Check Connectivity of Network using DFS
  • Thread starter Thread starter gradnu
    Network
To implement Depth-First Search (DFS) for checking network connectivity using an adjacency matrix, first convert the matrix into a suitable data structure, such as a 2D array or a vector. An object-oriented approach can be beneficial, utilizing classes for Graph, Node, and Connection. The DFS algorithm employs a Last In First Out (LIFO) stack to manage node traversal. As the algorithm progresses, it adds unvisited adjacent nodes to the stack, exploring as deeply as possible before backtracking when necessary. Each Node should maintain a reference to its parent Node to facilitate this backtracking process. This method effectively determines if a network is connected by ensuring all nodes are reachable from a starting point.
gradnu
Can somebody tell me how to implement(possibly C program) DFS to check whether a network is connected or not. I have network in the form of adjacency matrix.
Thanks
Technology news on Phys.org
I'm not sure I understand your question properly, but I can try to explain the DFS in general. I'm no mathematician so I can only really understand graphs and nodes and whatever in lay terms.
First you need to convert the adjacency matrix into some form of data structure you can store on the computer. A 2D array or vector (NOT the mathematical vector) I suppose? What I would do is use an object oriented language such as C++ and have a Graph composed of Nodes and Connections.
With the depth-first-search I think you can just implement a Last In First Out stack as your data structure to hold all the nodes. The LIFO stack is quite simple - the last item that you add into the stack, the first it is to come out.
A computer network can be represented as a graph with nodes. As you are traversing through the graph (with some sort of loop) you add to the stack all the adjacent unvisited nodes to the current node you are on. As you know, with a DFS you go as deeply into the graph until you find your target. If you reach the leaf node and still don't find it, then you need to track back to the previous node and go as deep into that node, and so on.
Once you find your node, you stop the process of looking. Again, if you were applying the OOP paradigm (e.g. Java or C++), you'd have a class Node, Connection, Graph, and Stack. Each Node needs a private data member that knows it's parent Node, so you can track back to the beginning once you've finished the search.
In general that is (to my knowledge) how DFS works.
Here is a good animation
http://www.rci.rutgers.edu/~cfs/472_html/AI_SEARCH/SearchAnimations.html
Thanks
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
