol/L, yielding 1.05 x 10^-3 moles of NaOH. Since the neutralization reaction between NaOH and HCl occurs in a 1:1 ratio, the moles of HCl are also 1.05 x 10^-3. Finally, to find the concentration of HCl, the moles of HCl are divided by the volume of HCl in liters (0.01 L), resulting in a concentration of 0.105 mol/L.
Jaramide
I need to return an asignment today and i just can't figure it out (should be a piece of cake for the people that hangs around here)
There is 10ml HCl with an unknown concentration i a beaker. You let NaOH with the concentration 0,100 mol/dm3 drip into the acid until it is neutralized.
It takes 10,5ml NaOH to neutralize the acid.
With this you should be able to calculate the concentration of the acid or so my teacher say. And all i can do is sit here and look dumb while my brain refuses to cooperate
Could anyone help me i would owe you a life debt. If i don't get this in today i won't get a grade in chemistry
Chemistry news on Phys.org
I have posted hint at https://www.physicsforums.com/showthread.php?s=&postid=115160#post115160
10.5mL is 0.0105L
mols of NaOH:
0.0105L x 0.1mol/L = 1.05 x 10^-3 mols NaOH
mols of HCl:
1molHCl/1molNaOH * 1.05 x 10^-3 mols NaOH = 1.05 x 10^-3 mol HCl
concentration:
(1.05 x 10^-3 mol HCl) / 0.01L = 0.105 mol/L
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
